    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 65.1k Views 5 Watching
      dave_
      I have been trying to setup any of the 2 modules the installation and config goes well but when i reach the stage where i to discover devices on my alexa app it just doesn’t work!
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @dave_
        @dave_ MMM-AlexaControl works well and MMM-AlexaOnOff does not work.
        Can you post the config of the module, maybe somebody can help you?
          dave_ @Stoffbeuteluwe
          @Stoffbeuteluwe sure
            @Stoffbeuteluwe
            // module: ‘MMM-AlexaControl’,
            // position: ‘middle_center’,
            // config:{
            // image: true,
            // pm2ProcessName: “PM2”,
            // vcgencmd: “vcgencmd”,
            ignore the // brackets.
              sdetweil @dave_
              @dave_ what port range did u specify? you need to set a unique port range for each mirror on your network.
              I see it defaults. never mind.
              if u are running a Spotify player on this machine, the two things fight over the discovery port, 1900. so u have to stop the Spotify client while Alexa does Discovery
              S D 2 Replies Last reply Reply Quote 0
                @dave_ you should see messages like this on MM startup for alexacontrol
                [2020-08-02 16:47:29.642] [INFO] Checking git for module: MMM-AlexaControl
                [2020-08-02 16:47:29.675] [LOG] Adding multicast membership for 127.0.0.1
                [2020-08-02 16:47:29.676] [LOG] Adding multicast membership for 192.168.2.11
                [2020-08-02 16:47:29.677] [LOG] server is listening on 11000
                [2020-08-02 16:47:29.679] [LOG] server is listening on 11001
                [2020-08-02 16:47:29.679] [LOG] server is listening on 11002
                [2020-08-02 16:47:29.680] [LOG] server is listening on 11005
                  dave_ @sdetweil
                  @sdetweil hmm so should i stop the Spotify and try again? Or what port range Should i specify it to?
                    sdetweil @dave_
                    @dave_ you MUST stop the spotify thing , then restart MM, see those messages and then do alexa discover devices (using real echo device)…
                    once the devices are added, you can turn on the spotify tool …
                      dave_ @sdetweil
                      @sdetweil so i did turn of the Spotify and when i launched the magic mirror it is not showing up anything it’s blank screen Like usually when there’s something with config it says a message but in this case it’s blank
                        sdetweil @dave_
                        @dave_ look at the console where u started mm.
                        pm2 logs --lines=100
                        or
                        in the window where u did npm start.
                        black screen usually means missing library
                        u did npm install in the AlexaControl folder, right?
                          dave_ @sdetweil
                          @sdetweil it’s finally showing on screen like the mm is working but still had no luck with discovery and Spotify is off
                            sdetweil @dave_
                            @dave_ did u see the startup messages from the module like i posted?
                              dave_ @sdetweil
                              @sdetweil alt text
                              I am not quite sure which line to look at but check the image
                              Just out of curiosity does it have to be alexa echo device like can’t a i use for a soundbar or speaker with built in alexa or maybe even the mobile app?
                                sdetweil @dave_
                                @dave_ u got the eaddressinuse error. something is using port 1900, this the the port we stopped Spotify to get access to
                                stop mm, then do
                                sudo netstat -a | grep 1900
                                in there is a response then something is still using the port.
                                I havent tried discovery from my Alexa app in a long time. since they made it possible via voice command
                                  dave_ @sdetweil
                                  @sdetweil alt text that’s what it says
                                    sdetweil @dave_
                                    @dave_
                                    ok do this
                                    sudo netstat -a -p | grep 1900
                                    mine shows this when MM is running
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           11153/electron.js
                                      dave_ @sdetweil
                                      @sdetweil ohh shit i had installed jellyfin media server ages ago and that’s what it’s saying how do i uninstall that 😂
                                        sdetweil @dave_
                                        @dave_ sorry, no idea… google might help
                                          dave_ @sdetweil
                                          @sdetweil lemme see and I’ll let u know
                                            dave_ @sdetweil
                                            @sdetweil can i just Change the ports? And then make ot work if yes what should i change it to
                                            • 4 / 5
