    MagicMirror² v2.12.0 & MMM-DHT-Sensor (temperatur & humidity)
    17 Posts 4 Posters 1.1k Views 4 Watching
      Stef @sdetweil
      @sdetweil sorry I couldn’t test it earlier…
      pi@mirrorpi:~/MagicMirror/modules $ rm -rf node_modules
      pi@mirrorpi:~/MagicMirror/modules $ rm package-locj.json
      rm: das Entfernen von 'package-locj.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
      pi@mirrorpi:~/MagicMirror/modules $ npm install nan
      + nan@2.14.1
      added 1 package from 8 contributors and audited 1330 packages in 76.427s
      92 packages are looking for funding
        run `npm fund` for details
      found 1 low severity vulnerability
        run `npm audit fix` to fix them, or `npm audit` for details
      pi@mirrorpi:~/MagicMirror/modules $ npm audit fix
      up to date in 56.381s
      fixed 0 of 1 vulnerability in 1295 scanned packages
        1 vulnerability required manual review and could not be updated
      > magicmirror@2.12.0 install /home/pi/MagicMirror
      > echo "Installing vendor files ...
      " && cd vendor && npm install --loglevel=error
      audited 150 packages in 14.543s
      found 8 vulnerabilities (7 low, 1 high)
      > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
      > npm run install-fonts && echo "MagicMirror installation finished successfully!
      > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
      > echo "Installing fonts ...
      " && cd fonts && npm install --loglevel=error
      audited 1 package in 1.136s
      found 0 vulnerabilities
      audited 1330 packages in 87.2s
      npm ERR! code ENOAUDIT
      npm ERR! audit Your configured registry (https://registry.npmjs.org/) may not support audit requests, or the audit endpoint may be temporarily unavailable.
      npm ERR! audit The server said: <!DOCTYPE html>
      npm ERR! audit <!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
      npm ERR! audit <!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
      npm ERR! audit <!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
      npm ERR! audit <!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
      npm ERR! audit <head>
      npm ERR! audit <meta http-equiv="refresh" content="0">
      npm ERR! audit
      npm ERR! audit <title>prod-frontdoor-lb-west.internal.npmjs.com | 502: Bad gateway</title>
      npm ERR! audit <meta charset="UTF-8" />
      npm ERR! audit <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      npm ERR! audit <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
      npm ERR! audit <meta name="robots" content="noindex, nofollow" />
      npm ERR! audit <meta name="viewport" content="width=device-width,initial-scale=1" />
      npm ERR! audit <link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
      npm ERR! audit <!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
      npm ERR! audit <style type="text/css">body{margin:0;padding:0}</style>
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit </head>
      npm ERR! audit <body>
      npm ERR! audit <div id="cf-wrapper">
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit     <div id="cf-error-details" class="cf-error-details-wrapper">
      npm ERR! audit         <div class="cf-wrapper cf-error-overview">
      npm ERR! audit             <h1>
      npm ERR! audit
      npm ERR! audit               <span class="cf-error-type">Error</span>
      npm ERR! audit               <span class="cf-error-code">502</span>
      npm ERR! audit               <small class="heading-ray-id">Ray ID: 5bebb812163005b7 &bull; 2020-08-06 21:05:59 UTC</small>
      npm ERR! audit             </h1>
      npm ERR! audit             <h2 class="cf-subheadline">Bad gateway</h2>
      npm ERR! audit         </div><!-- /.error-overview -->
      npm ERR! audit
      npm ERR! audit         <div class="cf-section cf-highlight cf-status-display">
      npm ERR! audit             <div class="cf-wrapper">
      npm ERR! audit                 <div class="cf-columns cols-3">
      npm ERR! audit
      npm ERR! audit <div id="cf-browser-status" class="cf-column cf-status-item cf-browser-status ">
      npm ERR! audit   <div class="cf-icon-error-container">
      npm ERR! audit     <i class="cf-icon cf-icon-browser"></i>
      npm ERR! audit     <i class="cf-icon-status cf-icon-ok"></i>
      npm ERR! audit   <span class="cf-status-desc">You</span>
      npm ERR! audit   <h3 class="cf-status-name">Browser</h3>
      npm ERR! audit   <span class="cf-status-label">Working</span>
      npm ERR! audit
      npm ERR! audit <div id="cf-cloudflare-status" class="cf-column cf-status-item cf-cloudflare-status ">
      npm ERR! audit     <i class="cf-icon cf-icon-cloud"></i>
      npm ERR! audit   <span class="cf-status-desc">Frankfurt</span>
      npm ERR! audit   <h3 class="cf-status-name">Cloudflare</h3>
      npm ERR! audit
      npm ERR! audit <div id="cf-host-status" class="cf-column cf-status-item cf-host-status cf-error-source">
      npm ERR! audit     <i class="cf-icon cf-icon-server"></i>
      npm ERR! audit     <i class="cf-icon-status cf-icon-error"></i>
      npm ERR! audit   <span class="cf-status-desc">prod-frontdoor-lb-west.internal.npmjs.com</span>
      npm ERR! audit   <h3 class="cf-status-name">Host</h3>
      npm ERR! audit   <span class="cf-status-label">Error</span>
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit         </div><!-- /.status-display -->
      npm ERR! audit
      npm ERR! audit         <div class="cf-section cf-wrapper">
      npm ERR! audit             <div class="cf-columns two">
      npm ERR! audit                 <div class="cf-column">
      npm ERR! audit                     <h2>What happened?</h2>
      npm ERR! audit                     <p>The web server reported a bad gateway error.</p>
      npm ERR! audit
      npm ERR! audit                     <h2>What can I do?</h2>
      npm ERR! audit                     <p>Please try again in a few minutes.</p>
      npm ERR! audit
      npm ERR! audit         </div><!-- /.section -->
      npm ERR! audit
      npm ERR! audit         <div class="cf-error-footer cf-wrapper">
      npm ERR! audit   <p>
      npm ERR! audit     <span class="cf-footer-item">Cloudflare Ray ID: <strong>5bebb812163005b7</strong></span>
      npm ERR! audit     <span class="cf-footer-separator">&bull;</span>
      npm ERR! audit     <span class="cf-footer-item"><span>Your IP</span>: 95.223.72.58</span>
      npm ERR! audit     <span class="cf-footer-item"><span>Performance &amp; security by</span> <a href="https://www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
      npm ERR! audit
      npm ERR! audit   </p>
      npm ERR! audit </div><!-- /.error-footer -->
      npm ERR! audit
      npm ERR! audit
      npm ERR! audit     </div><!-- /#cf-error-details -->
      npm ERR! audit </div><!-- /#cf-wrapper -->
      npm ERR! audit </body>
      npm ERR! audit </html>
      npm ERR! audit
      npm ERR! audit
      npm ERR!     /home/pi/.npm/_logs/2020-08-06T21_05_59_816Z-debug.log
        Stef @Stef
        @Stef oh and it won’t start… 😕
        Again, thank you for your help!
          sdetweil @Stef
          @Stef yeh, my screwup. u did this for the modules folder
          not the dht module folder
          and u did the audit fix… ouch
          and I had a misspelling, supposed to be package-lock.json
          ok, tough restart
          cd ~/MagicMirror
          rm -rf node_modules
          rm package-lock.json
          npm install
          repeat the last 3 steps in each module folder that contains a package.json file
          in the dht sensor folder, ONLY, do
          rm -rf node_modules
          npm install nan -- save
          npm install
            Stef
            YES! FINALLY!
            Thank you so very much @sdetweil !!!
            That did the trick! :D
              sdetweil @Stef
              @Stef woohoo! thanks for the feedback
              • BKeyportB Offline
                BKeyport Module Developer
                hey, @Stef
                Do you have any trouble with the module getting stuck? I’m having a heck of a time getting it to update if my mirror is up more than 30-40 minutes. :(
                  Stef @BKeyport
                  @BKeyport Nope i did not experienced that…
