    MagicMirror² v2.12.0 & MMM-DHT-Sensor (temperatur & humidity)
    17 Posts 4 Posters 2.3k Views 4 Watching
      Stef
      @sdetweil thanks a million for your effort… unfortunatley, the last command gives me back a bunch of errors… even with sudo…
      i ran it for a third time and got this:
      pi@mirrorpi:~/MagicMirror/modules/MMM-DHT-Sensor $ node node_modules/.bin/electron-rebuild
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      gyp info it worked if it ends with ok
      gyp info using node-gyp@6.1.0
      gyp info using node@12.14.0 | linux | arm
      gyp ERR! clean error
      gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
      gyp ERR! System Linux 4.19.66-v7+
      gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node-dht-sensor
      gyp ERR! node -v v12.14.0
      gyp ERR! node-gyp -v v6.1.0
      gyp ERR! not ok
      Failed with exit code: 1
      Error: gyp info it worked if it ends with ok
      gyp ERR! not ok
          at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
          at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
          at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
          at Subscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
          at Subscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
          at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
          at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
          at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
          at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
      @Bugsounet which command should i run?
        sdetweil @Stef
        @Stef cause I used sudo, some stuff is now connected to root user
        from the module folder
        do
        sudo chown -R pi *
        sudo chown -R pi *.*
        and rerun the electron rebuild
        show us the errors
          Stef
          ok…
          since the post would be to long, you will find it here
            sdetweil @Stef
            @Stef fun
            another try
            rm -rf node_modules
            rm package-lock.json
            npm install nan
            npm install
              Stef @sdetweil
              @sdetweil sorry I couldn’t test it earlier…
              pi@mirrorpi:~/MagicMirror/modules $ rm -rf node_modules
              pi@mirrorpi:~/MagicMirror/modules $ rm package-locj.json
              rm: das Entfernen von 'package-locj.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
              pi@mirrorpi:~/MagicMirror/modules $ npm install nan
              + nan@2.14.1
              added 1 package from 8 contributors and audited 1330 packages in 76.427s
              92 packages are looking for funding
                run `npm fund` for details
              found 1 low severity vulnerability
                run `npm audit fix` to fix them, or `npm audit` for details
              pi@mirrorpi:~/MagicMirror/modules $ npm audit fix
              up to date in 56.381s
              fixed 0 of 1 vulnerability in 1295 scanned packages
                1 vulnerability required manual review and could not be updated
              > magicmirror@2.12.0 install /home/pi/MagicMirror
              " && cd vendor && npm install --loglevel=error
              audited 150 packages in 14.543s
              found 8 vulnerabilities (7 low, 1 high)
              > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
              > npm run install-fonts && echo "MagicMirror installation finished successfully!
              > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
              > echo "Installing fonts ...
              " && cd fonts && npm install --loglevel=error
              audited 1 package in 1.136s
              found 0 vulnerabilities
              audited 1330 packages in 87.2s
              npm ERR! code ENOAUDIT
              npm ERR! audit Your configured registry (https://registry.npmjs.org/) may not support audit requests, or the audit endpoint may be temporarily unavailable.
              npm ERR! audit The server said: <!DOCTYPE html>
              npm ERR! audit <!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
              npm ERR! audit <!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
              npm ERR! audit <!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
              npm ERR! audit <!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
              npm ERR! audit <head>
              npm ERR! audit <meta http-equiv="refresh" content="0">
              npm ERR! audit
              npm ERR! audit <title>prod-frontdoor-lb-west.internal.npmjs.com | 502: Bad gateway</title>
              npm ERR! audit <meta charset="UTF-8" />
              npm ERR! audit <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
              npm ERR! audit <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
              npm ERR! audit <meta name="robots" content="noindex, nofollow" />
              npm ERR! audit <meta name="viewport" content="width=device-width,initial-scale=1" />
              npm ERR! audit <link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
              npm ERR! audit <!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
              npm ERR! audit <style type="text/css">body{margin:0;padding:0}</style>
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit </head>
              npm ERR! audit <body>
              npm ERR! audit <div id="cf-wrapper">
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit     <div id="cf-error-details" class="cf-error-details-wrapper">
              npm ERR! audit         <div class="cf-wrapper cf-error-overview">
              npm ERR! audit             <h1>
              npm ERR! audit
              npm ERR! audit               <span class="cf-error-type">Error</span>
              npm ERR! audit               <span class="cf-error-code">502</span>
              npm ERR! audit               <small class="heading-ray-id">Ray ID: 5bebb812163005b7 &bull; 2020-08-06 21:05:59 UTC</small>
              npm ERR! audit             </h1>
              npm ERR! audit             <h2 class="cf-subheadline">Bad gateway</h2>
              npm ERR! audit         </div><!-- /.error-overview -->
              npm ERR! audit
              npm ERR! audit         <div class="cf-section cf-highlight cf-status-display">
              npm ERR! audit             <div class="cf-wrapper">
              npm ERR! audit                 <div class="cf-columns cols-3">
              npm ERR! audit
              npm ERR! audit <div id="cf-browser-status" class="cf-column cf-status-item cf-browser-status ">
              npm ERR! audit   <div class="cf-icon-error-container">
              npm ERR! audit     <i class="cf-icon cf-icon-browser"></i>
              npm ERR! audit     <i class="cf-icon-status cf-icon-ok"></i>
              npm ERR! audit   <span class="cf-status-desc">You</span>
              npm ERR! audit   <h3 class="cf-status-name">Browser</h3>
              npm ERR! audit   <span class="cf-status-label">Working</span>
              npm ERR! audit
              npm ERR! audit <div id="cf-cloudflare-status" class="cf-column cf-status-item cf-cloudflare-status ">
              npm ERR! audit     <i class="cf-icon cf-icon-cloud"></i>
              npm ERR! audit   <span class="cf-status-desc">Frankfurt</span>
              npm ERR! audit   <h3 class="cf-status-name">Cloudflare</h3>
              npm ERR! audit
              npm ERR! audit <div id="cf-host-status" class="cf-column cf-status-item cf-host-status cf-error-source">
              npm ERR! audit     <i class="cf-icon cf-icon-server"></i>
              npm ERR! audit     <i class="cf-icon-status cf-icon-error"></i>
              npm ERR! audit   <span class="cf-status-desc">prod-frontdoor-lb-west.internal.npmjs.com</span>
              npm ERR! audit   <h3 class="cf-status-name">Host</h3>
              npm ERR! audit   <span class="cf-status-label">Error</span>
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit         </div><!-- /.status-display -->
              npm ERR! audit
              npm ERR! audit         <div class="cf-section cf-wrapper">
              npm ERR! audit             <div class="cf-columns two">
              npm ERR! audit                 <div class="cf-column">
              npm ERR! audit                     <h2>What happened?</h2>
              npm ERR! audit                     <p>The web server reported a bad gateway error.</p>
              npm ERR! audit
              npm ERR! audit                     <h2>What can I do?</h2>
              npm ERR! audit                     <p>Please try again in a few minutes.</p>
              npm ERR! audit
              npm ERR! audit         </div><!-- /.section -->
              npm ERR! audit
              npm ERR! audit         <div class="cf-error-footer cf-wrapper">
              npm ERR! audit   <p>
              npm ERR! audit     <span class="cf-footer-item">Cloudflare Ray ID: <strong>5bebb812163005b7</strong></span>
              npm ERR! audit     <span class="cf-footer-separator">&bull;</span>
              npm ERR! audit     <span class="cf-footer-item"><span>Your IP</span>: 95.223.72.58</span>
              npm ERR! audit     <span class="cf-footer-item"><span>Performance &amp; security by</span> <a href="https://www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
              npm ERR! audit
              npm ERR! audit   </p>
              npm ERR! audit </div><!-- /.error-footer -->
              npm ERR! audit
              npm ERR! audit
              npm ERR! audit     </div><!-- /#cf-error-details -->
              npm ERR! audit </div><!-- /#cf-wrapper -->
              npm ERR! audit </body>
              npm ERR! audit </html>
              npm ERR! audit
              npm ERR! audit
              npm ERR!     /home/pi/.npm/_logs/2020-08-06T21_05_59_816Z-debug.log
                Stef @Stef
                @Stef oh and it won’t start… 😕
                Again, thank you for your help!
                  sdetweil @Stef
                  @Stef yeh, my screwup. u did this for the modules folder
                  not the dht module folder
                  and u did the audit fix… ouch
                  and I had a misspelling, supposed to be package-lock.json
                  ok, tough restart
                  rm -rf node_modules
                  npm install
                  repeat the last 3 steps in each module folder that contains a package.json file
                  in the dht sensor folder, ONLY, do
                  rm -rf node_modules
                  npm install nan -- save
                  npm install
                    Stef
                    YES! FINALLY!
                    Thank you so very much @sdetweil !!!
                    That did the trick! :D
                      sdetweil @Stef
                      @Stef woohoo! thanks for the feedback
                      • BKeyportB
                        BKeyport Module Developer
                        hey, @Stef
                        Do you have any trouble with the module getting stuck? I’m having a heck of a time getting it to update if my mirror is up more than 30-40 minutes. :(
                          Stef @BKeyport
                          @BKeyport Nope i did not experienced that…
