    MagicMirror² v2.12.0 & MMM-DHT-Sensor (temperatur & humidity)
    17 Posts 4 Posters 2.0k Views 4 Watching
      sdetweil @Stef
      @Stef do
      npm install electron-rebuild --save
      node node_modules/.bin/electron-rebuild
        Stef @sdetweil
        Remembered that
        Did that
        Did not work
        Still the same error message…
          sdetweil @Stef
          @Stef asked friend to look at this too. we have been discussing right way to fix. so hang on
            sdetweil @Stef
            @Stef ok, let’s try this
            cd~/MagicMirror/modules
            cd MMM-DHT-Sensor
            npm i electron-rebuild
              [[global:former-user]]
              note:
              Don’t do npm fix npm audit fix npm rebuild or other command like @sdetweil says
              otherwise you will have the same error !
                Stef
                @sdetweil thanks a million for your effort… unfortunatley, the last command gives me back a bunch of errors… even with sudo…
                i ran it for a third time and got this:
                pi@mirrorpi:~/MagicMirror/modules/MMM-DHT-Sensor $ node node_modules/.bin/electron-rebuild
                ✖ Rebuild Failed
                An unhandled error occurred inside electron-rebuild
                gyp info it worked if it ends with ok
                gyp info using node-gyp@6.1.0
                gyp info using node@12.14.0 | linux | arm
                gyp ERR! clean error
                gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
                gyp ERR! System Linux 4.19.66-v7+
                gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source"
                gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node-dht-sensor
                gyp ERR! node -v v12.14.0
                gyp ERR! node-gyp -v v6.1.0
                gyp ERR! not ok
                Failed with exit code: 1
                Error: gyp info it worked if it ends with ok
                gyp ERR! not ok
                    at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
                    at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
                    at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
                    at Subscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                    at Subscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                    at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                    at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                    at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
                    at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
                @Bugsounet which command should i run?
                  sdetweil @Stef
                  @Stef cause I used sudo, some stuff is now connected to root user
                  from the module folder
                  do
                  sudo chown -R pi *
                  sudo chown -R pi *.*
                  and rerun the electron rebuild
                  show us the errors
                    Stef
                    ok…
                    since the post would be to long, you will find it here
                      sdetweil @Stef
                      @Stef fun
                      another try
                      rm -rf node_modules
                      rm package-lock.json
                      npm install nan
                      npm install
                        Stef @sdetweil
                        @sdetweil sorry I couldn’t test it earlier…
                        pi@mirrorpi:~/MagicMirror/modules $ rm -rf node_modules
                        pi@mirrorpi:~/MagicMirror/modules $ rm package-locj.json
                        rm: das Entfernen von 'package-locj.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                        pi@mirrorpi:~/MagicMirror/modules $ npm install nan
                        + nan@2.14.1
                        added 1 package from 8 contributors and audited 1330 packages in 76.427s
                        92 packages are looking for funding
                          run `npm fund` for details
                        found 1 low severity vulnerability
                          run `npm audit fix` to fix them, or `npm audit` for details
                        pi@mirrorpi:~/MagicMirror/modules $ npm audit fix
                        up to date in 56.381s
                        fixed 0 of 1 vulnerability in 1295 scanned packages
                          1 vulnerability required manual review and could not be updated
                        > magicmirror@2.12.0 install /home/pi/MagicMirror
                        " && cd vendor && npm install --loglevel=error
                        audited 150 packages in 14.543s
                        found 8 vulnerabilities (7 low, 1 high)
                        > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                        > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                        > echo "Installing fonts ...
                        " && cd fonts && npm install --loglevel=error
                        audited 1 package in 1.136s
                        found 0 vulnerabilities
                        audited 1330 packages in 87.2s
                        npm ERR! code ENOAUDIT
                        npm ERR! audit Your configured registry (https://registry.npmjs.org/) may not support audit requests, or the audit endpoint may be temporarily unavailable.
                        npm ERR! audit The server said: <!DOCTYPE html>
                        npm ERR! audit <!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
                        npm ERR! audit <!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
                        npm ERR! audit <!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
                        npm ERR! audit <!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
                        npm ERR! audit <head>
                        npm ERR! audit <meta http-equiv="refresh" content="0">
                        npm ERR! audit
                        npm ERR! audit <title>prod-frontdoor-lb-west.internal.npmjs.com | 502: Bad gateway</title>
                        npm ERR! audit <meta charset="UTF-8" />
                        npm ERR! audit <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
                        npm ERR! audit <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
                        npm ERR! audit <meta name="robots" content="noindex, nofollow" />
                        npm ERR! audit <meta name="viewport" content="width=device-width,initial-scale=1" />
                        npm ERR! audit <link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
                        npm ERR! audit <!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
                        npm ERR! audit <style type="text/css">body{margin:0;padding:0}</style>
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit </head>
                        npm ERR! audit <body>
                        npm ERR! audit <div id="cf-wrapper">
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit     <div id="cf-error-details" class="cf-error-details-wrapper">
                        npm ERR! audit         <div class="cf-wrapper cf-error-overview">
                        npm ERR! audit             <h1>
                        npm ERR! audit
                        npm ERR! audit               <span class="cf-error-type">Error</span>
                        npm ERR! audit               <span class="cf-error-code">502</span>
                        npm ERR! audit               <small class="heading-ray-id">Ray ID: 5bebb812163005b7 &bull; 2020-08-06 21:05:59 UTC</small>
                        npm ERR! audit             </h1>
                        npm ERR! audit             <h2 class="cf-subheadline">Bad gateway</h2>
                        npm ERR! audit         </div><!-- /.error-overview -->
                        npm ERR! audit
                        npm ERR! audit         <div class="cf-section cf-highlight cf-status-display">
                        npm ERR! audit             <div class="cf-wrapper">
                        npm ERR! audit                 <div class="cf-columns cols-3">
                        npm ERR! audit
                        npm ERR! audit <div id="cf-browser-status" class="cf-column cf-status-item cf-browser-status ">
                        npm ERR! audit   <div class="cf-icon-error-container">
                        npm ERR! audit     <i class="cf-icon cf-icon-browser"></i>
                        npm ERR! audit     <i class="cf-icon-status cf-icon-ok"></i>
                        npm ERR! audit   <span class="cf-status-desc">You</span>
                        npm ERR! audit   <h3 class="cf-status-name">Browser</h3>
                        npm ERR! audit   <span class="cf-status-label">Working</span>
                        npm ERR! audit
                        npm ERR! audit <div id="cf-cloudflare-status" class="cf-column cf-status-item cf-cloudflare-status ">
                        npm ERR! audit     <i class="cf-icon cf-icon-cloud"></i>
                        npm ERR! audit   <span class="cf-status-desc">Frankfurt</span>
                        npm ERR! audit   <h3 class="cf-status-name">Cloudflare</h3>
                        npm ERR! audit
                        npm ERR! audit <div id="cf-host-status" class="cf-column cf-status-item cf-host-status cf-error-source">
                        npm ERR! audit     <i class="cf-icon cf-icon-server"></i>
                        npm ERR! audit     <i class="cf-icon-status cf-icon-error"></i>
                        npm ERR! audit   <span class="cf-status-desc">prod-frontdoor-lb-west.internal.npmjs.com</span>
                        npm ERR! audit   <h3 class="cf-status-name">Host</h3>
                        npm ERR! audit   <span class="cf-status-label">Error</span>
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit         </div><!-- /.status-display -->
                        npm ERR! audit
                        npm ERR! audit         <div class="cf-section cf-wrapper">
                        npm ERR! audit             <div class="cf-columns two">
                        npm ERR! audit                 <div class="cf-column">
                        npm ERR! audit                     <h2>What happened?</h2>
                        npm ERR! audit                     <p>The web server reported a bad gateway error.</p>
                        npm ERR! audit
                        npm ERR! audit                     <h2>What can I do?</h2>
                        npm ERR! audit                     <p>Please try again in a few minutes.</p>
                        npm ERR! audit
                        npm ERR! audit         </div><!-- /.section -->
                        npm ERR! audit
                        npm ERR! audit         <div class="cf-error-footer cf-wrapper">
                        npm ERR! audit   <p>
                        npm ERR! audit     <span class="cf-footer-item">Cloudflare Ray ID: <strong>5bebb812163005b7</strong></span>
                        npm ERR! audit     <span class="cf-footer-separator">&bull;</span>
                        npm ERR! audit     <span class="cf-footer-item"><span>Your IP</span>: 95.223.72.58</span>
                        npm ERR! audit     <span class="cf-footer-item"><span>Performance &amp; security by</span> <a href="https://www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
                        npm ERR! audit
                        npm ERR! audit   </p>
                        npm ERR! audit </div><!-- /.error-footer -->
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR! audit     </div><!-- /#cf-error-details -->
                        npm ERR! audit </div><!-- /#cf-wrapper -->
                        npm ERR! audit </body>
                        npm ERR! audit </html>
                        npm ERR! audit
                        npm ERR! audit
                        npm ERR!     /home/pi/.npm/_logs/2020-08-06T21_05_59_816Z-debug.log
                          Stef @Stef
                          @Stef oh and it won’t start… 😕
                          Again, thank you for your help!
                            sdetweil @Stef
                            @Stef yeh, my screwup. u did this for the modules folder
                            not the dht module folder
                            and u did the audit fix… ouch
                            and I had a misspelling, supposed to be package-lock.json
                            ok, tough restart
                            rm -rf node_modules
                            npm install
                            repeat the last 3 steps in each module folder that contains a package.json file
                            in the dht sensor folder, ONLY, do
                            rm -rf node_modules
                            npm install nan -- save
                            npm install
                              Stef
                              YES! FINALLY!
                              Thank you so very much @sdetweil !!!
                              That did the trick! :D
                                sdetweil @Stef
                                @Stef woohoo! thanks for the feedback
                                • BKeyportB Offline
                                  BKeyport Module Developer
                                  hey, @Stef
                                  Do you have any trouble with the module getting stuck? I’m having a heck of a time getting it to update if my mirror is up more than 30-40 minutes. :(
                                    Stef @BKeyport
                                    @BKeyport Nope i did not experienced that…
