    MagicMirror² v2.12.0 & MMM-DHT-Sensor (temperatur & humidity)
    17 Posts 4 Posters 2.3k Views 4 Watching
      sdetweil @Stef
      @Stef asked friend to look at this too. we have been discussing right way to fix. so hang on
        sdetweil @Stef
        @Stef ok, let’s try this
        cd~/MagicMirror/modules
        cd MMM-DHT-Sensor
        npm i electron-rebuild
        node node_modules/.bin/electron-rebuild
          A Former User
          note:
          Don’t do npm fix npm audit fix npm rebuild or other command like @sdetweil says
          otherwise you will have the same error !
            Stef
            @sdetweil thanks a million for your effort… unfortunatley, the last command gives me back a bunch of errors… even with sudo…
            i ran it for a third time and got this:
            pi@mirrorpi:~/MagicMirror/modules/MMM-DHT-Sensor $ node node_modules/.bin/electron-rebuild
            ✖ Rebuild Failed
            An unhandled error occurred inside electron-rebuild
            gyp info it worked if it ends with ok
            gyp info using node-gyp@6.1.0
            gyp info using node@12.14.0 | linux | arm
            gyp ERR! clean error
            gyp ERR! stack Error: EACCES: permission denied, unlink 'build/Makefile'
            gyp ERR! System Linux 4.19.66-v7+
            gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source"
            gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node-dht-sensor
            gyp ERR! node -v v12.14.0
            gyp ERR! node-gyp -v v6.1.0
            gyp ERR! not ok
            Failed with exit code: 1
            Error: gyp info it worked if it ends with ok
            gyp ERR! not ok
                at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
                at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
                at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
                at Subscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                at Subscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
                at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
            @Bugsounet which command should i run?
              sdetweil @Stef
              @Stef cause I used sudo, some stuff is now connected to root user
              from the module folder
              do
              sudo chown -R pi *
              sudo chown -R pi *.*
              and rerun the electron rebuild
              show us the errors
                Stef
                ok…
                since the post would be to long, you will find it here
                  sdetweil @Stef
                  @Stef fun
                  another try
                  rm -rf node_modules
                  rm package-lock.json
                  npm install nan
                  npm install
                    Stef @sdetweil
                    @sdetweil sorry I couldn’t test it earlier…
                    pi@mirrorpi:~/MagicMirror/modules $ rm -rf node_modules
                    pi@mirrorpi:~/MagicMirror/modules $ rm package-locj.json
                    rm: das Entfernen von 'package-locj.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                    pi@mirrorpi:~/MagicMirror/modules $ npm install nan
                    + nan@2.14.1
                    added 1 package from 8 contributors and audited 1330 packages in 76.427s
                    92 packages are looking for funding
                      run `npm fund` for details
                    found 1 low severity vulnerability
                      run `npm audit fix` to fix them, or `npm audit` for details
                    pi@mirrorpi:~/MagicMirror/modules $ npm audit fix
                    up to date in 56.381s
                    fixed 0 of 1 vulnerability in 1295 scanned packages
                      1 vulnerability required manual review and could not be updated
                    > magicmirror@2.12.0 install /home/pi/MagicMirror
                    " && cd vendor && npm install --loglevel=error
                    audited 150 packages in 14.543s
                    found 8 vulnerabilities (7 low, 1 high)
                    > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                    > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                    > echo "Installing fonts ...
                    " && cd fonts && npm install --loglevel=error
                    audited 1 package in 1.136s
                    found 0 vulnerabilities
                    audited 1330 packages in 87.2s
                    npm ERR! code ENOAUDIT
                    npm ERR! audit Your configured registry (https://registry.npmjs.org/) may not support audit requests, or the audit endpoint may be temporarily unavailable.
                    npm ERR! audit The server said: <!DOCTYPE html>
                    npm ERR! audit <!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en-US"> <![endif]-->
                    npm ERR! audit <!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en-US"> <![endif]-->
                    npm ERR! audit <!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en-US"> <![endif]-->
                    npm ERR! audit <!--[if gt IE 8]><!--> <html class="no-js" lang="en-US"> <!--<![endif]-->
                    npm ERR! audit <head>
                    npm ERR! audit <meta http-equiv="refresh" content="0">
                    npm ERR! audit
                    npm ERR! audit <title>prod-frontdoor-lb-west.internal.npmjs.com | 502: Bad gateway</title>
                    npm ERR! audit <meta charset="UTF-8" />
                    npm ERR! audit <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
                    npm ERR! audit <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1" />
                    npm ERR! audit <meta name="robots" content="noindex, nofollow" />
                    npm ERR! audit <meta name="viewport" content="width=device-width,initial-scale=1" />
                    npm ERR! audit <link rel="stylesheet" id="cf_styles-css" href="/cdn-cgi/styles/cf.errors.css" type="text/css" media="screen,projection" />
                    npm ERR! audit <!--[if lt IE 9]><link rel="stylesheet" id='cf_styles-ie-css' href="/cdn-cgi/styles/cf.errors.ie.css" type="text/css" media="screen,projection" /><![endif]-->
                    npm ERR! audit <style type="text/css">body{margin:0;padding:0}</style>
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit </head>
                    npm ERR! audit <body>
                    npm ERR! audit <div id="cf-wrapper">
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit     <div id="cf-error-details" class="cf-error-details-wrapper">
                    npm ERR! audit         <div class="cf-wrapper cf-error-overview">
                    npm ERR! audit             <h1>
                    npm ERR! audit
                    npm ERR! audit               <span class="cf-error-type">Error</span>
                    npm ERR! audit               <span class="cf-error-code">502</span>
                    npm ERR! audit               <small class="heading-ray-id">Ray ID: 5bebb812163005b7 &bull; 2020-08-06 21:05:59 UTC</small>
                    npm ERR! audit             </h1>
                    npm ERR! audit             <h2 class="cf-subheadline">Bad gateway</h2>
                    npm ERR! audit         </div><!-- /.error-overview -->
                    npm ERR! audit
                    npm ERR! audit         <div class="cf-section cf-highlight cf-status-display">
                    npm ERR! audit             <div class="cf-wrapper">
                    npm ERR! audit                 <div class="cf-columns cols-3">
                    npm ERR! audit
                    npm ERR! audit <div id="cf-browser-status" class="cf-column cf-status-item cf-browser-status ">
                    npm ERR! audit   <div class="cf-icon-error-container">
                    npm ERR! audit     <i class="cf-icon cf-icon-browser"></i>
                    npm ERR! audit     <i class="cf-icon-status cf-icon-ok"></i>
                    npm ERR! audit   <span class="cf-status-desc">You</span>
                    npm ERR! audit   <h3 class="cf-status-name">Browser</h3>
                    npm ERR! audit   <span class="cf-status-label">Working</span>
                    npm ERR! audit
                    npm ERR! audit <div id="cf-cloudflare-status" class="cf-column cf-status-item cf-cloudflare-status ">
                    npm ERR! audit     <i class="cf-icon cf-icon-cloud"></i>
                    npm ERR! audit   <span class="cf-status-desc">Frankfurt</span>
                    npm ERR! audit   <h3 class="cf-status-name">Cloudflare</h3>
                    npm ERR! audit
                    npm ERR! audit <div id="cf-host-status" class="cf-column cf-status-item cf-host-status cf-error-source">
                    npm ERR! audit     <i class="cf-icon cf-icon-server"></i>
                    npm ERR! audit     <i class="cf-icon-status cf-icon-error"></i>
                    npm ERR! audit   <span class="cf-status-desc">prod-frontdoor-lb-west.internal.npmjs.com</span>
                    npm ERR! audit   <h3 class="cf-status-name">Host</h3>
                    npm ERR! audit   <span class="cf-status-label">Error</span>
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit         </div><!-- /.status-display -->
                    npm ERR! audit
                    npm ERR! audit         <div class="cf-section cf-wrapper">
                    npm ERR! audit             <div class="cf-columns two">
                    npm ERR! audit                 <div class="cf-column">
                    npm ERR! audit                     <h2>What happened?</h2>
                    npm ERR! audit                     <p>The web server reported a bad gateway error.</p>
                    npm ERR! audit
                    npm ERR! audit                     <h2>What can I do?</h2>
                    npm ERR! audit                     <p>Please try again in a few minutes.</p>
                    npm ERR! audit
                    npm ERR! audit         </div><!-- /.section -->
                    npm ERR! audit
                    npm ERR! audit         <div class="cf-error-footer cf-wrapper">
                    npm ERR! audit   <p>
                    npm ERR! audit     <span class="cf-footer-item">Cloudflare Ray ID: <strong>5bebb812163005b7</strong></span>
                    npm ERR! audit     <span class="cf-footer-separator">&bull;</span>
                    npm ERR! audit     <span class="cf-footer-item"><span>Your IP</span>: 95.223.72.58</span>
                    npm ERR! audit     <span class="cf-footer-item"><span>Performance &amp; security by</span> <a href="https://www.cloudflare.com/5xx-error-landing?utm_source=error_footer" id="brand_link" target="_blank">Cloudflare</a></span>
                    npm ERR! audit
                    npm ERR! audit   </p>
                    npm ERR! audit </div><!-- /.error-footer -->
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR! audit     </div><!-- /#cf-error-details -->
                    npm ERR! audit </div><!-- /#cf-wrapper -->
                    npm ERR! audit </body>
                    npm ERR! audit </html>
                    npm ERR! audit
                    npm ERR! audit
                    npm ERR!     /home/pi/.npm/_logs/2020-08-06T21_05_59_816Z-debug.log
                      Stef @Stef
                      @Stef oh and it won’t start… 😕
                      Again, thank you for your help!
                        sdetweil @Stef
                        @Stef yeh, my screwup. u did this for the modules folder
                        not the dht module folder
                        and u did the audit fix… ouch
                        and I had a misspelling, supposed to be package-lock.json
                        ok, tough restart
                        rm -rf node_modules
                        npm install
                        repeat the last 3 steps in each module folder that contains a package.json file
                        in the dht sensor folder, ONLY, do
                        rm -rf node_modules
                        npm install nan -- save
                        npm install
                          Stef
                          YES! FINALLY!
                          Thank you so very much @sdetweil !!!
                          That did the trick! :D
                            sdetweil @Stef
                            @Stef woohoo! thanks for the feedback
                            • BKeyportB
                              BKeyport Module Developer
                              hey, @Stef
                              Do you have any trouble with the module getting stuck? I’m having a heck of a time getting it to update if my mirror is up more than 30-40 minutes. :(
                                Stef @BKeyport
                                @BKeyport Nope i did not experienced that…
