    Put RSS module in two places?
    8 Posts 3 Posters 1.6k Views 3 Watching
    • T Offline
      tf2
      Is it possible to put the RSS module in two places on a MagicMirror implementation? I’d like it in the (default) lower third, but also in the top bar.
      When I try to add another RSS module with the position of top_bar, I get a config error. But I don’t know if that’s because I’ve mistyped something, or if it’s not possible to put the RSS module in two places at once.
      Thanks!
        sdetweil @tf2
        @tf2 can u show the config error?
        • thgmirrorT Offline
          thgmirror
          @tf2 I have two “newsfeed”-modules one over each other, both on the bottom-bar and it works
          But this is an exception, if you want to double any other module you have to copy the original folder, rename the folder and use this name to change the corresponding *.js in the new folder. Additionally, rename the Module.register name inside the js-file.
          You can verify your config.js here https://esprima.org/demo/validate.html for example.
          Hope that helps,
          Thomas
          • T Offline
            tf2 @thgmirror
            @thgmirror Just to make sure: Do you mean two instances of the module, or do you mean two separate RSS feeds in one module? I can do the latter, but for some reason the former isn’t working.
            If you’ve gotten two instances to work, then I have some kind of an error in my config file that doesn’t crash the mirror entirely.
              thgmirror
              This post is deleted!
                thgmirror
                Hi @tf2, in my config.js, I have two newsfeed-instances:
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: " 3 Podcasts",
                					url: "http://localhost:8080/modules/Podcast.rss2"
                			showSourceTitle: true,
                			showPublishDate: true,
                			broadcastNewsFeeds: true,
                            ignoreOldItems: true,
                            showDescription: true,
                			broadcastNewsUpdates: true,
                            wrapDescription: true
                and
                		module: "newsfeed",
                			feeds: [
                					title: "Tagesschau",
                					url: "http://www.tagesschau.de/xml/rss2"
                					title: "Spiegel Online",
                					url: "https://www.spiegel.de/schlagzeilen/index.rss"
                					title: "Radio Bonn Rhein-Sieg",
                					url: "https://www.radiobonn.de/thema/bonn-su-429.rss"
                which leads to this output:
                • T Offline
                  tf2 @thgmirror
                  @thgmirror Hey, thanks! Very helpful. Will try that out tonight.
                    sdetweil @tf2
                    @tf2 notice those were both configured to the same position, 1st in config it on top, next is lower, etc
                    they don’t HAVE to be in the same area
