[Electron] display en screen after installing MMM-PIR-Sensor
I’m lost, can you tell me another time the electron rebuild procedure you posted.
my logs :
pi@raspberrypi:~ $ pm2 logs --lines=100 [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 100 lines: PM2 | 2020-08-22T15:45:31: PM2 log: pid=1888 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T15:45:31: PM2 log: pid=1888 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T15:45:31: PM2 log: pid=1888 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T15:45:31: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-08-22T15:45:31: PM2 log: pid=1888 msg=process killed PM2 | 2020-08-22T15:45:31: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T15:45:31: PM2 log: App [mm:0] online PM2 | 2020-08-22T15:55:13: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT] PM2 | 2020-08-22T15:55:13: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T15:55:13: PM2 log: App [mm:0] online PM2 | 2020-08-22T15:55:14: PM2 log: Stopping app:mm id:0 PM2 | 2020-08-22T15:55:15: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-08-22T15:55:15: PM2 log: pid=2771 msg=process killed PM2 | 2020-08-22T15:55:15: PM2 log: PM2 successfully stopped PM2 | 2020-08-22T15:55:24: PM2 log: =============================================================================== PM2 | 2020-08-22T15:55:24: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-08-22T15:55:24: PM2 log: Time : Sat Aug 22 2020 15:55:24 GMT+0200 (GMT+02:00) PM2 | 2020-08-22T15:55:24: PM2 log: PM2 version : 4.4.1 PM2 | 2020-08-22T15:55:24: PM2 log: Node.js version : 10.22.0 PM2 | 2020-08-22T15:55:24: PM2 log: Current arch : arm PM2 | 2020-08-22T15:55:24: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2020-08-22T15:55:24: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2020-08-22T15:55:24: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2020-08-22T15:55:24: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2020-08-22T15:55:24: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2020-08-22T15:55:24: PM2 log: Worker Interval : 30000 PM2 | 2020-08-22T15:55:24: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2020-08-22T15:55:24: PM2 log: Concurrent actions : 2 PM2 | 2020-08-22T15:55:24: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-08-22T15:55:24: PM2 log: =============================================================================== PM2 | 2020-08-22T15:55:24: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T15:55:24: PM2 log: App [mm:0] online PM2 | 2020-08-22T16:01:22: PM2 log: Stopping app:mm id:0 PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T16:01:23: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-08-22T16:01:23: PM2 log: pid=568 msg=process killed PM2 | 2020-08-22T16:01:23: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T16:01:23: PM2 log: App [mm:0] online PM2 | 2020-08-22T16:03:17: PM2 log: Stopping app:mm id:0 PM2 | 2020-08-22T16:03:17: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-08-22T16:03:17: PM2 log: pid=2333 msg=process killed PM2 | 2020-08-22T16:03:17: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T16:03:17: PM2 log: App [mm:0] online PM2 | 2020-08-22T18:17:09: PM2 log: =============================================================================== PM2 | 2020-08-22T18:17:09: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-08-22T18:17:09: PM2 log: Time : Sat Aug 22 2020 18:17:09 GMT+0200 (GMT+02:00) PM2 | 2020-08-22T18:17:09: PM2 log: PM2 version : 4.4.1 PM2 | 2020-08-22T18:17:09: PM2 log: Node.js version : 10.22.0 PM2 | 2020-08-22T18:17:09: PM2 log: Current arch : arm PM2 | 2020-08-22T18:17:09: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2020-08-22T18:17:09: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2020-08-22T18:17:09: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2020-08-22T18:17:09: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2020-08-22T18:17:09: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2020-08-22T18:17:09: PM2 log: Worker Interval : 30000 PM2 | 2020-08-22T18:17:09: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2020-08-22T18:17:09: PM2 log: Concurrent actions : 2 PM2 | 2020-08-22T18:17:09: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-08-22T18:17:09: PM2 log: =============================================================================== PM2 | 2020-08-22T18:17:09: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T18:17:09: PM2 log: App [mm:0] online PM2 | 2020-08-22T18:45:22: PM2 log: Stopping app:mm id:0 PM2 | 2020-08-22T18:45:22: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-08-22T18:45:22: PM2 log: pid=565 msg=process killed PM2 | 2020-08-22T18:45:22: PM2 log: PM2 successfully stopped PM2 | 2020-08-22T18:45:31: PM2 log: =============================================================================== PM2 | 2020-08-22T18:45:31: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-08-22T18:45:31: PM2 log: Time : Sat Aug 22 2020 18:45:31 GMT+0200 (GMT+02:00) PM2 | 2020-08-22T18:45:31: PM2 log: PM2 version : 4.4.1 PM2 | 2020-08-22T18:45:31: PM2 log: Node.js version : 10.22.0 PM2 | 2020-08-22T18:45:31: PM2 log: Current arch : arm PM2 | 2020-08-22T18:45:31: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2020-08-22T18:45:31: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2020-08-22T18:45:31: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2020-08-22T18:45:31: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2020-08-22T18:45:31: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2020-08-22T18:45:31: PM2 log: Worker Interval : 30000 PM2 | 2020-08-22T18:45:31: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2020-08-22T18:45:31: PM2 log: Concurrent actions : 2 PM2 | 2020-08-22T18:45:31: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-08-22T18:45:31: PM2 log: =============================================================================== PM2 | 2020-08-22T18:45:31: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-08-22T18:45:31: PM2 log: App [mm:0] online PM2 | 2020-08-22T19:26:59: PM2 log: Stopping app:mm id:0 PM2 | 2020-08-22T19:26:59: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:26:59: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:26:59: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:26:59: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:26:59: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:26:59: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:27:00: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:27:00: PM2 log: pid=564 msg=failed to kill - retrying in 100ms PM2 | 2020-08-22T19:27:00: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-08-22T19:27:00: PM2 log: pid=564 msg=process killed /home/pi/.pm2/logs/mm-error.log last 100 lines: 0|mm | at Class.addons (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:5076) 0|mm | at Class.initialize (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:3566) 0|mm | at MD5.cb (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:807) 0|mm | at MD5.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/md5/index.js:1:1719) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '::', 0|mm | port: 8569 0|mm | } 0|mm | [2020-08-22 18:33:41.663] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-08-22 18:33:41.665] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | [2020-08-22 18:36:30.379] [ERROR] Whoops! There was an uncaught exception... 0|mm | [2020-08-22 18:36:30.380] [ERROR] Error: listen EADDRINUSE: address already in use :::8569 0|mm | at Server.setupListenHandle [as _listen2] (net.js:1226:14) 0|mm | at listenInCluster (net.js:1274:12) 0|mm | at Server.listen (net.js:1362:7) 0|mm | at Function.listen (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/express/lib/application.js:618:24) 0|mm | at DialServer.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/cast/index.js:90:23) 0|mm | at Class.addons (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:5076) 0|mm | at Class.initialize (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:3566) 0|mm | at MD5.cb (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:807) 0|mm | at MD5.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/md5/index.js:1:1719) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '::', 0|mm | port: 8569 0|mm | } 0|mm | [2020-08-22 18:36:30.382] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-08-22 18:36:30.383] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | [2020-08-22 18:41:28.797] [ERROR] Whoops! There was an uncaught exception... 0|mm | [2020-08-22 18:41:28.798] [ERROR] Error: listen EADDRINUSE: address already in use :::8569 0|mm | at Server.setupListenHandle [as _listen2] (net.js:1226:14) 0|mm | at listenInCluster (net.js:1274:12) 0|mm | at Server.listen (net.js:1362:7) 0|mm | at Function.listen (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/express/lib/application.js:618:24) 0|mm | at DialServer.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/cast/index.js:90:23) 0|mm | at Class.addons (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:5076) 0|mm | at Class.initialize (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:3566) 0|mm | at MD5.cb (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:807) 0|mm | at MD5.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/md5/index.js:1:1719) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '::', 0|mm | port: 8569 0|mm | } 0|mm | [2020-08-22 18:41:28.800] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-08-22 18:41:28.802] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | npm ERR! code ELIFECYCLE 0|mm | npm ERR! errno 1 0|mm | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|mm | npm ERR! Exit status 1 0|mm | npm ERR! 0|mm | npm ERR! Failed at the magicmirror@2.12.0 start script. 0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|mm | 0|mm | npm ERR! A complete log of this run can be found in: 0|mm | npm ERR! /home/pi/.npm/_logs/2020-08-22T16_45_21_656Z-debug.log 0|mm | [2020-08-22 18:45:47.160] [ERROR] (node:731) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead. 0|mm | [2020-08-22 18:45:47.163] [ERROR] (node:731) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead. 0|mm | [2020-08-22 18:48:27.965] [ERROR] Whoops! There was an uncaught exception... 0|mm | [2020-08-22 18:48:27.966] [ERROR] Error: listen EADDRINUSE: address already in use :::8569 0|mm | at Server.setupListenHandle [as _listen2] (net.js:1226:14) 0|mm | at listenInCluster (net.js:1274:12) 0|mm | at Server.listen (net.js:1362:7) 0|mm | at Function.listen (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/express/lib/application.js:618:24) 0|mm | at DialServer.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/cast/index.js:90:23) 0|mm | at Class.addons (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:5076) 0|mm | at Class.initialize (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:3566) 0|mm | at MD5.cb (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:807) 0|mm | at MD5.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/md5/index.js:1:1719) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '::', 0|mm | port: 8569 0|mm | } 0|mm | [2020-08-22 18:48:27.991] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-08-22 18:48:27.992] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | [2020-08-22 19:14:00.927] [ERROR] Whoops! There was an uncaught exception... 0|mm | [2020-08-22 19:14:00.928] [ERROR] Error: listen EADDRINUSE: address already in use :::8569 0|mm | at Server.setupListenHandle [as _listen2] (net.js:1226:14) 0|mm | at listenInCluster (net.js:1274:12) 0|mm | at Server.listen (net.js:1362:7) 0|mm | at Function.listen (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/express/lib/application.js:618:24) 0|mm | at DialServer.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/cast/index.js:90:23) 0|mm | at Class.addons (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:5076) 0|mm | at Class.initialize (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:3566) 0|mm | at MD5.cb (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:807) 0|mm | at MD5.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/md5/index.js:1:1719) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '::', 0|mm | port: 8569 0|mm | } 0|mm | [2020-08-22 19:14:00.930] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-08-22 19:14:00.931] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues /home/pi/.pm2/logs/mm-out.log last 100 lines: 0|mm | [2020-08-22 19:03:27.501] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:03:27.642] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:03:27.706] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:03:27.840] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:08:25.284] [LOG] Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics 0|mm | [2020-08-22 19:08:25.299] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:08:25.710] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:08:27.311] [INFO] Newsfeed-Fetcher: Broadcasting 18 items. 0|mm | [2020-08-22 19:08:27.476] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:08:27.669] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:08:27.774] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:08:27.909] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:08:27.978] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:25.284] [LOG] Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics 0|mm | [2020-08-22 19:13:25.284] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:13:25.717] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:13:27.468] [INFO] Newsfeed-Fetcher: Broadcasting 18 items. 0|mm | [2020-08-22 19:13:27.603] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:27.863] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:27.973] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:28.084] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:28.166] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:58.757] [LOG] Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics 0|mm | [2020-08-22 19:13:58.759] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:13:58.980] [LOG] Use existing news fetcher for url: https://www.lemonde.fr/rss/une.xml 0|mm | [2020-08-22 19:13:58.992] [INFO] Newsfeed-Fetcher: Broadcasting 18 items. 0|mm | [2020-08-22 19:13:59.032] [LOG] Use existing news fetcher for url: https://www.lemonde.fr/economie/rss_full.xml 0|mm | [2020-08-22 19:13:59.032] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:59.059] [LOG] Use existing news fetcher for url: https://www.lemonde.fr/culture/rss_full.xml 0|mm | [2020-08-22 19:13:59.063] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:59.134] [LOG] Refreshed access token because it has expired. Expired at: 19:13:58 now is: 19:13:59 0|mm | [2020-08-22 19:13:59.378] [INFO] Newsfeed-Fetcher: Broadcasting 18 items. 0|mm | [2020-08-22 19:13:59.385] [LOG] Use existing news fetcher for url: https://www.lemonde.fr/cinema/rss_full.xml 0|mm | [2020-08-22 19:13:59.386] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:59.598] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:59.799] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:59.828] [LOG] Use existing news fetcher for url: https://www.lemonde.fr/musiques/rss_full.xml 0|mm | [2020-08-22 19:13:59.829] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:13:59.977] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:14:00.003] [LOG] Use existing news fetcher for url: https://www.lemonde.fr/sport/rss_full.xml 0|mm | [2020-08-22 19:14:00.003] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:14:00.046] [LOG] [ASSISTANT] MMM-GoogleAssistant Version: 2.4.1 0|mm | [2020-08-22 19:14:00.223] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:14:00.251] [LOG] [A2D] MMM-Assistant2Display Version: 2.3.7 0|mm | [2020-08-22 19:14:00.412] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:14:00.511] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:14:00.533] [LOG] [Error: failed to read sensor] 0|mm | [2020-08-22 19:14:00.918] [LOG] [INTERNET] Internet v1.0.0 Initialized... 0|mm | [2020-08-22 19:14:00.919] [LOG] [CAST] Cast v1.0.0 Initialized... 0|mm | [2020-08-22 19:14:00.923] [LOG] [SPOTIFY:ERROR] Token not found! /home/pi/MagicMirror/modules/MMM-Assistant2Display/spotify-token.json 0|mm | [2020-08-22 19:14:00.924] [LOG] [SPOTIFY:ERROR] Token Error ! ./spotify-token.json 0|mm | [2020-08-22 19:14:00.925] [LOG] [A2D] Assistant2Display is initialized. 0|mm | [2020-08-22 19:14:00.963] [LOG] [SNOWBOY] Model selected: jarvis 0|mm | [2020-08-22 19:14:00.968] [LOG] [SNOWBOY] snowboy v1.5.1 Initialized... 0|mm | [2020-08-22 19:14:00.985] [LOG] [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js 0|mm | [2020-08-22 19:14:00.995] [LOG] [ASSISTANT] Assistant2Display Server Started 0|mm | [2020-08-22 19:14:01.022] [LOG] [ASSISTANT] Use native program (mpg321) for audio response 0|mm | [2020-08-22 19:14:01.031] [LOG] [SOUND] mpg321 Initialized 0|mm | [2020-08-22 19:14:01.040] [LOG] [ASSISTANT] Google Assistant is initialized. 0|mm | [2020-08-22 19:14:01.401] [LOG] [LPCM16] WARN: arecord: main:828: erreur à l'ouverture audio: Périphérique ou ressource occupé 0|mm | 0|mm | [2020-08-22 19:14:01.403] [LOG] [SNOWBOY] Retry restarting... 0|mm | [2020-08-22 19:14:03.505] [LOG] [LPCM16] WARN: arecord: main:828: erreur à l'ouverture audio: Périphérique ou ressource occupé 0|mm | 0|mm | [2020-08-22 19:14:03.510] [LOG] [SNOWBOY] Retry restarting... 0|mm | [2020-08-22 19:14:05.643] [LOG] [LPCM16] WARN: arecord: main:828: erreur à l'ouverture audio: Périphérique ou ressource occupé 0|mm | 0|mm | [2020-08-22 19:14:05.646] [LOG] [SNOWBOY] Retry restarting... 0|mm | [2020-08-22 19:14:07.776] [LOG] [LPCM16] WARN: arecord: main:828: 0|mm | [2020-08-22 19:14:07.777] [LOG] [LPCM16] WARN: erreur à l'ouverture audio: Périphérique ou ressource occupé 0|mm | 0|mm | [2020-08-22 19:14:07.780] [LOG] [SNOWBOY] Retry restarting... 0|mm | [2020-08-22 19:18:57.948] [LOG] Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics 0|mm | [2020-08-22 19:18:57.949] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:18:58.339] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:18:59.540] [INFO] Newsfeed-Fetcher: Broadcasting 18 items. 0|mm | [2020-08-22 19:18:59.722] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:18:59.949] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:19:00.201] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:19:00.336] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:19:00.612] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:23:57.944] [LOG] Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics 0|mm | [2020-08-22 19:23:57.947] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:23:58.321] [INFO] Calendar-Fetcher: Broadcasting 108 events. 0|mm | [2020-08-22 19:23:59.795] [INFO] Newsfeed-Fetcher: Broadcasting 18 items. 0|mm | [2020-08-22 19:23:59.994] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:24:00.249] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:24:00.500] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:24:00.560] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:24:00.786] [INFO] Newsfeed-Fetcher: Broadcasting 20 items. 0|mm | [2020-08-22 19:26:59.375] [LOG] Shutting down server... 0|mm | [2020-08-22 19:26:59.377] [LOG] Stopping module helper: MMM-GoogleAssistant 0|mm | [2020-08-22 19:26:59.377] [LOG] Stopping module helper: MMM-Assistant2Display 0|mm | [2020-08-22 19:26:59.378] [LOG] Stopping module helper: updatenotification 0|mm | [2020-08-22 19:26:59.379] [LOG] Stopping module helper: calendar 0|mm | [2020-08-22 19:26:59.379] [LOG] Stopping module helper: MMM-DHT-Sensor 0|mm | [2020-08-22 19:26:59.380] [LOG] Stopping module helper: MMM-NowPlayingOnSpotify 0|mm | [2020-08-22 19:26:59.380] [LOG] Stopping module helper: newsfeed 0|mm | [2020-08-22 19:26:59.467] [LOG] [LPCM16] WARN: arecord: pcm_read:2145: erreur en lecture: Appel système interrompu 0|mm | -
…without using MMM-PIR-Sensor or MMM-PIR, just tried with the PIR of MMM-Assistant2Display
@RIKKO14 eaddrinuse means something is already using that port?
did u reboot and then try pm2 start again
pm2 status will show u what is defined and running
