    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 13.1k Views 2 Watching
      RIKKO14
      If i find my IP adress, Can you give me the commands to delete the problem ?
        sdetweil @RIKKO14
        @RIKKO14 if u didn’t turn on ssh, it isn’t on, so can’t use it anyhow. look in your router to see what addresses were given out…
        I do that quite often, then fix/reserve the address so I don’t have to remember
          RIKKO14
          ok, i find my IP adress (I’ve wrote it in excel file with some commandes i use) and I connected in SHH with putty,
          thanks for your help to delete the commandh whose powered off my screen
            RIKKO14
            below my pm2 logs,
            If that can help you…
            https://www.cjoint.com/c/JHvqsqJ1QTT
              RIKKO14
              If it can help you this is my pm2 logs : https://www.cjoint.com/c/JHvqsqJ1QTT
                sdetweil @RIKKO14
                @RIKKO14 looking at… hard to tell
                do
                pm2 stop 0
                pm2 flush
                pm2 start 0
                the will throw away the old logs…
                  RIKKO14
                  I do this, the problem still here…
                    sdetweil @RIKKO14
                    @RIKKO14 it just makes the log easier to read. please post it again
                      RIKKO14
                      hre it is :
                      https://www.cjoint.com/c/JHvrPBCBgZT
                        RIKKO14
                        and this one (because i don’t if it it change something) : https://www.cjoint.com/c/JHvrUegIVzT after the command :
                        pm2 stop 0
                        pm2 flush
                        pm2 start 0
                        and after only pm2 logs --lines=100
                        without pm2 status and pm2 stop 0
                        • 2 / 5
