    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 13.7k Views 2 Watching
      sdetweil @RIKKO14
      @RIKKO14 too small to read
        sdetweil @RIKKO14
        @RIKKO14 i think the ‘failed to read the sensor’ error lead to the power off command being issued…
        but don’t know
          RIKKO14
          https://www.cjoint.com/c/JHvsIkBBC7T
            sdetweil @RIKKO14
            @RIKKO14 that is dev window open on forum page, not MM page
              RIKKO14
              that’s te problem…
              you ask me to do ctrl+shift+i on the mirror keyboard :
              but the screen is powered off so nothing displayed, i don’t know if it’s displayed something, I can’t see it…
              or i don’t anderstand to acceed MM page with my pc, I have only this :
                sdetweil @RIKKO14
                @RIKKO14 edit the config.js on the mirror
                change address and ipWhitelist like this
                address:"0.0.0.0",
                ipWhitelist:[],
                restart mm…
                now on your pc you can do
                http://pi_ip:8080
                and then u can open the dev window on that page
                i thought you said earlier you had removed the command to make your mirror screen turn off
                so you know which code is issuing the command… tell where that was
                  RIKKO14
                  But I have only acces to my MM with SSH, so how to edit the config.js on the mirror with ssh ?
                    sdetweil @RIKKO14
                    @RIKKO14 on the ssh terminal, (its a terminal window, same as works on pi)
                    cd MagicMirror/config
                    nano config.js
                    fix the text (move the cursor with the arrow keys and type and backspace
                    then ctrl-o to write the changes back out and ctrl -x to exit nano
                    then type pm2 restart 0
                    for your windows box, get winscp, then u can connect to pi as both terminal window (for commands)
                    and a file system view, like windows, double click on folder to go in, or file to edit… use your favorite pc editor (I use notepad++_)
                      RIKKO14
                      I do this :
                      and type pm2 restart 0, but my screen of MM is steel powered off…
                        sdetweil @RIKKO14
                        @RIKKO14 now on your PC, open browser to
                        http://pi_ip:8080
                        same up address u used for ssh
                        now see magic mirror
                        • 3 / 5
