    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 14.0k Views 2 Watching
      RIKKO14
      ctrl+shift+i on the mirror keyboard : nothing displayed : because my screen is powered off : source of the issue…
        sdetweil @RIKKO14
        @RIKKO14 too small to read
          sdetweil @RIKKO14
          @RIKKO14 i think the ‘failed to read the sensor’ error lead to the power off command being issued…
          but don’t know
            RIKKO14
            https://www.cjoint.com/c/JHvsIkBBC7T
              sdetweil @RIKKO14
              @RIKKO14 that is dev window open on forum page, not MM page
                RIKKO14
                that’s te problem…
                you ask me to do ctrl+shift+i on the mirror keyboard :
                but the screen is powered off so nothing displayed, i don’t know if it’s displayed something, I can’t see it…
                or i don’t anderstand to acceed MM page with my pc, I have only this :
                  sdetweil @RIKKO14
                  @RIKKO14 edit the config.js on the mirror
                  change address and ipWhitelist like this
                  address:"0.0.0.0",
                  ipWhitelist:[],
                  restart mm…
                  now on your pc you can do
                  http://pi_ip:8080
                  and then u can open the dev window on that page
                  i thought you said earlier you had removed the command to make your mirror screen turn off
                  so you know which code is issuing the command… tell where that was
                    RIKKO14
                    But I have only acces to my MM with SSH, so how to edit the config.js on the mirror with ssh ?
                      sdetweil @RIKKO14
                      @RIKKO14 on the ssh terminal, (its a terminal window, same as works on pi)
                      cd MagicMirror/config
                      nano config.js
                      fix the text (move the cursor with the arrow keys and type and backspace
                      then ctrl-o to write the changes back out and ctrl -x to exit nano
                      then type pm2 restart 0
                      for your windows box, get winscp, then u can connect to pi as both terminal window (for commands)
                      and a file system view, like windows, double click on folder to go in, or file to edit… use your favorite pc editor (I use notepad++_)
                        RIKKO14
                        I do this :
                        and type pm2 restart 0, but my screen of MM is steel powered off…
                        • 3 / 5
