    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 16.0k Views 2 Watching
      RIKKO14
      I do this, the problem still here…
        sdetweil @RIKKO14
        @RIKKO14 it just makes the log easier to read. please post it again
          RIKKO14
          hre it is :
          https://www.cjoint.com/c/JHvrPBCBgZT
            RIKKO14
            and this one (because i don’t if it it change something) : https://www.cjoint.com/c/JHvrUegIVzT after the command :
            pm2 stop 0
            pm2 flush
            pm2 start 0
            and after only pm2 logs --lines=100
            without pm2 status and pm2 stop 0
              sdetweil @RIKKO14
              @RIKKO14 i see this
              0|mm | [2020-08-21 19:37:58.395] [LOG] [LPCM16] WARN: arecord: pcm_read
              :2145: erreur en lecture: Appel système interrompu
              and this
              0|mm | [2020-08-21 19:43:41.435] [LOG] [Error: failed to read sensor]
              so we may have to look at t he browser dev window,
              ctrl-shift-i on the mirror keyboard
              select the tab labebled console,
              and scroll up to see any errors, usually in red text
                RIKKO14
                ctrl+shift+i on the mirror keyboard : nothing displayed
                ctrl+shift+i on my pc keyboard : this is displayed :
                  RIKKO14
                  ctrl+shift+i on the mirror keyboard : nothing displayed : because my screen is powered off : source of the issue…
                    sdetweil @RIKKO14
                    @RIKKO14 too small to read
                      sdetweil @RIKKO14
                      @RIKKO14 i think the ‘failed to read the sensor’ error lead to the power off command being issued…
                      but don’t know
                        RIKKO14
                        https://www.cjoint.com/c/JHvsIkBBC7T
                          sdetweil @RIKKO14
                          @RIKKO14 that is dev window open on forum page, not MM page
                            RIKKO14
                            that’s te problem…
                            you ask me to do ctrl+shift+i on the mirror keyboard :
                            but the screen is powered off so nothing displayed, i don’t know if it’s displayed something, I can’t see it…
                            or i don’t anderstand to acceed MM page with my pc, I have only this :
                              sdetweil @RIKKO14
                              @RIKKO14 edit the config.js on the mirror
                              change address and ipWhitelist like this
                              address:"0.0.0.0",
                              ipWhitelist:[],
                              restart mm…
                              now on your pc you can do
                              http://pi_ip:8080
                              and then u can open the dev window on that page
                              i thought you said earlier you had removed the command to make your mirror screen turn off
                              so you know which code is issuing the command… tell where that was
                                RIKKO14
                                But I have only acces to my MM with SSH, so how to edit the config.js on the mirror with ssh ?
                                  sdetweil @RIKKO14
                                  @RIKKO14 on the ssh terminal, (its a terminal window, same as works on pi)
                                  cd MagicMirror/config
                                  nano config.js
                                  fix the text (move the cursor with the arrow keys and type and backspace
                                  then ctrl-o to write the changes back out and ctrl -x to exit nano
                                  then type pm2 restart 0
                                  for your windows box, get winscp, then u can connect to pi as both terminal window (for commands)
                                  and a file system view, like windows, double click on folder to go in, or file to edit… use your favorite pc editor (I use notepad++_)
                                    RIKKO14
                                    I do this :
                                    and type pm2 restart 0, but my screen of MM is steel powered off…
                                      sdetweil @RIKKO14
                                      @RIKKO14 now on your PC, open browser to
                                      http://pi_ip:8080
                                      same up address u used for ssh
                                      now see magic mirror
                                        @sdetweil and disable the PIR module in config.js, and manually turn screen back on
                                        I’d this a Pi4. the off command works, the old on command doesn’t. I have seen others fight this but don’t remember any solution
                                          RIKKO14
                                          I reinstalled everything last night except the GA module and had the same problem.
                                          This morning I start all over again with the MMM-PIR module and the [Electron] screen is displayed instead of my MM screen.
                                          My pm2 log indicated that there is a Node.js version pb: I am in version 73 while the require version is version 64.
                                          So I put an issue on the link of this module to request an update of the module with Node.js version 73, hoping that there is only that.
                                          In the meantime I put aside this module and reinstall all the modules for the X time.
                                          my pm2 log :
                                          0|mm       | was compiled against a different Node.js version using
                                          0|mm       | NODE_MODULE_VERSION 64. This version of Node.js requires
                                          0|mm       | NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                                          0|mm       | the module (for instance, using `npm rebuild` or `npm install`).```
                                          Thank you very much however for all your help and patience.
                                            sdetweil @RIKKO14
                                            @RIKKO14 same instructions as post 5 of the topic
                                            • 2 / 3
