    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 15.0k Views 2 Watching
      RIKKO14
      If it can help you this is my pm2 logs : https://www.cjoint.com/c/JHvqsqJ1QTT
        sdetweil @RIKKO14
        @RIKKO14 looking at… hard to tell
        do
        pm2 stop 0
        pm2 flush
        pm2 start 0
        the will throw away the old logs…
          RIKKO14
          I do this, the problem still here…
            sdetweil @RIKKO14
            @RIKKO14 it just makes the log easier to read. please post it again
              RIKKO14
              hre it is :
              https://www.cjoint.com/c/JHvrPBCBgZT
                RIKKO14
                and this one (because i don’t if it it change something) : https://www.cjoint.com/c/JHvrUegIVzT after the command :
                pm2 stop 0
                pm2 flush
                pm2 start 0
                and after only pm2 logs --lines=100
                without pm2 status and pm2 stop 0
                  sdetweil @RIKKO14
                  @RIKKO14 i see this
                  0|mm | [2020-08-21 19:37:58.395] [LOG] [LPCM16] WARN: arecord: pcm_read
                  :2145: erreur en lecture: Appel système interrompu
                  and this
                  0|mm | [2020-08-21 19:43:41.435] [LOG] [Error: failed to read sensor]
                  so we may have to look at t he browser dev window,
                  ctrl-shift-i on the mirror keyboard
                  select the tab labebled console,
                  and scroll up to see any errors, usually in red text
                    RIKKO14
                    ctrl+shift+i on the mirror keyboard : nothing displayed
                    ctrl+shift+i on my pc keyboard : this is displayed :
                      RIKKO14
                      ctrl+shift+i on the mirror keyboard : nothing displayed : because my screen is powered off : source of the issue…
                        sdetweil @RIKKO14
                        @RIKKO14 too small to read
                          sdetweil @RIKKO14
                          @RIKKO14 i think the ‘failed to read the sensor’ error lead to the power off command being issued…
                          but don’t know
                            RIKKO14
                            https://www.cjoint.com/c/JHvsIkBBC7T
                              sdetweil @RIKKO14
                              @RIKKO14 that is dev window open on forum page, not MM page
                                RIKKO14
                                that’s te problem…
                                you ask me to do ctrl+shift+i on the mirror keyboard :
                                but the screen is powered off so nothing displayed, i don’t know if it’s displayed something, I can’t see it…
                                or i don’t anderstand to acceed MM page with my pc, I have only this :
                                  sdetweil @RIKKO14
                                  @RIKKO14 edit the config.js on the mirror
                                  change address and ipWhitelist like this
                                  address:"0.0.0.0",
                                  ipWhitelist:[],
                                  restart mm…
                                  now on your pc you can do
                                  http://pi_ip:8080
                                  and then u can open the dev window on that page
                                  i thought you said earlier you had removed the command to make your mirror screen turn off
                                  so you know which code is issuing the command… tell where that was
                                    RIKKO14
                                    But I have only acces to my MM with SSH, so how to edit the config.js on the mirror with ssh ?
                                      sdetweil @RIKKO14
                                      @RIKKO14 on the ssh terminal, (its a terminal window, same as works on pi)
                                      cd MagicMirror/config
                                      nano config.js
                                      fix the text (move the cursor with the arrow keys and type and backspace
                                      then ctrl-o to write the changes back out and ctrl -x to exit nano
                                      then type pm2 restart 0
                                      for your windows box, get winscp, then u can connect to pi as both terminal window (for commands)
                                      and a file system view, like windows, double click on folder to go in, or file to edit… use your favorite pc editor (I use notepad++_)
                                        RIKKO14
                                        I do this :
                                        and type pm2 restart 0, but my screen of MM is steel powered off…
                                          sdetweil @RIKKO14
                                          @RIKKO14 now on your PC, open browser to
                                          http://pi_ip:8080
                                          same up address u used for ssh
                                          now see magic mirror
                                            @sdetweil and disable the PIR module in config.js, and manually turn screen back on
                                            I’d this a Pi4. the off command works, the old on command doesn’t. I have seen others fight this but don’t remember any solution
                                            • 2 / 3
