    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 15.4k Views 2 Watching
      RIKKO14
      And I forgot to not the IP adress of my py, so I can’t use ssh now…
      Pffff, I’m not lucky, every modules I want works instead of the PIR module…
        RIKKO14
        If i find my IP adress, Can you give me the commands to delete the problem ?
          sdetweil @RIKKO14
          @RIKKO14 if u didn’t turn on ssh, it isn’t on, so can’t use it anyhow. look in your router to see what addresses were given out…
          I do that quite often, then fix/reserve the address so I don’t have to remember
            RIKKO14
            ok, i find my IP adress (I’ve wrote it in excel file with some commandes i use) and I connected in SHH with putty,
            thanks for your help to delete the commandh whose powered off my screen
              RIKKO14
              below my pm2 logs,
              If that can help you…
              https://www.cjoint.com/c/JHvqsqJ1QTT
                RIKKO14
                If it can help you this is my pm2 logs : https://www.cjoint.com/c/JHvqsqJ1QTT
                  sdetweil @RIKKO14
                  @RIKKO14 looking at… hard to tell
                  do
                  pm2 stop 0
                  pm2 flush
                  pm2 start 0
                  the will throw away the old logs…
                    RIKKO14
                    I do this, the problem still here…
                      sdetweil @RIKKO14
                      @RIKKO14 it just makes the log easier to read. please post it again
                        RIKKO14
                        hre it is :
                        https://www.cjoint.com/c/JHvrPBCBgZT
                          RIKKO14
                          and this one (because i don’t if it it change something) : https://www.cjoint.com/c/JHvrUegIVzT after the command :
                          pm2 stop 0
                          pm2 flush
                          pm2 start 0
                          and after only pm2 logs --lines=100
                          without pm2 status and pm2 stop 0
                            sdetweil @RIKKO14
                            @RIKKO14 i see this
                            0|mm | [2020-08-21 19:37:58.395] [LOG] [LPCM16] WARN: arecord: pcm_read
                            :2145: erreur en lecture: Appel système interrompu
                            and this
                            0|mm | [2020-08-21 19:43:41.435] [LOG] [Error: failed to read sensor]
                            so we may have to look at t he browser dev window,
                            ctrl-shift-i on the mirror keyboard
                            select the tab labebled console,
                            and scroll up to see any errors, usually in red text
                              RIKKO14
                              ctrl+shift+i on the mirror keyboard : nothing displayed
                              ctrl+shift+i on my pc keyboard : this is displayed :
                                RIKKO14
                                ctrl+shift+i on the mirror keyboard : nothing displayed : because my screen is powered off : source of the issue…
                                  sdetweil @RIKKO14
                                  @RIKKO14 too small to read
                                    sdetweil @RIKKO14
                                    @RIKKO14 i think the ‘failed to read the sensor’ error lead to the power off command being issued…
                                    but don’t know
                                      RIKKO14
                                      https://www.cjoint.com/c/JHvsIkBBC7T
                                        sdetweil @RIKKO14
                                        @RIKKO14 that is dev window open on forum page, not MM page
                                          RIKKO14
                                          that’s te problem…
                                          you ask me to do ctrl+shift+i on the mirror keyboard :
                                          but the screen is powered off so nothing displayed, i don’t know if it’s displayed something, I can’t see it…
                                          or i don’t anderstand to acceed MM page with my pc, I have only this :
                                            sdetweil @RIKKO14
                                            @RIKKO14 edit the config.js on the mirror
                                            change address and ipWhitelist like this
                                            address:"0.0.0.0",
                                            ipWhitelist:[],
                                            restart mm…
                                            now on your pc you can do
                                            http://pi_ip:8080
                                            and then u can open the dev window on that page
                                            i thought you said earlier you had removed the command to make your mirror screen turn off
                                            so you know which code is issuing the command… tell where that was
