    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 14.1k Views 2 Watching
      RIKKO14
        sdetweil @RIKKO14
        @RIKKO14
        from the module folder do
        npm install onoff --save
          RIKKO14
          I do npm install onoff --save in ~/MagicMirror/modules/MMM-PIR-Sensor and reboot
          but the same problem :
          0|mm       | [2020-08-21 13:36:17.541] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'onoff'
          0|mm       | Require stack:
          0|mm       | - /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js
          0|mm       | - /home/pi/MagicMirror/js/app.js
          0|mm       | - /home/pi/MagicMirror/js/electron.js
          0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          and
          0|mm       | [2020-08-21 14:22:15.086] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
          0|mm       | was compiled against a different Node.js version using
          0|mm       | NODE_MODULE_VERSION 64. This version of Node.js requires
          0|mm       | NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
          0|mm       | the module (for instance, using `npm rebuild` or `npm install`).
            sdetweil @RIKKO14
            @RIKKO14 oh the joy, do
            cd ~/MagicMirror/modules/MMM-PIR-Sensor
            rm -rf node_modules
            rm package-lock.json
            npm install
            npm install nan --save
            npm install electron-rebuild --save
            node node_modules/.bin/electron-rebuild
              sdetweil @RIKKO14
              @RIKKO14 and u don’t need to reboot. just use the pm2 commands
              pm2 restart 0
                RIKKO14
                I do this, MM reload but now after 2-3 secondes the screen turn off, GA with Jarvis works in background but i can’t find the screen of MM, if i do Ctrl + M
                nothing is happening, there, I’m completely stuck…, I unplugged but the problem stay here…
                  sdetweil @RIKKO14
                  @RIKKO14 is the screen actually powered off? did u enable ssh to get into a terminal window if desktop/mm has trouble?
                  if so I can issue commands there to turn on display tvservice or dpms…
                  I don’t use PIR, lots of troubles.
                    RIKKO14
                    I dont use ssh, only command on the py.
                    Instead of that, i think the py cut the power to the screen because the led of my screen is yellow like power off and not blue like something displayed.
                      RIKKO14
                      Yes, the screen actually powered off
                        RIKKO14
                        And I forgot to not the IP adress of my py, so I can’t use ssh now…
                        Pffff, I’m not lucky, every modules I want works instead of the PIR module…
                          RIKKO14
                          If i find my IP adress, Can you give me the commands to delete the problem ?
                            sdetweil @RIKKO14
                            @RIKKO14 if u didn’t turn on ssh, it isn’t on, so can’t use it anyhow. look in your router to see what addresses were given out…
                            I do that quite often, then fix/reserve the address so I don’t have to remember
                              RIKKO14
                              ok, i find my IP adress (I’ve wrote it in excel file with some commandes i use) and I connected in SHH with putty,
                              thanks for your help to delete the commandh whose powered off my screen
                                RIKKO14
                                below my pm2 logs,
                                If that can help you…
                                https://www.cjoint.com/c/JHvqsqJ1QTT
                                  RIKKO14
                                  If it can help you this is my pm2 logs : https://www.cjoint.com/c/JHvqsqJ1QTT
                                    sdetweil @RIKKO14
                                    @RIKKO14 looking at… hard to tell
                                    do
                                    pm2 stop 0
                                    pm2 flush
                                    pm2 start 0
                                    the will throw away the old logs…
                                      RIKKO14
                                      I do this, the problem still here…
                                        sdetweil @RIKKO14
                                        @RIKKO14 it just makes the log easier to read. please post it again
                                          RIKKO14
                                          hre it is :
                                          https://www.cjoint.com/c/JHvrPBCBgZT
                                            RIKKO14
                                            and this one (because i don’t if it it change something) : https://www.cjoint.com/c/JHvrUegIVzT after the command :
                                            pm2 stop 0
                                            pm2 flush
                                            pm2 start 0
                                            and after only pm2 logs --lines=100
                                            without pm2 status and pm2 stop 0
