    [Electron] display en screen after installing MMM-PIR-Sensor
    44 Posts 2 Posters 16.0k Views 2 Watching
      sdetweil @RIKKO14
      @RIKKO14 and u don’t need to reboot. just use the pm2 commands
      pm2 restart 0
        RIKKO14
        I do this, MM reload but now after 2-3 secondes the screen turn off, GA with Jarvis works in background but i can’t find the screen of MM, if i do Ctrl + M
        nothing is happening, there, I’m completely stuck…, I unplugged but the problem stay here…
          sdetweil @RIKKO14
          @RIKKO14 is the screen actually powered off? did u enable ssh to get into a terminal window if desktop/mm has trouble?
          if so I can issue commands there to turn on display tvservice or dpms…
          I don’t use PIR, lots of troubles.
            RIKKO14
            I dont use ssh, only command on the py.
            Instead of that, i think the py cut the power to the screen because the led of my screen is yellow like power off and not blue like something displayed.
              RIKKO14
              Yes, the screen actually powered off
                RIKKO14
                And I forgot to not the IP adress of my py, so I can’t use ssh now…
                Pffff, I’m not lucky, every modules I want works instead of the PIR module…
                  RIKKO14
                  If i find my IP adress, Can you give me the commands to delete the problem ?
                    sdetweil @RIKKO14
                    @RIKKO14 if u didn’t turn on ssh, it isn’t on, so can’t use it anyhow. look in your router to see what addresses were given out…
                    I do that quite often, then fix/reserve the address so I don’t have to remember
                      RIKKO14
                      ok, i find my IP adress (I’ve wrote it in excel file with some commandes i use) and I connected in SHH with putty,
                      thanks for your help to delete the commandh whose powered off my screen
                        RIKKO14
                        below my pm2 logs,
                        If that can help you…
                        https://www.cjoint.com/c/JHvqsqJ1QTT
                          RIKKO14
                          If it can help you this is my pm2 logs : https://www.cjoint.com/c/JHvqsqJ1QTT
                            sdetweil @RIKKO14
                            @RIKKO14 looking at… hard to tell
                            do
                            pm2 stop 0
                            pm2 flush
                            pm2 start 0
                            the will throw away the old logs…
                              RIKKO14
                              I do this, the problem still here…
                                sdetweil @RIKKO14
                                @RIKKO14 it just makes the log easier to read. please post it again
                                  RIKKO14
                                  hre it is :
                                  https://www.cjoint.com/c/JHvrPBCBgZT
                                    RIKKO14
                                    and this one (because i don’t if it it change something) : https://www.cjoint.com/c/JHvrUegIVzT after the command :
                                    pm2 stop 0
                                    pm2 flush
                                    pm2 start 0
                                    and after only pm2 logs --lines=100
                                    without pm2 status and pm2 stop 0
                                      sdetweil @RIKKO14
                                      @RIKKO14 i see this
                                      0|mm | [2020-08-21 19:37:58.395] [LOG] [LPCM16] WARN: arecord: pcm_read
                                      :2145: erreur en lecture: Appel système interrompu
                                      and this
                                      0|mm | [2020-08-21 19:43:41.435] [LOG] [Error: failed to read sensor]
                                      so we may have to look at t he browser dev window,
                                      ctrl-shift-i on the mirror keyboard
                                      select the tab labebled console,
                                      and scroll up to see any errors, usually in red text
                                        RIKKO14
                                        ctrl+shift+i on the mirror keyboard : nothing displayed
                                        ctrl+shift+i on my pc keyboard : this is displayed :
                                          RIKKO14
                                          ctrl+shift+i on the mirror keyboard : nothing displayed : because my screen is powered off : source of the issue…
                                            sdetweil @RIKKO14
                                            @RIKKO14 too small to read
