    Read local txt file from node_helper.js
    12 Posts 2 Posters 4.0k Views 2 Watching
      Aphamguin
      I am currently creating my own MM module, but am still relatively new to the platform so I used this tutorial to help me get started: https://forum.magicmirror.builders/topic/8534/head-first-developing-mm-module-for-extreme-beginners
      It mentions that the node_helper.js is able to read from local files, but I’m having trouble getting it to work.
      Here’s what my node_helper.js looks like so far:
      var NodeHelper = require("node_helper")
      var fs = require('fs')
      	start: function() {
      		this.rawText = fs.readFileSync('YourTrueHome.txt').toString()
      		this.readIn = this.rawText.split('\r')  //array of book line by line
      		this.text = this.readIn[1]
      	switch(notification) {
      		case "DO_YOUR_JOB":
      			this.sendSocketNotification("I_DID", this.text)
      			break
      And then in the main js file, the socket notification receiver simply reads:
      		switch(notification){
      			case "I_DID":
      				let elem = document.getElementById("COUNT")
      				elem.innerHTML = "Count: " + payload
      				break
      There is a COUNT element correctly defined in getDom: function() already.
        sdetweil @Aphamguin
        @Aphamguin what is the problem? I don’t see anything obvious
        also, see my Sample Module, which sends thru node_helper and gets response back which is shown.
        https://github.com/sdetweil/SampleModule
        if u are just showing text, you should use innerText, so the dom handler doesn’t have to examine your text only to find no html tags… (save cycles for other work)
          Aphamguin @sdetweil
          @sdetweil it seems to break the module and MM. Nothing shows up on the screen when I run it.
          Thanks for the sample module. It’s a really helpful template that I thought MM would have given us.
          It’s a simple module, but I’m just implementing its functionality in phases. At the moment I just want it to read from a local txt file, parse it into an array, and then display a chunk of text by accessing that array. So yes I’m just showing text. What is innerText? Do I just do elem.innerText(“text”)
          instead of elem.innerHTML(“text”)?
          S 3 Replies Last reply Reply Quote 0
            sdetweil @Aphamguin
            @Aphamguin yes elem.innerText.
            not sure what you mean by breaks mm…
            if u email me the three files I will find what the problem is.
            same user ID on gmail. rename the .js as .txt
              sdetweil @Aphamguin
              @Aphamguin you did set a position for your module in config, right? else the output doesn’t get used
                sdetweil @Aphamguin
                @Aphamguin the sample mm provides (hello world), uses the nunjuks template approach
                  Aphamguin @sdetweil
                  @sdetweil I have emailed you the main js file, the helper, and the txt file, all as txt files. I hope you got it.
                  I did set a position, yes.
                  Where can I get the sample mm? What is the nunjuks template approach?
                    sdetweil @Aphamguin
                    @Aphamguin my sample module
                    I don’t have any links to nunjuks.
                    but basically you create a layout template with locations for variables, and then supply the data, and the template engine does that formatting
                    see the helloworld module in the defaults folder
                    I am working on your module. the initial problem is the data filename has to have a path, else it will be in the MagicMirror folder.
                    but there is also an easier way to process your data.
                    in a couple hours I will get it back to you the same way
                      Aphamguin @sdetweil
                      @sdetweil Ok I’ll play around with it then.
                      Wow great. Thanks a lot. I really appreciate it.
                        sdetweil @Aphamguin
                        @Aphamguin sent back
                          Aphamguin
                          To conclude this issue, when reading from a local txt file with node_helper.js, you have to make sure the file name has a path. And then when parsing it, you can parse it easily by checking for carriage returns (\r) to see if if its a windows file. Here is a snippet of the solution:
                          this.rawText = fs.readFileSync(__dirname + '/localTxtFile.txt').toString()
                          this.isWindows = (this.rawText.indexOf('\r') == -1) ? false:true
                          this.variable= this.rawText.split(this.isWindows ? '\r\n\r\n' : '\n\n')
                            sdetweil @Aphamguin
                            @Aphamguin well, you think about what you are trying to accomplish,
                            I changed the file to Linux line ends. then realized u might get it from somewhere as windows line end. so added to make it work either way.
