    MMM-SystemStats and MMM-EyeCandy not initializing upon start, boot, reboot, or restart of the MM OS
    9 Posts 3 Posters 954 Views 3 Watching
    • P Offline
      pjcrux
      I’m running magic mirror os and I have been able to update and install numerous other modules but MMM-SystemStats and MMM-EyeCandy not initializing upon start, boot, reboot, or restart of the MM OS. All are installed and the modules are configued on config.js.
      Thoughts? Here’s my config.js:
      var config = {
      	address: "0.0.0.0", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: [], 	// Set [] to allow all IP addresses
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "imperial",
      		    module: 'MMM-SystemStats',
      		    position: 'bottom_right', // This can be any of the regions.
      	    	// classes: 'small_dimmed', // Add your own styling. OPTIONAL.
      		    header: 'System Stats', // Set the header text OPTIONAL
      			        updateInterval: '10000', // every 10 seconds
      			        align: 'right', // align labels
      			        header: 'System Stats', // This is optional
      			        units: 'imperial', // default, metric, imperial
      			        view: 'textAndIcon',
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
                  module: 'MMM-NetworkScanner',
                  position: 'bottom_left',
                  // Optional config options
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                  position: "top_bar"
                  module: "MMM-EyeCandy",
                  position: "top_center",
                       maxWidth: "50%",       // Sizes the images. Retains aspect ratio.
                       style: '19',            // Style number or use ownImagePath to override style
                       ownImagePath: 'https://www.picgifs.com/easter-graphics/cross/easter-graphics-cross-733506'      // ex: 'modules/MMM-EyeCandy/pix/YOUR_PICTURE_NAME.jpg', or internet url to image
      			module: "compliments",
      			position: "lower_third",
                      updateInterval: 10000,
                      compliments: {
                              morning: [
                              "Rise and Shine!",
      						"Good Morning!",
      						"Top of the Morning!",
                              afternoon: [
                              "It's a nice day outside. Go play in it!",
      						"How was your day?",
      						"Do you have homework?",
      						"What did you learn today?",
                              evening: [
                                      "Good Evening",
      								"Is your reading done?",
      								"Is your spelling done?",
      								"Wasn't the sunset beautiful?",
                                      "Wasn't the day just spectacular?"
      			module: "currentweather",
      				locationID: "4726206",
      				appid: "d889a2812cdb379288ae4e860e7cbb7a"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "4726206", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "News",
                              // url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                              url: "https://old.reddit.com/r/news.rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      };[link text](link url)
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @pjcrux
        @pjcrux what messages do you see on the console where you start MM?? npm start or pm2 logs if you use pm2.
          Mykle1 Project Sponsor Module Developer @pjcrux
          @pjcrux said in MMM-SystemStats and MMM-EyeCandy not initializing upon start, boot, reboot, or restart of the MM OS:
          The url you are trying to access is not directly to an image. Are you trying to get the cross image from that page? Is so, use this url
          https://www.picgifs.com/easter-graphics/easter-graphics/cross/easter-graphics-cross-056663.gif
          • P Offline
            pjcrux @sdetweil
            @sdetweil here’s the return:
            pi@magicmirroros:~/MagicMirror/modules/MMM-NetworkScanner $ pm2 info mm
            -bash: pm2: command not found
            pi@magicmirroros:~/MagicMirror/modules/MMM-NetworkScanner $ npm info mm
            npm WARN npm npm does not support Node.js v10.21.0
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make any promises that npm will work with this version.
            npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
            npm WARN npm You can find the latest version at https://nodejs.org/
            { name: 'mm',
              description: 'mock mate, mock http request, fs access and so on.',
              'dist-tags': { latest: '3.2.0', 'latest-1': '1.5.2' },
              versions:
               [ '0.0.1',
                 '0.0.2',
                 '0.0.3',
                 '0.0.4',
                 '0.0.5',
                 '0.0.6',
                 '0.0.7',
                 '0.0.8',
                 '0.0.9',
                 '0.1.0',
                 '0.1.1',
                 '0.1.2',
                 '0.1.3',
                 '0.1.4',
                 '0.1.5',
                 '0.1.6',
                 '0.1.7',
                 '0.1.8',
                 '0.2.0',
                 '0.2.1',
                 '1.0.0',
                 '1.0.1',
                 '1.1.0',
                 '1.2.0',
                 '1.3.0',
                 '1.3.1',
                 '1.3.2',
                 '1.3.3',
                 '1.3.4',
                 '1.3.5',
                 '1.4.0',
                 '1.5.0',
                 '1.5.1',
                 '1.5.2',
                 '2.0.0',
                 '2.0.1',
                 '2.1.0',
                 '2.1.1',
                 '2.2.0',
                 '2.2.1',
                 '2.2.2',
                 '2.3.0',
                 '2.4.0',
                 '2.4.1',
                 '2.5.0',
                 '3.0.0',
                 '3.0.1',
                 '3.0.2',
                 '3.0.3',
                 '3.1.0',
                 '3.2.0' ],
              maintainers:
               [ 'atian25 <atian25@qq.com>',
                 'dead_horse <dead_horse@qq.com>',
                 'fengmk2 <fengmk2@gmail.com>',
                 'popomore <sakura9515@gmail.com>' ],
              time:
               { modified: '2020-03-24T05:40:58.863Z',
                 created: '2012-11-03T17:37:01.800Z',
                 '0.0.1': '2012-11-03T17:37:06.751Z',
                 '0.0.2': '2012-11-06T15:30:11.465Z',
                 '0.0.3': '2012-11-06T15:57:17.632Z',
                 '0.0.4': '2012-11-12T18:53:52.835Z',
                 '0.0.5': '2012-11-20T19:23:15.607Z',
                 '0.0.6': '2012-11-20T19:58:09.388Z',
                 '0.0.7': '2012-11-26T09:11:28.133Z',
                 '0.0.8': '2012-11-26T16:24:03.056Z',
                 '0.0.9': '2012-11-27T17:11:35.398Z',
                 '0.1.0': '2012-12-01T13:05:25.339Z',
                 '0.1.1': '2013-04-15T02:26:09.576Z',
                 '0.1.2': '2013-04-20T13:14:18.884Z',
                 '0.1.3': '2013-05-05T05:53:38.502Z',
                 '0.1.4': '2013-05-21T08:27:49.494Z',
                 '0.1.5': '2013-07-03T09:07:10.505Z',
                 '0.1.6': '2013-07-04T03:32:04.040Z',
                 '0.1.7': '2013-11-20T02:46:48.809Z',
                 '0.1.8': '2013-12-27T10:46:19.727Z',
                 '0.2.0': '2014-02-21T06:57:30.451Z',
                 '0.2.1': '2014-03-14T06:23:02.151Z',
                 '1.0.0': '2014-10-29T18:09:27.474Z',
                 '1.0.1': '2014-10-30T15:18:51.238Z',
                 '1.1.0': '2015-05-08T06:06:08.451Z',
                 '1.2.0': '2015-08-16T09:22:41.232Z',
                 '1.3.0': '2015-08-22T14:18:07.015Z',
                 '1.3.1': '2015-08-30T17:06:40.412Z',
                 '1.3.2': '2015-09-17T08:58:20.869Z',
                 '1.3.3': '2015-09-17T15:22:49.695Z',
                 '1.3.4': '2015-09-24T10:34:57.396Z',
                 '1.3.5': '2015-09-28T16:27:05.896Z',
                 '1.4.0': '2016-06-12T04:04:27.416Z',
                 '1.5.0': '2016-06-12T16:23:51.481Z',
                 '1.5.1': '2016-07-21T02:45:11.372Z',
                 '2.0.0': '2016-07-31T04:13:13.502Z',
                 '2.0.1': '2017-01-22T09:31:49.350Z',
                 '2.1.0': '2017-01-24T18:46:16.748Z',
                 '1.5.2': '2017-09-06T14:52:41.576Z',
                 '2.1.1': '2017-09-06T15:44:40.138Z',
                 '2.2.0': '2017-09-07T01:21:52.337Z',
                 '2.2.1': '2018-07-11T12:02:51.495Z',
                 '2.2.2': '2018-07-12T03:55:43.166Z',
                 '2.3.0': '2018-08-07T06:00:22.000Z',
                 '2.4.0': '2018-08-08T09:40:37.638Z',
                 '2.4.1': '2018-08-27T08:36:58.870Z',
                 '2.5.0': '2019-03-06T15:52:30.962Z',
                 '3.0.0': '2020-02-29T16:59:36.088Z',
                 '3.0.1': '2020-02-29T17:31:53.399Z',
                 '3.0.2': '2020-02-29T18:25:04.055Z',
                 '3.0.3': '2020-03-12T06:15:56.593Z',
                 '3.1.0': '2020-03-13T13:06:06.788Z',
                 '3.2.0': '2020-03-24T05:40:56.524Z' },
              author: 'fengmk2 <fengmk2@gmail.com> (https://fengmk2.com)',
              repository: { type: 'git', url: 'git://github.com/node-modules/mm.git' },
              readmeFilename: 'README.md',
              homepage: 'http://github.com/node-modules/mm',
              keywords: [ 'mm', 'muk', 'mock', 'test' ],
              contributors:
               [ 'fengmk2 <fengmk2@gmail.com> (https://github.com/fengmk2)',
                 'dead_horse <dead_horse@qq.com> (https://github.com/dead-horse)',
                 'AlsoTang <alsotang@gmail.com> (https://github.com/alsotang)',
                 'Haoliang Gao <sakura9515@gmail.com> (https://github.com/popomore)',
                 'xavierzhou <xiayezhou@gmail.com> (https://github.com/xavierchow)' ],
              bugs: { url: 'https://github.com/node-modules/mm/issues' },
              license: 'MIT',
              users: { lfeng: true },
              version: '3.2.0',
              main: 'index.js',
              scripts:
               { test: 'npm run lint && egg-bin test',
                 ci: 'npm run lint && egg-bin cov',
                 lint: 'eslint --fix lib test index.js',
                 autod: 'autod -w --prefix \'^\'' },
              dependencies:
               { 'is-type-of': '^1.2.1',
                 'ko-sleep': '^1.0.3',
                 'muk-prop': '^1.2.1',
                 thenify: '^3.3.0' },
              devDependencies:
               { autod: '^3.1.0',
                 chunkstream: '^0.0.1',
                 co: '^4.6.0',
                 'egg-bin': '^1.11.1',
                 'egg-ci': '^1.13.1',
                 enable: '^3.4.0',
                 eslint: '^6.8.0',
                 'eslint-config-egg': '^8.0.1',
                 'node-patch': '*',
                 pedding: '^1.1.0',
                 should: '^13.2.3',
                 'thunkify-wrap': '^1.0.4',
                 urllib: '^2.34.2',
                 uuid: '^3.4.0' },
              engines: { node: '>=8.0.0' },
              ci:
               { type: 'travis, azure-pipelines', version: '8, 10, 12, 13' },
              gitHead: 'fd71b21ccc554a34e93fbde8642a07c49af337d8',
              dist:
               { integrity:
                  'sha512-/VCj1KbfQHqY5YfAQZY0YVoU8QyTvFDdRnGfAQ1SzILtwgns2fl+SXiIMH+/7GW/5DEr69ffmGVP2pouUIKlaA==',
                 shasum: '509cc2477c24376f4c441229ddf8ddd3d80b5fcc',
                 tarball: 'https://registry.npmjs.org/mm/-/mm-3.2.0.tgz',
                 fileCount: 7,
                 unpackedSize: 36734,
                 'npm-signature':
                  '-----BEGIN PGP SIGNATURE-----\r\nVersion: OpenPGP.js v3.0.4\r\nComment: https://openpgpjs.org\r\n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\nX+Ww\r\n=iyb3\r\n-----END PGP SIGNATURE-----\r\n' },
              directories: {} }
            • P Offline
              pjcrux @Mykle1
              @Mykle1 Thanks I’ve changed it but still is not loading. My first initial thought was that the module hadn’t installed in the modules folder but I do see this when listing in the parent directory:
              pi@magicmirroros:~/MagicMirror/modules $ ls
              MMM-EyeCandy MMM-NetworkScanner MMM-SystemStats
                sdetweil @pjcrux
                @pjcrux I thought there was a MagicMirror OS parm that said allow override modules
                • P Offline
                  pjcrux @sdetweil
                  @sdetweil said in MMM-SystemStats and MMM-EyeCandy not initializing upon start, boot, reboot, or restart of the MM OS:
                  MagicMirror OS parm
                  If you know of what to do or what I can google please let me know when it comes to you. I’m not finding anything with my google-fu.
                    sdetweil @pjcrux
                    @pjcrux see https://gitlab.com/khassel/magicmirror
                    this covers config and module install best I can tell
                      Does it work with the default config entry?
                              maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                              style: '1',            // Style number or use ownImagePath to override style
                              ownImagePath: '',      // ex: 'modules/MMM-EyeCandy/pix/YOUR_PICTURE_NAME.jpg', or internet url to image
