    MMM-Tado
    12 Posts 7 Posters 6.4k Views 8 Watching
    • W Offline
      WouterEekhout
      Hi everyone!
      Here is a module for reading out information of your Tado Thermostat. I hope you guys like it.
      https://github.com/WouterEekhout/MMM-Tado/
      • T Offline
        toldenburger
        Can I just take a moment to thank you for writing this module?
        I love it! And it works perfectly.
        I have couple of Smart Radiator Thermostats and I can now see the set and current temperature as well as the humidity in every room. And if a room is heating up with the little flame symbol.
        Awesome!
        • W Offline
          WouterEekhout @toldenburger
          @toldenburger Thank you for the comment, I really appreciate it :)
            jasim @WouterEekhout
            @WouterEekhout Does not work after update, the screen remains black.
              sdetweil @jasim
              @jasim git pull, and then npm install
                jasim @sdetweil
                @sdetweil said in MMM-Tado:
                in the tado folder? both
                  sdetweil @jasim
                  @jasim yes
                    jasim @sdetweil
                    @sdetweil Danke, funktioniert.
                    • N Offline
                      NielHeesakkers
                      I’ve installed the Tado module and configured it but it’s not showing anything.
                      Anybody here that can help me out?
                      • F Offline
                        FlorianRD
                        Hello,
                        im just installed the module. The brigthness is a bit to much. Im looking in the MMM-Tado.js, but i didnt find the correct settings. Can you help me?
                          sdetweil @FlorianRD
                          @FlorianRD it would probably be in the case file
                          • H Offline
                            hypertraxs
                            This post is deleted!
