    2.12 repeating all day calendar events not shown for today, or weather only showing 2 days and missing analog clock numbers
    19 Posts 5 Posters 6.7k Views 5 Watching
      sdetweil
      This post is deleted!
        RIKKO14
        After do this :
        cd ~/MagicMirror/node_modules
        mv ical old_ical
        git clone https://github.com/sdetweil/ical.js.git ical
        cd ical
        npm install
        I do this :
        cd ~/MagicMirror
        rm package-lock.json
        git checkout develop
        and here is the answer :
        pi@raspberrypi:~/MagicMirror $ rm package-lock.json
        pi@raspberrypi:~/MagicMirror $ git checkout develop
        error: Vos modifications locales aux fichiers suivants seraient écrasées par l'extraction :
        	package.json
        Veuillez valider ou remiser vos modifications avant de basculer de branche.
        Abandon
        the problem is still there about repeating calendar events :
        my MM shows 2 hours ahead of google calendar
        what can I do ?
        my .ics : https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics
          sdetweil @RIKKO14
          @RIKKO14 got them out of order
          do
          cd ~/MagicMirror
          git stash
          git stash pop
            RIKKO14
            I do this but the problem sill here after a pm2 restart mm
            pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
            pi@raspberrypi:~/MagicMirror $ git stash
            *** Veuillez me dire qui vous êtes.
            Lancez
              git config --global user.email "Vous@exemple.com"
              git config --global user.name "Votre Nom"
            pour régler l'identité par défaut de votre compte.
            Éliminez --global pour ne faire les réglages que dans ce dépôt.
            fatal: impossible de détecter automatiquement l'adresse ('pi@raspberrypi.(none)' trouvé)
            Impossible de sauver l'état courant de l'index
            	package.json
            Abandon
            pi@raspberrypi:~/MagicMirror $ git stash pop
            Aucune entrée de remisage trouvée.
            pi@raspberrypi:~/MagicMirror $ pm2 restart mm
            i think these commands were not carried out
              sdetweil @RIKKO14
              @RIKKO14 ggrrrrrr
              to stash changes, git needs to know WHO did it, in case it gets forgotten. but u are not a developer registered to git
              do
              cd ~/MagicMirror
              git checkout package.json
                RIKKO14
                WHAOOOO ! it’s ok.
                thanks you much !
                • T Offline
                  torte22
                  once I switched to the ‘develop’ branch, how can I switch back to ‘master’?
                    sdetweil @torte22
                    @torte22 git checkout master
                    you will lose the fixes from develop of course
                    • N Offline
                      natrlhy
                      I’m trying to get the weather for 2 days to work. I’ve followed the steps on a new install of mm:
                      [2020-09-23 18:20:11.758] [ERROR]  Error: Cannot find module 'node-ical'
                      Require stack:
                      - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                      - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                          at Module.require (internal/modules/cjs/loader.js:685:19)
                          at require (internal/modules/cjs/helpers.js:16:16)
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                          at Module._compile (internal/modules/cjs/loader.js:786:30)
                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                          at Module.load (internal/modules/cjs/loader.js:645:32)
                      [2020-09-23 18:20:11.762] [ERROR]  Whoops! There was an uncaught exception...
                      [2020-09-23 18:20:11.763] [ERROR]  Error: Cannot find module 'node-ical'
                      Require stack:
                          at Module.load (internal/modules/cjs/loader.js:645:32) {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: [
                          '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                          '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                          '/home/pi/MagicMirror/js/app.js',
                          '/home/pi/MagicMirror/js/electron.js',
                          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                          undefined
                      [2020-09-23 18:20:11.775] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2020-09-23 18:20:11.776] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        sdetweil @natrlhy
                        @natrlhy ah, sorry, late change forgot to update instructions… we fixed calendar, but had to use a different library,
                        cd ~/MagicMirror
                        npm install
                        will be fixed on next release (Oct 1)
                        • N Offline
                          natrlhy
                          Thanks for the extra step!
                          For the life of me, it just wont load the forecast…
                                                  disabled: false,
                                                  module: "weatherforecast",
                                                  header: "Weather Forecast",
                                                          locationID: "5344157", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                                          appid: "myappid",
                                                          // maxNumberOfDays: "10",
                                                          // fade: "false"
                            sdetweil @natrlhy
                            @natrlhy open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors usually red text
                            and the console where u start mm
                            npm start
                            or
                            pm2 logs --lines=???
                            ??? is a number, default 15
                            • N Offline
                              natrlhy
                              Nothing in the dev window…
                              pm2 log (20 lines):
                              PM2        | 2020-09-23T20:08:10: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-09-23T20:08:10: PM2 log: App [MagicMirror:0] online
                              /home/pi/.pm2/logs/MagicMirror-error.log last 20 lines:
                              0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                              0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:685:19)
                              0|MagicMir |     at require (internal/modules/cjs/helpers.js:16:16)
                              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                              0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                              0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                              0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                              0|MagicMir |   code: 'MODULE_NOT_FOUND',
                              0|MagicMir |   requireStack: [
                              0|MagicMir |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                              0|MagicMir |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                              0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
                              0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
                              0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                              0|MagicMir |     undefined
                              0|MagicMir |   ]
                              0|MagicMir | }
                              0|MagicMir | [2020-09-23 18:20:11.775] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              0|MagicMir | [2020-09-23 18:20:11.776] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              /home/pi/.pm2/logs/MagicMirror-out.log last 20 lines:
                              0|MagicMir | [2020-09-23 20:08:16.677] [LOG]    Module helper loaded: updatenotification
                              0|MagicMir | [2020-09-23 20:08:16.678] [LOG]    No helper found for module: clock.
                              0|MagicMir | [2020-09-23 20:08:16.680] [LOG]    No helper found for module: currentweather.
                              0|MagicMir | [2020-09-23 20:08:16.682] [LOG]    No helper found for module: weatherforecast.
                              0|MagicMir | [2020-09-23 20:08:17.796] [LOG]    Initializing new module helper ...
                              0|MagicMir | [2020-09-23 20:08:17.797] [LOG]    Module helper loaded: newsfeed
                              0|MagicMir | [2020-09-23 20:08:17.798] [LOG]    All module helpers loaded.
                              0|MagicMir | [2020-09-23 20:08:18.142] [LOG]    Starting server on port 8080 ...
                              0|MagicMir | [2020-09-23 20:08:18.161] [LOG]    Server started ...
                              0|MagicMir | [2020-09-23 20:08:18.162] [LOG]    Connecting socket for: updatenotification
                              0|MagicMir | [2020-09-23 20:08:18.164] [LOG]    Connecting socket for: newsfeed
                              0|MagicMir | [2020-09-23 20:08:18.165] [LOG]    Starting node helper for: newsfeed
                              0|MagicMir | [2020-09-23 20:08:18.166] [LOG]    Sockets connected & modules started ...
                              0|MagicMir | [2020-09-23 20:08:18.476] [LOG]    Launching application.
                              0|MagicMir | [2020-09-23 20:08:22.215] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                              0|MagicMir | [2020-09-23 20:08:23.231] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
                              0|MagicMir | [2020-09-23 20:08:29.750] [LOG]    Use existing news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml
                              0|MagicMir | [2020-09-23 20:08:29.751] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
                              0|MagicMir | [2020-09-23 20:08:30.224] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
                              0|MagicMir | [2020-09-23 20:13:30.985] [INFO]   Newsfeed-Fetcher: Broadcasting 59 items.
                              S N 2 Replies Last reply Reply Quote 0
                                sdetweil @natrlhy
                                @natrlhy u need to do
                                cd ~/MagicMirror
                                npm install
                                because u switched to the develop branch which has a new required library
                                • N Offline
                                  natrlhy @natrlhy
                                  After I switched to the develop branch, I did cd ~/MagicMirror and ran npm install.
                                  I refreshed my MM window with inspector and did see this:
                                  Yet currentweather loads fine with the same appid key…
                                    sdetweil @natrlhy
                                    @natrlhy well there is a 401 error on openweather, and a module not found for calendar…
                                    • N Offline
                                      natrlhy
                                      pi@teslamate:~/MagicMirror $ npm install
                                      > magicmirror@2.13.0-develop install /home/pi/MagicMirror
                                      > echo "Installing vendor files ...
                                      " && cd vendor && npm install --loglevel=error
                                      audited 24 packages in 2.71s
                                      1 package is looking for funding
                                        run `npm fund` for details
                                      found 0 vulnerabilities
                                      > magicmirror@2.13.0-develop postinstall /home/pi/MagicMirror
                                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                      > magicmirror@2.13.0-develop install-fonts /home/pi/MagicMirror
                                      > echo "Installing fonts ...
                                      " && cd fonts && npm install --loglevel=error
                                      audited 1 package in 0.981s
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                      audited 1124 packages in 60.578s
                                      87 packages are looking for funding
                                      found 3 low severity vulnerabilities
                                        run `npm audit fix` to fix them, or `npm audit` for details
                                      • N Offline
                                        natrlhy
                                        Ok thanks for bearing with me :)
                                        I started from scratch again. Generated a new API key from openweathermap, made my changes to the config.js config file. Waited a while since inspector was showing my API was invalid since it was newly generated…
                                        Thanks for the help!
                                          jani.karna
                                          So I have Calendar to show two upcoming birthdays. It is showing them one day too early. Is it the same problem as mentioned earlier? And will the same fix fix them for me?
