    trying to setup a DHT22/am2302 not getting readings
    5 Posts 3 Posters 1.1k Views 3 Watching
      spoonbe
      well i’m trying to get my Sensor to work but can’t seem to figure out what i’m doing wrong.
      I’m pretty new to all of this
      the Mirror is setup and working fine
      added a Sr501 PIR sensor and that one is working fine, so wiring up the Temp Sensor should be right
      but this sensor is giving me some trouble. I think that i ran through all the installation steps
      some modules give me errors and the mirror won’t load at all showing on top electron
      Some modules show up on the mirror but don’t give me readings
      i’m a bit lost at this point.
      these are the ones i tried
      https://github.com/Bangee44/MMM-DHT22
      https://github.com/bernardpletikosa/MMM-DHT-Sensor
      https://github.com/nebulx29/MMM-dht22
      https://github.com/glitch452/MMM-LocalTemperature
      could really use some help
      • BKeyportB
        BKeyport Module Developer @spoonbe
        @spoonbe have you tried using the sensor with another program or service to see if it’s the problem?
        https://pimylifeup.com/raspberry-pi-humidity-sensor-dht22/ for example.
          spoonbe @BKeyport
          @BKeyport i’ll have a look at that
          • FoziF
            Fozi Project Sponsor
            You need to put a 10k pull-up resistor between The GND and data for the DHT11. The AM2302 is identical to the DHT11, but is shipped on a small PCB, which already has the resistor included.
            • BKeyportB
              BKeyport Module Developer @Fozi
              @Fozi I wonder if that’s why I’m having problems getting readings from time to time. I’ve got a DHT on a board, but I don’t think it’s got anything other than direct wiring to the pins you solder to.
