    config google assistant
    10 Posts 5 Posters 1.3k Views 5 Watching
      raf
      can anyone post an example of the config.js to configure my google assistant, when I call jarvis it appears but otherwise nothing happens,
      do I have to put something separately in the config file for each event?
      this is my config:
      	  module: "MMM-GoogleAssistant",
      	  position: "top_bar",
      		assistantConfig: {
      		  latitude: 51.3893229,
      		  longitude: -4.5900218,
      		  micConfig: { // put there configuration generated by auto-installer
      		  recorder: "arecord",
      		  device: "plughw:2",
      what else should I insert
        JohnBachini
        What is supposed to happen ?, ie what are you asking it that it isnt doing…
          raf
          @JohnBachini said in config google assistant:
          here is an example
          https://youtu.be/OZYetwbCkuM
            raf
            there is always a text with: I don’t understand you
              sdetweil @raf
              @raf his video shows no text response
                raf
                yes he does show text but it is difficult to see on the video, he shows: I do not understand you and he only gives text and no speech
                i will try to make a new video tomorrow which is more clear
                • ? Offline
                  A Former User @raf
                  @raf :
                  I see 2 reasons for this
                  1. You have another Mic application using by another module
                    in this case it’s the Mic Fight GA win the first time (detector: jarvis) and lost the second time (listening the question)
                  2. Credentials and/or token is not correct (something missing in google setup part or bad Credentials download)
                    Google return an error and close the conversation
                  • W Offline
                    WendyColbert
                    I tried to install an assistant on my site, but it’s not possible through the admin panel. I ordered the service from the programmers, they did it quickly. Now I use an assistant.
                    W 1 Reply Last reply Reply Quote -1
                    • W Offline
                      WendyColbert @WendyColbert
                      @WendyColbert said in config google assistant:
                      I tried to install an assistant on my site, but it’s not possible through the admin panel. I ordered the service from the programmers, they did it quickly. Now I use an assistant here.
                      All changes are made in the site code, so it is better to entrust the work to professionals.
                      S 1 Reply Last reply Reply Quote -1
                        sdetweil @WendyColbert
                        @WendyColbert this looks like a garbage post (your two)… what does ‘site’ mean? and who are the ‘professionals’
                        we are all volunteer here, and no one is available (generally) work for hire…
