    Is it possible to ad an Arduino?
    55 Posts 4 Posters 20.8k Views 4 Watching
      Shinji0912 @sdetweil
      This post is deleted!
        Ok so like i said it starts now , but the ArduPorts module still says : “waiting for connection”
        and i added the
        debug: true,
        line. And for some reason Ctrl + shift + i does nothing for me except that the radeon software takes a screenshot… so heres the full console log :
        pi@raspberrypi:~/MagicMirror $ npm run start
        > magicmirror@2.12.0 start /home/pi/MagicMirror
        [2020-09-18 18:12:43.751] [LOG]    Starting MagicMirror: v2.12.0
        [2020-09-18 18:12:43.764] [LOG]    Loading config ...
        [2020-09-18 18:12:43.776] [LOG]    Loading module helpers ...
        [2020-09-18 18:12:43.801] [LOG]    Initializing new module helper ...
        [2020-09-18 18:12:43.802] [LOG]    Module helper loaded: MMM-ArduPort
        node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
        In the future, you will have to enable it yourself.
        See https://github.com/yagop/node-telegram-bot-api/issues/319. internal/modules/cjs/loader.js:786:30
        [2020-09-18 18:12:45.439] [LOG]    Initializing new module helper ...
        [2020-09-18 18:12:45.440] [LOG]    Module helper loaded: MMM-TelegramBot
        [2020-09-18 18:12:45.442] [LOG]    No helper found for module: MMM-Online-State.
        [2020-09-18 18:12:45.519] [LOG]    Initializing new module helper ...
        [2020-09-18 18:12:45.520] [LOG]    Module helper loaded: updatenotification
        [2020-09-18 18:12:45.521] [LOG]    No helper found for module: clock.
        [2020-09-18 18:12:45.698] [LOG]    Initializing new module helper ...
        [2020-09-18 18:12:45.700] [LOG]    Module helper loaded: MMM-RBB-Weather
        [2020-09-18 18:12:46.359] [LOG]    Initializing new module helper ...
        [2020-09-18 18:12:46.360] [LOG]    Module helper loaded: calendar
        [2020-09-18 18:12:47.125] [LOG]    Initializing new module helper ...
        [2020-09-18 18:12:47.126] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
        [2020-09-18 18:12:47.126] [LOG]    All module helpers loaded.
        [2020-09-18 18:12:47.336] [LOG]    Starting server on port 8080 ...
        [2020-09-18 18:12:47.362] [LOG]    Server started ...
        [2020-09-18 18:12:47.364] [LOG]    Connecting socket for: MMM-ArduPort
        [2020-09-18 18:12:47.365] [LOG]    [MMM-ArduPort]:: Starting node_helper for module [MMM-ArduPort]
        [2020-09-18 18:12:47.366] [LOG]    Connecting socket for: MMM-TelegramBot
        [2020-09-18 18:12:47.367] [LOG]    Connecting socket for: updatenotification
        [2020-09-18 18:12:47.369] [LOG]    Connecting socket for: MMM-RBB-Weather
        [2020-09-18 18:12:47.369] [LOG]    Starting module helper: MMM-RBB-Weather
        [2020-09-18 18:12:47.371] [LOG]    Connecting socket for: calendar
        [2020-09-18 18:12:47.371] [LOG]    Starting node helper for: calendar
        [2020-09-18 18:12:47.372] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
        [2020-09-18 18:12:47.373] [LOG]    Sockets connected & modules started ...
        [2020-09-18 18:12:47.553] [LOG]    Launching application.
        [2020-09-18 18:12:50.879] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
        [2020-09-18 18:12:51.091] [LOG]    MMM-RBB-Weather[18.9.2020, 18:12:50]: Load data for ID "18228265" and "0" days ...
        [2020-09-18 18:12:51.100] [INFO]   Checking git for module: MMM-ArduPort
        [2020-09-18 18:12:51.132] [INFO]   Checking git for module: MMM-TelegramBot
        [2020-09-18 18:12:51.168] [INFO]   Checking git for module: MMM-Online-State
        [2020-09-18 18:12:51.209] [INFO]   Checking git for module: MMM-RBB-Weather
        [2020-09-18 18:12:51.246] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
        [2020-09-18 18:12:51.281] [ERROR]  (node:1451) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
        [2020-09-18 18:12:51.283] [ERROR]  (node:1451) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
        [2020-09-18 18:12:51.420] [LOG]    MMM-RBB-Weather[18.9.2020, 18:12:51]: Fetch data for day "0" ...
        [2020-09-18 18:12:51.446] [LOG]    { debug: 'SerialPort shell started...' }
        [2020-09-18 18:12:51.458] [LOG]    undefined[MMM-ArduPort] SerialPort shell started...
        [2020-09-18 18:12:51.459] [LOG]    { debug: 'Waiting Ardunio to connect on port...' }
        [2020-09-18 18:12:51.460] [LOG]    undefined[MMM-ArduPort] Waiting Ardunio to connect on port...
        [2020-09-18 18:12:51.461] [LOG]    { status: { name: 'connect', data: 'connected' } }
        [2020-09-18 18:12:51.462] [LOG]    { name: 'connect', data: 'connected' }
        [2020-09-18 18:12:51.484] [ERROR]  Whoops! There was an uncaught exception...
        [2020-09-18 18:12:51.485] [ERROR]  SyntaxError: Unexpected token E in JSON at position 0
           at JSON.parse (<anonymous>)
           at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:381:21)
           at /home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:323:42
           at Array.forEach (<anonymous>)
           at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:319:15)
           at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-ArduPort/node_modules/python-shell/index.js:303:21)
           at Socket.emit (events.js:205:15)
           at addChunk (_stream_readable.js:294:12)
           at readableAddChunk (_stream_readable.js:271:13)
           at Socket.Readable.push (_stream_readable.js:210:10)
           at Pipe.onStreamRead (internal/stream_base_commons.js:166:17)
        [2020-09-18 18:12:51.494] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-09-18 18:12:51.495] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-09-18 18:12:51.515] [LOG]    [MMM-ArduPort] finished running...
        [2020-09-18 18:12:52.033] [LOG]    Refreshed access token because it has expired. Expired at: 18:12:50 now is: 18:12:52
        [2020-09-18 18:12:52.074] [LOG]    Refreshed access token because it has expired. Expired at: 19:12:52 now is: 18:12:52
        [2020-09-18 18:12:52.241] [LOG]    MMM-RBB-Weather[18.9.2020, 18:12:52]: Data received, send to module ...
        [2020-09-18 18:12:52.420] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
        [2020-09-18 18:13:14.146] [LOG]    Shutting down server...
        [2020-09-18 18:13:14.149] [LOG]    Stopping module helper: MMM-ArduPort
        [2020-09-18 18:13:14.150] [LOG]    Stopping module helper: MMM-TelegramBot
        [2020-09-18 18:13:14.152] [LOG]    Stopping module helper: updatenotification
        [2020-09-18 18:13:14.153] [LOG]    Stopping module helper: MMM-RBB-Weather
        [2020-09-18 18:13:14.155] [LOG]    Stopping module helper: calendar
        [2020-09-18 18:13:14.157] [LOG]    Stopping module helper: MMM-NowPlayingOnSpotify
        EDIT:
        Seems like it can’t find the Arduino but via NodeRed i can see it is sending Informations which the Pi is able to read.
          sdetweil @Shinji0912
          @Shinji0912 it found the Arduino and then died when the data arrived on wrong format
            @sdetweil Ok … so is it the Arduino sketch that is the problem and if yes what should i change?
              @Shinji0912 says json.parse failed. are u sending json formatted data as required?
                @sdetweil Im not sure about that …
                Like i said im a reallyyy bloody newbie… sry :C
                #include
                #include "DHT.h"
                #define DHTPIN 2
                #define DHTTYPE 11
                DHT dht (DHTPIN, DHTTYPE);
                void setup()
                  Wire.begin();
                  Serial.begin(9600);
                  dht.begin();
                void loop()
                  delay(2000);
                  float temp = dht.readTemperature();
                  float rel_hum = dht.readHumidity();
                  if (isnan(rel_hum) || isnan(temp)) {
                    Serial.println(F("Daten vom Sensor konnten nicht gelesen werden!"));
                    return;
                  float hif = dht.computeHeatIndex(rel_hum);
                  float hic = dht.computeHeatIndex(temp, rel_hum, false);
                  Serial.print(F("Luftfeuchtigkeit: "));
                  Serial.print(rel_hum);
                  Serial.print(F("%  Temperatur: "));
                  Serial.print(temp);
                  Serial.print(F("°C "));
                  Serial.println(F(""));
                this is the arduino code
                When i tried to rewrite the given code by ArduPorts it didn’t even showed me the temperature in the SerialMonitor this was the sketch ;
                volatile int32_t m_counter = 0;
                bool WasStarted = false;
                static const char *pcDHT11Prefix = "[sensor:DHT11:";
                static const char *pcPostfix = "]";
                void setup() {
                  Serial.begin(9600);
                  while(!Serial);
                  Serial.println("[status:setup:starting]");
                  Serial.println("[sensor:DHT11:11]");
                  int test = 1;
                  m_counter = test;
                  if(test > 1) {
                    WasStarted = false;
                    Serial.println("[status:setup:failed]");
                    return;
                  delay(3000);
                  WasStarted = true;
                  Serial.println("[status:setup:started]");
                  delay(100);
                void loop() {
                  Serial.print(m_counter + 11);
                  Serial.println(pcPostfix);
                  if(m_counter % 3 == 0) {
                    delay(1000);
                    Serial.print(pcDHT11Prefix);
                    delay(2000);
                  if(m_counter >= 60) m_counter = 0;
                  m_counter++;
                  delay(1000);
                EDIT 2 :
                This is what the Arduino SerialOutput looks like in NoteRed
                ( using the Rewritten ArduPorts Sketch)
                alt text
                  @Shinji0912 use one of the online json validators to check your messages
                    @sdetweil alt text
                    alt text
                      @Shinji0912 only what u send(println) not the whole sketch
                      json, all text strings must be in double quotes
                      Serial.print(pcMQ2Prefix);
                      Serial.print(m_counter);
                      sample shows sketch sending sensor info
                        @sdetweil U mean like this?
                           Serial.println("pcPostfix)"
                           "Serial.println(""[status:setup:starting]"")"
                           "Serial.println(""[sensor:DHT11:11]"")"
                           "Serial.println(""[status:setup:failed]"")"
                        • 6
                        • 4 / 6
