    Is it possible to ad an Arduino?
    55 Posts 4 Posters 18.0k Views 4 Watching
      Shinji0912 @sdetweil
      @sdetweil Just tried it but it’s not working … now the “waiting for connection” or starting arduports isn’t even displayed on the MagicMirror anymore
      and the console log changed from :
      pi@raspberrypi:~/MagicMirror $ npm run start
      > magicmirror@2.12.0 start /home/pi/MagicMirror
      [2020-09-24 15:48:02.396] [LOG]    Starting MagicMirror: v2.12.0
      [2020-09-24 15:48:02.409] [LOG]    Loading config ...
      [2020-09-24 15:48:02.421] [LOG]    Loading module helpers ...
      [2020-09-24 15:48:02.444] [LOG]    Initializing new module helper ...
      [2020-09-24 15:48:02.445] [LOG]    Module helper loaded: MMM-ArduPort
      node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
      In the future, you will have to enable it yourself.
      See https://github.com/yagop/node-telegram-bot-api/issues/319. internal/modules/cjs/loader.js:786:30
      [2020-09-24 15:48:04.024] [LOG]    Initializing new module helper ...
      [2020-09-24 15:48:04.025] [LOG]    Module helper loaded: MMM-TelegramBot
      [2020-09-24 15:48:04.027] [LOG]    No helper found for module: MMM-Online-State.
      [2020-09-24 15:48:04.097] [LOG]    Initializing new module helper ...
      [2020-09-24 15:48:04.098] [LOG]    Module helper loaded: updatenotification
      [2020-09-24 15:48:04.100] [LOG]    No helper found for module: clock.
      [2020-09-24 15:48:04.259] [LOG]    Initializing new module helper ...
      [2020-09-24 15:48:04.260] [LOG]    Module helper loaded: MMM-RBB-Weather
      [2020-09-24 15:48:04.904] [LOG]    Initializing new module helper ...
      [2020-09-24 15:48:04.905] [LOG]    Module helper loaded: calendar
      [2020-09-24 15:48:05.663] [LOG]    Initializing new module helper ...
      [2020-09-24 15:48:05.664] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
      [2020-09-24 15:48:05.664] [LOG]    All module helpers loaded.
      [2020-09-24 15:48:05.869] [LOG]    Starting server on port 8080 ...
      [2020-09-24 15:48:05.894] [LOG]    Server started ...
      [2020-09-24 15:48:05.895] [LOG]    Connecting socket for: MMM-ArduPort
      [2020-09-24 15:48:05.897] [LOG]    [MMM-ArduPort]:: Starting node_helper for module [MMM-ArduPort]
      [2020-09-24 15:48:05.898] [LOG]    Connecting socket for: MMM-TelegramBot
      [2020-09-24 15:48:05.899] [LOG]    Connecting socket for: updatenotification
      [2020-09-24 15:48:05.901] [LOG]    Connecting socket for: MMM-RBB-Weather
      [2020-09-24 15:48:05.902] [LOG]    Starting module helper: MMM-RBB-Weather
      [2020-09-24 15:48:05.902] [LOG]    Connecting socket for: calendar
      [2020-09-24 15:48:05.903] [LOG]    Starting node helper for: calendar
      [2020-09-24 15:48:05.904] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
      [2020-09-24 15:48:05.905] [LOG]    Sockets connected & modules started ...
      [2020-09-24 15:48:06.097] [LOG]    Launching application.
      [2020-09-24 15:48:09.747] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
      [2020-09-24 15:48:09.956] [LOG]    MMM-RBB-Weather[24.9.2020, 15:48:09]: Load data for ID "18228265" and "0" days ...
      [2020-09-24 15:48:09.970] [INFO]   Checking git for module: MMM-ArduPort
      [2020-09-24 15:48:10.014] [INFO]   Checking git for module: MMM-TelegramBot
      [2020-09-24 15:48:10.057] [INFO]   Checking git for module: MMM-Online-State
      [2020-09-24 15:48:10.104] [INFO]   Checking git for module: MMM-RBB-Weather
      [2020-09-24 15:48:10.148] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
      [2020-09-24 15:48:10.201] [ERROR]  (node:1251) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-09-24 15:48:10.209] [ERROR]  (node:1251) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-09-24 15:48:10.357] [LOG]    MMM-RBB-Weather[24.9.2020, 15:48:10]: Fetch data for day "0" ...
      [2020-09-24 15:48:10.397] [LOG]    { debug: 'SerialPort shell started...' }
      [2020-09-24 15:48:10.408] [LOG]    undefined[MMM-ArduPort] SerialPort shell started...
      [2020-09-24 15:48:10.410] [LOG]    { debug: 'Waiting Ardunio to connect on port...' }
      [2020-09-24 15:48:10.411] [LOG]    undefined[MMM-ArduPort] Waiting Ardunio to connect on port...
      [2020-09-24 15:48:10.413] [LOG]    { status: { name: 'connect', data: 'connected' } }
      [2020-09-24 15:48:10.416] [LOG]    { name: 'connect', data: 'connected' }
      [2020-09-24 15:48:11.002] [LOG]    Refreshed access token because it has expired. Expired at: 15:48:09 now is: 15:48:11
      [2020-09-24 15:48:11.093] [LOG]    Refreshed access token because it has expired. Expired at: 16:48:11 now is: 15:48:11
      [2020-09-24 15:48:11.189] [LOG]    MMM-RBB-Weather[24.9.2020, 15:48:11]: Data received, send to module ...
      [2020-09-24 15:48:11.328] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
      [2020-09-24 15:48:12.086] [LOG]    { status: { name: 'setup', data: 'starting' } }
      [2020-09-24 15:48:12.093] [LOG]    { name: 'setup', data: 'starting' }
      [2020-09-24 15:48:12.187] [LOG]    { status: { name: 'setup', data: 'started' } }
      [2020-09-24 15:48:12.189] [LOG]    { name: 'setup', data: 'started' }
      [2020-09-24 15:48:12.258] [LOG]    { sensor: { name: 'DHT11', data: '0' } }
      to this :
      [2020-09-24 15:52:40.905] [LOG]    Starting MagicMirror: v2.12.0
      [2020-09-24 15:52:40.918] [LOG]    Loading config ...
      [2020-09-24 15:52:40.930] [LOG]    Loading module helpers ...
      [2020-09-24 15:52:40.953] [LOG]    Initializing new module helper ...
      [2020-09-24 15:52:40.954] [LOG]    Module helper loaded: MMM-ArduPort
      [2020-09-24 15:52:42.568] [LOG]    Initializing new module helper ...
      [2020-09-24 15:52:42.569] [LOG]    Module helper loaded: MMM-TelegramBot
      [2020-09-24 15:52:42.571] [LOG]    No helper found for module: MMM-Online-State.
      [2020-09-24 15:52:42.641] [LOG]    Initializing new module helper ...
      [2020-09-24 15:52:42.642] [LOG]    Module helper loaded: updatenotification
      [2020-09-24 15:52:42.644] [LOG]    No helper found for module: clock.
      [2020-09-24 15:52:42.801] [LOG]    Initializing new module helper ...
      [2020-09-24 15:52:42.802] [LOG]    Module helper loaded: MMM-RBB-Weather
      [2020-09-24 15:52:43.439] [LOG]    Initializing new module helper ...
      [2020-09-24 15:52:43.440] [LOG]    Module helper loaded: calendar
      [2020-09-24 15:52:44.199] [LOG]    Initializing new module helper ...
      [2020-09-24 15:52:44.200] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
      [2020-09-24 15:52:44.201] [LOG]    All module helpers loaded.
      [2020-09-24 15:52:44.413] [LOG]    Starting server on port 8080 ...
      [2020-09-24 15:52:44.436] [LOG]    Server started ...
      [2020-09-24 15:52:44.438] [LOG]    Connecting socket for: MMM-ArduPort
      [2020-09-24 15:52:44.439] [LOG]    [MMM-ArduPort]:: Starting node_helper for module [MMM-ArduPort]
      [2020-09-24 15:52:44.440] [LOG]    Connecting socket for: MMM-TelegramBot
      [2020-09-24 15:52:44.442] [LOG]    Connecting socket for: updatenotification
      [2020-09-24 15:52:44.443] [LOG]    Connecting socket for: MMM-RBB-Weather
      [2020-09-24 15:52:44.444] [LOG]    Starting module helper: MMM-RBB-Weather
      [2020-09-24 15:52:44.445] [LOG]    Connecting socket for: calendar
      [2020-09-24 15:52:44.446] [LOG]    Starting node helper for: calendar
      [2020-09-24 15:52:44.447] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
      [2020-09-24 15:52:44.448] [LOG]    Sockets connected & modules started ...
      [2020-09-24 15:52:44.620] [LOG]    Launching application.
      [2020-09-24 15:52:48.090] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
      [2020-09-24 15:52:48.288] [LOG]    MMM-RBB-Weather[24.9.2020, 15:52:48]: Load data for ID "18228265" and "0" days ...
      [2020-09-24 15:52:48.296] [INFO]   Checking git for module: MMM-TelegramBot
      [2020-09-24 15:52:48.333] [INFO]   Checking git for module: MMM-Online-State
      [2020-09-24 15:52:48.367] [INFO]   Checking git for module: MMM-RBB-Weather
      [2020-09-24 15:52:48.398] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
      [2020-09-24 15:52:48.431] [ERROR]  (node:1440) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-09-24 15:52:48.433] [ERROR]  (node:1440) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-09-24 15:52:48.460] [LOG]    MMM-RBB-Weather[24.9.2020, 15:52:48]: Fetch data for day "0" ...
      [2020-09-24 15:52:48.818] [LOG]    Refreshed access token because it has expired. Expired at: 15:52:48 now is: 15:52:48
      [2020-09-24 15:52:49.005] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
      [2020-09-24 15:52:49.077] [LOG]    MMM-RBB-Weather[24.9.2020, 15:52:49]: Data received, send to module ...
      [2020-09-24 15:52:49.107] [LOG]    Refreshed access token because it has expired. Expired at: 16:52:48 now is: 15:52:49
      [2020-09-24 15:53:56.041] [LOG]    Shutting down server...
      [2020-09-24 15:53:56.043] [LOG]    Stopping module helper: MMM-ArduPort
      [2020-09-24 15:53:56.045] [LOG]    Stopping module helper: MMM-TelegramBot
      [2020-09-24 15:53:56.046] [LOG]    Stopping module helper: updatenotification
      after doing what they told in the issue topic from the ArduPort Git
        sdetweil @Shinji0912
        @Shinji0912 sorry, have no idea… not my module and cannot build matching system here
          @sdetweil Sad, but thank you soo much for kind of wasting your time trying to help me ^^
          • C Offline
            Crime @Shinji0912
            @Shinji0912 just got the “arduport” to show the data correctly! advice helped me @sdetweil
            I connect via VNC.
            have to set developerMode:true in the module config.js section
            call the developer window by clicking on the keyboard ctrl+shift+i
            I saw my mistake. function “formatValue” doesn’t work.
            the following solution helped
            https://github.com/Dentrax/MMM-ArduPort/issues/3
              Shinji0912 @Crime
              @Crime I already tried to fix it like that but sadly i didn’t worked… now i don’t know what to do and i don’t have the knowledge to fix it myself atm atleast .-.
              • 6
              • 6 / 6
