    Is it possible to ad an Arduino?
    55 Posts 4 Posters 21.2k Views 4 Watching
      sdetweil @Shinji0912
      @Shinji0912 see prior post
        Shinji0912 @sdetweil
        @sdetweil alt text
        Edit : Im really sorry for my Stupidity normally im a really quick learner and i understand things pretty fast but i got kind off lost at this point… but im sooo thankful for your help in general without you i wouldn’t even been able to get the right SerialPort name…soo thank u soo much so far ^^ and sry for using your time , but i wouldn’t ask if i could do it myself :/
          @Shinji0912 you can only send the sensor values in the sketch loop() function,
          the rest is is used for getting connected to the matching code in the python script
          they do
          arduino, hey, are u there?
          python script, yes, ready for sensor values
          arduino, once a second, or whatever frequency
          hey, here is sensor:???:value
            @sdetweil Ok , so based on that i have rewritten my whole Script and added just a few comments so maybe you will understand my thoughts about it…
            #include <dht_nonblocking.h>
            #include <Wire.h>
            #define DHT_SENSOR_TYPE DHT_TYPE_11
            static const char DHT_SENSOR_PIN = 2;
            DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
            void setup() {
              Wire.begin();
              Serial.begin(9600);
            //Verbindung zum Raspberry aufbauen
            // Connect to the Raspberry start ArduPort connection
              Serial.println("[status:setup:starting]");
              Serial.println("[status:setup:started]");
            // Messungen Definieren
            //Define Measurment Names
              static bool messung_t( float *temperatur, float *feuchtigkeit)
                static unsigned long messung_t = millis( );
                  if( millis( ) - messung_t > 3000ul )
                      if( dht_sensor.measure( temperatur, feuchtigkeit ) == true)
                        return( true );
                        return ( false );
            void loop() {
             //Übermitteln der Daten an ArduPorts
             //sending informations to ArduPorts
              float temperatur;
              float feuchtigkeit;
                Serial.print( "[sensor:DHT11:" );
                Serial.print(temperatur, 1 );
                Serial.println("]");
                delay(2000);
            I thought it is going to work this time but on the mirror it is still : “waiting for connection”
            but my Console log when starting the mirror shows me that the ArduPorts reads the Temperature (because a slightly mistake (but should still work) the Temperature is always 0.0)
            Console Log :
            [2020-09-22 16:24:17.982] [LOG]    Launching application.
            [2020-09-22 16:24:21.437] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/oliver.kuck12%40gmail.com/public/basic.ics - Interval: 300000
            [2020-09-22 16:24:21.624] [LOG]    MMM-RBB-Weather[22.9.2020, 16:24:21]: Load data for ID "18228265" and "0" days ...
            [2020-09-22 16:24:21.633] [INFO]   Checking git for module: MMM-ArduPort
            [2020-09-22 16:24:21.665] [INFO]   Checking git for module: MMM-TelegramBot
            [2020-09-22 16:24:21.700] [INFO]   Checking git for module: MMM-Online-State
            [2020-09-22 16:24:21.733] [INFO]   Checking git for module: MMM-RBB-Weather
            [2020-09-22 16:24:21.772] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
            [2020-09-22 16:24:21.810] [ERROR]  (node:1379) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            [2020-09-22 16:24:21.812] [ERROR]  (node:1379) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            [2020-09-22 16:24:21.956] [LOG]    MMM-RBB-Weather[22.9.2020, 16:24:21]: Fetch data for day "0" ...
            [2020-09-22 16:24:21.999] [LOG]    { debug: 'SerialPort shell started...' }
            [2020-09-22 16:24:22.014] [LOG]    undefined[MMM-ArduPort] SerialPort shell started...
            [2020-09-22 16:24:22.016] [LOG]    { debug: 'Waiting Ardunio to connect on port...' }
            [2020-09-22 16:24:22.018] [LOG]    undefined[MMM-ArduPort] Waiting Ardunio to connect on port...
            [2020-09-22 16:24:22.019] [LOG]    { status: { name: 'connect', data: 'connected' } }
            [2020-09-22 16:24:22.020] [LOG]    { name: 'connect', data: 'connected' }
            [2020-09-22 16:24:22.026] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:22.031] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:22.359] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:22.363] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:22.731] [LOG]    Refreshed access token because it has expired. Expired at: 16:24:21 now is: 16:24:22
            [2020-09-22 16:24:22.768] [LOG]    Refreshed access token because it has expired. Expired at: 17:24:22 now is: 16:24:22
            [2020-09-22 16:24:22.870] [LOG]    MMM-RBB-Weather[22.9.2020, 16:24:22]: Data received, send to module ...
            [2020-09-22 16:24:23.104] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
            [2020-09-22 16:24:23.341] [LOG]    { status: { name: 'setup', data: 'starting' } }
            [2020-09-22 16:24:23.348] [LOG]    { name: 'setup', data: 'starting' }
            [2020-09-22 16:24:23.723] [LOG]    { status: { name: 'setup', data: 'started' } }
            [2020-09-22 16:24:23.727] [LOG]    { name: 'setup', data: 'started' }
            [2020-09-22 16:24:23.731] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:25.345] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:27.353] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:29.363] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:31.374] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
            [2020-09-22 16:24:33.383] [LOG]    { sensor: { name: 'DHT11', data: '0.0' } }
              @Shinji0912 ok, now we need to see the log from the browser
              ctrl-shift-i on the mirror keyboard, select the tab labeled console, and then put port in the filter field
              also set
              developerMode:true,
              in the config.js config section for the arduport module
              there are a lot of messages available from the modulename.js
                @sdetweil alt text
                and
                alt text
                  @Shinji0912 not acm0 in filter,
                  module name part
                  ardu
                    @sdetweil Oh okay
                    alt text
                    alt text
                    alt text
                    alt text
                      @Shinji0912 others appear to have had the same problem, see the changes suggested here
                      https://github.com/Dentrax/MMM-ArduPort/issues/3
                        @sdetweil Ok, i will try when back @home
                        • 6
                        • 5 / 6
