    MMM-Bring errors, not working
    3 Posts 2 Posters 874 Views 2 Watching
      secdude
      Hi folks,
      anyone recently seen this error with MMM-Bring?
      [2020-09-24 13:11:39.995] [ERROR]  (node:1166) UnhandledPromiseRejectionWarning: Error: Request failed with status code 404
          at createError (/home/pi/mm_prod/MagicMirror/modules/MMM-Bring/node_modules/axios/lib/core/createError.js:16:15)
          at settle (/home/pi/mm_prod/MagicMirror/modules/MMM-Bring/node_modules/axios/lib/core/settle.js:17:12)
          at IncomingMessage.handleStreamEnd (/home/pi/mm_prod/MagicMirror/modules/MMM-Bring/node_modules/axios/lib/adapters/http.js:237:11)
          at IncomingMessage.emit (events.js:205:15)
          at endReadableNT (_stream_readable.js:1154:12)
          at processTicksAndRejections (internal/process/task_queues.js:84:9)
      [2020-09-24 13:11:39.997] [ERROR]  (node:1166) UnhandledPromiseRejectionWarning: Error: Request failed with status code 404
      [2020-09-24 13:11:40.000] [ERROR]  (node:1166) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4)
      [2020-09-24 13:11:40.002] [ERROR]  (node:1166) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4)
      Thanks & regards,
      secdude
        secdude
        Solution: This is what it looks like if you provide a non-existing list name…:man_facepalming:
        Reply Quote 1
        • lavolp3L
          lavolp3 Module Developer
          @secdude ok thanks for clarifying.
          Still this promise rejection should be handled.
          I would send an issue on github.
          Unhandled promise rejections are not nice and rather easy to avoid.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
