    new tutorial credentials / api
    6 Posts 2 Posters 869 Views 2 Watching
      raf
      I have seen that the procedure to create an api (credentials) has changed at google, is there sometimes someone who has or can make a tutorial about this
        sdetweil @raf
        @raf do u mean for the GoogleAssistant module?? the problem with tutorials is they never last… someone has to maintain them, and no one does…
        there are at LEAST 10 tutorials on how to install MM… but the best way is to use the automated script…
          raf
          yes that’s what i mean, i would like to make an api / credentials for the google assistant but i don’t understand the procedure anymore (and what do you mean by the automtsche script)
          like this one but this no longer corresponds to the way it works now :https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Google-Assistant-Setup
            sdetweil @raf
            @raf the MM documentation lists alternative install approaches,
            https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
            one of those is my scripts (which were part of the base, but removed to allow me to update them frequently)
              sdetweil @raf
              @raf @Bugsounet did they change the setup process as well as the content??
                raf
                yes the procedure at google has changed
                try creating a new one as described in the wiki and you will see that the steps will be different
                from this step it changes APIs & Services > OAuth Consent Screen
