    V2.13.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 1.6k Views 1 Watching
    • MichMichM
      MichMich
      [2.13.0] - 2020-10-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.13.0
      Special thanks to the following contributors: @bryanzzhu, @bugsounet, @chamakura, @cjbrunner, @easyas314, @larryare, @oemel09, @rejas, @sdetweil & @sthuber90.
      ℹ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install.
      Added
      • --dry-run option adde in fetch call within updatenotification node_helper. This is to prevent
        MagicMirror from consuming any fetch result. Causes conflict with MMPM when attempting to check
        for updates to MagicMirror and/or MagicMirror modules.
      • Test coverage with Istanbul, run it with npm run test:coverage.
      • Add lithuanian language.
      • Added support in weatherforecast for OpenWeather onecall API.
      • Added config option to calendar-icons for recurring- and fullday-events.
      • Added current, hourly (max 48), and daily (max 7) weather forecasts to weather module via OpenWeatherMap One Call API.
      • Added eslint-plugin for jsdoc comments.
      • Added new configDeepMerge option for module developers.
      Updated
      • Change incorrect weather.js default properties.
      • Cleaned up newsfeed module.
      • Cleaned up jsdoc comments.
      • Cleaned up clock tests.
      • Move lodash into devDependencies, update other dependencies.
      • Switch from ical to node-ical library.
      Fixed
      • Fix backward compatibility issues for Safari < 11.
      • Fix the use of “maxNumberOfDays” in the module “weatherforecast depending on the endpoint (forecast/daily or forecast)”. #2018
      • Fix calendar display. Account for current timezone. #2068
      • Fix logLevel being set before loading config.
      • Fix incorrect namespace links in svg clockfaces. #2072
      • Fix weather/providers/weathergov for API guidelines. #2045
      • Fix “undefined” in weather modules header. #1985
      • Fix #2110, #2111, #2118: Recurring full day events should not use timezone adjustment. Just compare month/day.
