V2.13.0
[2.13.0] - 2020-10-01
https://github.com/MichMich/MagicMirror/releases/tag/v2.13.0
Special thanks to the following contributors: @bryanzzhu, @bugsounet, @chamakura, @cjbrunner, @easyas314, @larryare, @oemel09, @rejas, @sdetweil & @sthuber90.
ℹ️ Note: This update uses new dependencies. Please update using the following command:
git pull && npm install.Added
--dry-runoption adde in fetch call within updatenotification node_helper. This is to prevent
MagicMirror from consuming any fetch result. Causes conflict with MMPM when attempting to check
for updates to MagicMirror and/or MagicMirror modules.- Test coverage with Istanbul, run it with
npm run test:coverage. - Add lithuanian language.
- Added support in weatherforecast for OpenWeather onecall API.
- Added config option to calendar-icons for recurring- and fullday-events.
- Added current, hourly (max 48), and daily (max 7) weather forecasts to weather module via OpenWeatherMap One Call API.
- Added eslint-plugin for jsdoc comments.
- Added new configDeepMerge option for module developers.
Updated
- Change incorrect weather.js default properties.
- Cleaned up newsfeed module.
- Cleaned up jsdoc comments.
- Cleaned up clock tests.
- Move lodash into devDependencies, update other dependencies.
- Switch from ical to node-ical library.
Fixed
- Fix backward compatibility issues for Safari < 11.
- Fix the use of “maxNumberOfDays” in the module “weatherforecast depending on the endpoint (forecast/daily or forecast)”. #2018
- Fix calendar display. Account for current timezone. #2068
- Fix logLevel being set before loading config.
- Fix incorrect namespace links in svg clockfaces. #2072
- Fix weather/providers/weathergov for API guidelines. #2045
- Fix “undefined” in weather modules header. #1985
- Fix #2110, #2111, #2118: Recurring full day events should not use timezone adjustment. Just compare month/day.
