IR Frame doesn't rotate
24 Posts 7 Posters 17.8k Views 8 Watching
    AlessandroRa @yawns
    @yawns I tried, there’s no way to open it…
    @Snille I’ve installed xinput_calibrator and I’ve just tried to start the mirror with the command you wrote, but it still doesn’t recognise the xinput command… How did you do it?
    @cowboysdude smart move!
    S 1 Reply Last reply Feb 24, 2017, 9:50 PM Reply Quote 1
      Snille Module Developer @AlessandroRa
      @AlessandroRa Just install xinput sudo apt-get install xinput
      Then you are good to go. :)
      @cowboysdude I have to know when to start the actual xinput command, I have tried in the “startup” for LXDE, with CRON and in “openbox”:es “statup”. For some reason I cant get it to “take”. I have not made a .sh file, true. But where / when to execute it? :)
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      C 1 Reply Last reply Feb 25, 2017, 12:57 PM Reply Quote 0
      • C Offline
        cowboysdude Module Developer @Snille
        @Snille
        Edit the file:
        sudo crontab -e
        Add line to file (here a python script):
        @reboot python3 /home/pi/Desktop/example.py &
        S P 2 Replies Last reply Feb 25, 2017, 2:34 PM Reply Quote 0
          Snille Module Developer @cowboysdude
          @cowboysdude It worked when added to a sh script! Good call! :) Before I just tested with the xinput command directly in the autostart file, but that did not work. So now instead I just created a script called xin.sh.
          nano ~/xin.sh
          Then added
          DISPLAY=:0.0 xinput --set-prop "Multi touch Multi touch overlay device" "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
          There should actually be 3 spaces between “Multi touch” and “Multi touch overlay device”. For some reason the board removes the extra spaces here.
          You can actually find the “name” of the device with this command DISPLAY=:0.0 xinput list
          Shows something like this:
          ⎡ Virtual core pointer id=2 [master pointer (3)]
          ⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
          ⎜ ↳ Multi touch Multi touch overlay device id=6 [slave pointer (2)]
          ⎣ Virtual core keyboard id=3 [master keyboard (2)]
          ↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
          Depending on what you have connected to your RPi. :)
          So, after creating the xin.sh I added that to the autostart file for LXDE:
          Like this:
          nano ~/.config/lxsession/LXDE/autostart
          Added at the end of the file.
          @/home/pi/xin.sh
          Restarted and it works. :)
          C 1 Reply Last reply Feb 25, 2017, 2:42 PM Reply Quote 2
          • C Offline
            @Snille Oddly enough you may have accidently solved my problem too! :) I’m getting a 32" IR touch frame… this may work for me as well!! So Thank you! :)
            What kind of IR touch frame do you have and where did you get it?
            Thanks!
            S 1 Reply Last reply Feb 25, 2017, 2:59 PM Reply Quote 0
              @cowboysdude I bought this one: https://www.aliexpress.com/item/32-points-32-Inch-IR-Multi-touch-overlay-kit-without-glass-for-Interactive-Table-Multi-Touch/1195149819.html
              And I can actually “zoom” the on the mirror (in the electron browser) which means that multitouch works (at least for two points). :)
              C 1 Reply Last reply Feb 25, 2017, 3:01 PM Reply Quote 0
              • C Offline
                @Snille said in IR Frame doesn’t rotate:
                That’s AWESOME … Thank you soooooooooo much… That’s the one I am ordering too!! WOW that’s just amazing how things work out…
                What kind of glass did you get for it?
                S 1 Reply Last reply Feb 25, 2017, 3:11 PM Reply Quote 0
                  @cowboysdude Hehe, I’m still waiting for my mirror. Have not yet tested with any glass, just have it leaned against the monitor right now. :) I hope my work can supply a Pilkington MirrorView mirror, if not that’s what I’m going to buy.
                  • C Offline
                    OH that’ll be very cool! I have a 7" touch clock and bathroom mirror already built. This is a 32" ‘command center’ for the house… so no mirror but as I have read I need to use tempered glass so when the frame comes in I’ll take it there and get the glass for it :)
                    How long did it take to get after you ordered it?
                    S 1 Reply Last reply Feb 25, 2017, 3:18 PM Reply Quote 0
                      @cowboysdude Actually it was quite fast only 8 days! :)
                      C 1 Reply Last reply Feb 25, 2017, 3:22 PM Reply Quote 1
                      • 2 / 3
                      2 / 3
