    Basic Text on Magic Mirror
    6 Posts 7 Posters 3.5k Views 5 Watching
      Juri
      Hello guys,
      is there a way or someone who can help me to display a simple Text on my MagicMirror.
      I want a Text with 4 Lines shown at my bottom part of the Mirror.
      I found no module…
      Pls help me guys :)
      • SnilleS Offline
        Snille Module Developer
        Hi!
        Try one of these:
        https://github.com/SaltyRiver/MMM-SimpleText
        https://github.com/martinmeinke/MMM-display-text-file
        https://github.com/SkogDev/MMM-Text
        Depending on how you want it… :)
        If you cant find it, make it and share it
        MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
        S A 2 Replies Last reply Reply Quote 1
          Sven1894
          The deafualt module “helloworld” can do this :)
            SymmetriC @Snille
            @Snille Unfortunately, the only module I found that actually worked was MMM-Text, but the config.js stated (below) in the directions don’t work:
                module: 'MMM-Text',
                position: 'lower_third',
                    url: 'your url here'
            I tried multiple variations and still nothing. Instead, the only solution I found to make this module work was to go into the //MMM-Text.js file and change line #26 of the ‘Loading…’ to your desired text output from the following lines:
            		this.text = 'Loading ..';
            		var self = this;
            		setInterval(function() {
            Your new text would look like this:
            // Schedule update timer.
            		this.text = 'Write Whatever You Want';
            		var self = this;
            This will now display your text on the MagicMirror display. Hope I could help someone from the frustration I went through, but if someone has other solutions to make MMM-helloworld or MMM-Text work as intended, I’d appreciate it. :)
              sdetweil @SymmetriC
              @SymmetriC what url did u provide?
              if using the mm web server
              http://localhost:8080/modules/MMM-Text/filename
              for reading from filename in the module folder
              if some other file NOT using the mm web server
              file:///full_path_to_filename
              and of course if on some server someplace else
              http{s}://server name/path?parms_if_any
                alienatedwan @Snille
                @Snille Many thanks! It’s worked.
