    MMM-NOAA3
    3 Posts 2 Posters 793 Views 2 Watching
      mmcghee
      Hi Guys,
      following the downfall of another weather module i was using - “MMM-MyWeather” i am trying to install MMM-NOAA3.
      When i run MM i get the below error,
      [2020-10-27 21:19:39.201] [LOG]    Sockets connected & modules started ...
      [2020-10-27 21:19:39.287] [LOG]    Launching application.
      [2020-10-27 21:19:43.002] [LOG]    wu
      [2020-10-27 21:19:43.006] [ERROR]  Whoops! There was an uncaught exception...
      [2020-10-27 21:19:43.007] [ERROR]  Error: Cannot find module './providers/wu.js'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-NOAA3/node_helper.js
      - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai        n.js
          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/elect        ron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/modul        e-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Class.getProviderFromConfig (/home/pi/MagicMirror/modules/MMM-NOAA3/node_        helper.js:128:16)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NOAA3/        node_helper.js:38:34)
          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:112:11)
          at Socket.emit (events.js:200:13)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at processTicksAndRejections (internal/process/task_queues.js:82:9)
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/MMM-NOAA3/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/        main.js',
          undefined
      [2020-10-27 21:19:43.015] [ERROR]  MagicMirror will not quit, but it might be a        good idea to check why this happened. Maybe no internet connection?
      [2020-10-27 21:19:43.016] [ERROR]  If you think this really is an issue, please        open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Below is my config minus api keys
           module: 'MMM-NOAA3',
       position: 'top_right',
       	    provider: "weatherunlocked",
       	    apiKey: "MY API KEY",
       	    appID: "MY APP ID",
       	    airKey: "MY API KEY",
               css: "NOAA4",                  // THIS MUST CONTAIN A CSS STYLE NAME
       	userlat: "55.861790", //MUST HAVE BOTH
               userlon: "-3.827600",  //MUST HAVE BOTH
      I am at a complete loss with this one any help would be appreciated.
      Cheers
      Michael
        Mykle1 Project Sponsor Module Developer @mmcghee
        @mmcghee said in MMM-NOAA3:
        Did you try it with another provider? I just loaded it up with openweather and it fired right up. I know this author and the amount of work it takes to maintain this module. I think he is working on a new version because NOAA3 is vulnerable if any of the providers changes their data
          mmcghee
          Yeah i tried it with Accuweather and still had the same. I’ll try it with openweather when i get home and see what happens.
          Michael
