    Magic mirror as thin as possible
    laptopnotebookscreenthinwandrobe
    4 Posts 4 Posters 5.4k Views 3 Watching
    • Z
      ZombieDE
      Hey,
      I want to build a magic mirror for my wardrobe and therefore it should be as thin as possible (similiar to this normal mirror).
      I guess that a laptop screen would be the best solution, but does anyone have experience with a thin monitor or tv?
      And can anyone recommend a good laptop screen?
      ? brobergB 2 Replies Last reply
        A Former User @ZombieDE
        @ZombieDE You could get a flatscreen TV instead, a smaller one that’s meant to mount on the wall. then frame only the screen and mirror, and wire the RPi somewhere else in the wardrobe.
        Or, if you can’t find a thin/small enough TV, you’d have some difficulty getting a laptop screen to connect to the RPi without it’s own Motherboard. No doubt, it can be done, but dude good luck.
        • brobergB
          broberg Project Sponsor @ZombieDE
          @ZombieDE
          A wardrobe is a perfect place to fit a flush mount mirror, you should have enough space on the back of the wardrobe door to recess the entire screen and flush mount the mirror to the door.
          A normal TFT (with casing) is around 50-60mm deep, that’s not much at all, you should have that much space on the inside, right?
          • lolobyteL
            lolobyte
            exact like hight of raspi
