Magic mirror as thin as possible
laptopnotebookscreenthinwandrobe
4 Posts 4 Posters 4.7k Views 3 Watching
  • Z Offline
    ZombieDE
    Hey,
    I want to build a magic mirror for my wardrobe and therefore it should be as thin as possible (similiar to this normal mirror).
    I guess that a laptop screen would be the best solution, but does anyone have experience with a thin monitor or tv?
    And can anyone recommend a good laptop screen?
    ? B 2 Replies Last reply Jan 12, 2017, 5:55 PM Reply Quote 0
      A Former User @ZombieDE
      @ZombieDE You could get a flatscreen TV instead, a smaller one that’s meant to mount on the wall. then frame only the screen and mirror, and wire the RPi somewhere else in the wardrobe.
      Or, if you can’t find a thin/small enough TV, you’d have some difficulty getting a laptop screen to connect to the RPi without it’s own Motherboard. No doubt, it can be done, but dude good luck.
        broberg Project Sponsor @ZombieDE
        @ZombieDE
        A wardrobe is a perfect place to fit a flush mount mirror, you should have enough space on the back of the wardrobe door to recess the entire screen and flush mount the mirror to the door.
        A normal TFT (with casing) is around 50-60mm deep, that’s not much at all, you should have that much space on the inside, right?
        • L Offline
          lolobyte
          exact like hight of raspi
