    Not all Modules are displaying on the tv
    34 Posts 6 Posters 12.9k Views 5 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @kusselin
      @kusselin You are rotating the pages every 60 seconds? Correct? From what I understand, ever time the pages rotate a call is done to get data which would be true in the case of mmm-traffic. It could be that by the time the module get it’s data that the rotation has happened and then it does not display? I may be wrong. I don’t use the module myself.
      • kusselinK Offline
        kusselin
        I have now taken the code for my MMM-pages out of the config.js - strange then everything works! then traffic is displayed … so it is due to the MMM-pages module …
        Question: Can the mmm-pages code be at the very end of the config.js or does it have to be at the beginning?
        Question 2: the mmm-pages code from me is correct, right?
        I have already set the time to 120,000, there too no traffic and current weather is displayed! :-( I’m with my Latain at the end :-(
          sdetweil @kusselin
          @kusselin said in Not all Modules are displaying on the tv:
          what is the time value increment, seconds or milliseconds? if milliseconds, that 120,000 is just 2 minutes
          • kusselinK Offline
            kusselin
            exactly … milliseconds and two minutes should be long for a switch …
            as I said, even if I take out the duration time it doesn’t work with traffic and the weather module :-(
            I take the complete mmm-pages code out of the config, then everything works!
              mumblebaj Module Developer @sdetweil
              @sdetweil I have had a look and I see the following:
              Will not show MMM-Traffic. LockStrings active: module_7_MMM-pages
              I assume this is why the MMM-Traffic is not showing when used in MMM-Pages? I have added the modules on my test machine and I can’t get the module to show either. I see that the above error comes from the main.js of MM. maybe you can shed more light on the issue for @kusselin
                sdetweil @mumblebaj
                @mumblebaj that is not an error. Just info.
                The module will ONLY be shown on its page, or if set to fixed.
                All the message says is pages hid it, and no-one else can show it
                  sdetweil
                  Looks like this module manipulates the hidden status directly, instead of calling the hide/show api…
                    @sdetweil Yeah, doesn’t seem to play well with pages. The minute you remove paged the module works fine.
                    • kusselinK Offline
                      kusselin
                      @mumblebaj said in Not all Modules are displaying on the tv:
                      Yep, that’s how I see it … the MMM traffic module cannot be used in combination with the MMM pages module !!
                      • kusselinK Offline
                        kusselin
                        MMM-Traffic definitely doesn’t work with the module “Pages” !!! And the weather module doesn’t work either if you run the “pages” module !! This is a pity :-(
                        Can the developer of MMM Traffic and the MMM-OpenmapWeather take a look …
                        here again my config:
                            			module: "MMM-pages",
                        						modules:
                        						[[ "MMM-SoccerLiveScore" ],
                        						[ "MMM-COVID19-AMPEL" ],
                        						[ "MMM-Formula1" ]],
                        			fixed: [ "clock" , "MMM-OpenmapWeather" , "weatherforecast" , "MMM-PublicTransportHafas" , "newsfeed" , "calendar" , "MMM-Fuel", "MMM-Tankerkoenig" , "MMM-ioBroker" , "MMM-Traffic" ],
                            		rotationTime: 120000,
                          sdetweil @kusselin
                          @kusselin posting here probably won’t get the developer’s attention… open an issue on the module github site
                          • kusselinK Offline
                            kusselin
                            @sdetweil said in Not all Modules are displaying on the tv:
                            ok. thanks
                            • O Offline
                              OberfragGER @kusselin
                              @kusselin I have nearly sam problem with less Modules.
                              The default weather and also MMM-openmapweather are not loading, when u put that on the first page of MM-Pages. If you put that on other Pages, no problem so far.
                              I dont have any idea why…
                              • kusselinK Offline
                                kusselin
                                Ok, thank you for answer
