    Dell Monitor 19" 1905FP for my Magic Mirror
    display
    8 Posts 2 Posters 2.4k Views 2 Watching
    • kusselinK Offline
      kusselin
      Hello everybody,
      I have the above monitor and would like to use this one for my Magic Mirror. There are instructions on how to dismantle the monitor on the Internet:
      https://www.youtube.com/watch?v=2oEyzoV4NCQ
      My question to the experts … which KIT do I still need for the display to work? Or can I use the panels from the monitor?
      I would be very grateful if you could send me a link from the components that I need … Thank you very much.
      or do I need the extra controller board in any case?
      https://www.amazon.de/gp/product/B0722PLC11/ref=as_li_ss_tl?ie=UTF8&psc=1&linkCode=sl1&tag=bath0f-21&linkId=38d709c7b5c9af1a00eb339dab49508f&language=de_DE
      • kusselinK Offline
        kusselin
        so, i screwed the monitor open und i took some photos. i hope this is o.k. so.
        Is this a 40 pin connector?
        for a link what controller panel i can use, thanks a lot.
        • L Offline
          lolobyte @kusselin
          @kusselin
          Hello Friend.
          here some links for your panel:
          Important:
          search for version v.1: M190EN03 V1
          You also need a power adapter (Ouput 12V/4A) for it.
          ebay
          AliExpress
          good luck
          • kusselinK Offline
            kusselin
            @lolobyte said in Dell Monitor 19" 1905FP for my Magic Mirror:
            M190EN03 V1
            thanks very much
            • kusselinK Offline
              kusselin
              one more question about the power supply …
              if the voltage were higher … would the controller break? Does it have to be exactly 12V / 4W !!?
              I can supply the Raspberry Pi with power with the MicroUSB on the USB on the controller … right?
              Is the power adapter big for a connect to the pi?
              • L Offline
                lolobyte @kusselin
                @kusselin
                Hi, Friend.
                Yes, you need two power supplies!
                The standard one 4 the Raspberry pi 3 (5V/2,5A) or (5V/3A) for version pi 4.
                For your panel you need the 12 V/4A (ampere) not 4W (wat) power supply.
                4W ist to poor power. This one has 12*4=48W
                Please read “Instruction to connect the controller board to the LCD” for example in the board specs at ebay.
                Best regards
                • kusselinK Offline
                  kusselin
                  Hi, Friend.
                  Best regards
                  Hi with this controller you need only one power supply…
                  • L Offline
                    lolobyte @kusselin
                    @kusselin
                    OK, much better…
