    Where do I put this.sendNotification?
    3 Posts 3 Posters 711 Views 3 Watching
    • E Offline
      eracerhead
      I’m trying to use this for newsfeeds module.
      It says in the documentation to use
      this.sendNotification(‘ARTICLE_whatever’);
      If I put this anywhere in config.js, it fails to recognize the config.js
      If I put this anywhere in newsfeeds.js it fails to load.
      I’ve done some programming but I know absolutely nothing about javascript.
      S lavolp3L 2 Replies Last reply Reply Quote 0
        sdetweil @eracerhead
        @eracerhead unless u have your own module trying to get newsfeed to display something, then u do not need to do this.
        That code would go inside your module
        • lavolp3L Offline
          lavolp3 Module Developer @eracerhead
          @eracerhead these functions (this.sendNotification()) are being used to trigger something in one module from inside another module. It is only needed for module developers.
          You could create e.g. a module with control functions including these.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
