    MMM-Awesome-Alexa (again =p)
    17 Posts 3 Posters 3.6k Views 3 Watching
      stalker401
      So i’m having another issue, but it’s not the installation. When I try to add an item to my calendar or remove one, alexa responds to me with a confirmation question. But does not listen for my response. Anyone else seen this issue, or has anyone dealt with this? I tried looking through the GitHub issues and searching online, but I couldn’t find anything.
        sdetweil @stalker401
        @stalker401 no idea if the developer handled that case. i don’t see it in the state model
          stalker401 @sdetweil
          @sdetweil Thanks again, I appreciate your patience working with me.
            @stalker401 no problem, I built an alexa integration for a different platform,
            so I understand about handling the dialog.
              Didikojak @sdetweil
              @sdetweil : after tried your script for installation of awesome-alexa, but got a lot of error messages at the end:
              Please find following cut-out:
              ⠧ Building module: snowboy, Completed: 0  SOLINK_MODULE(target) Release/obj.target/snowboy.node
              ⠏ Building module: snowboy, Completed: 0/usr/bin/ld: cannot find -lcblas
              collect2: error: ld returned 1 exit status
              make: *** [snowboy.target.mk:151: Release/obj.target/snowboy.node] Error 1
              make: Leaving directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
              ✖ Rebuild Failed
              An unhandled error occurred inside electron-rebuild
              node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
              Error: `make` failed with exit code: 2
              Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                  at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:193:19)
                  at processTicksAndRejections (internal/process/task_queues.js:93:5)
                  at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:190:9)
                  at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:152:17)
                  at async /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/cli.js:146:9
              any help would be appriciated!
              kind regards, Dieter
                sdetweil @Didikojak
                @didikojak only the results of the last command matters
                there WILL be errors reported before that… I didn’t design the steps, I just hate typing someone elses stuff,
                so I copy/pasted the steps to a file and made it runnable
                and it worked…
                so, now I thought others might like it too… I don’t add any technical value…
                just ease of use
                  Didikojak @sdetweil
                  I see, thanks for the clarification!
