    MMM-Awesome-Alexa (again =p)
    17 Posts 3 Posters 7.1k Views 3 Watching
      sdetweil @stalker401
      @stalker401 1st error, missing comma on line before
      2nd error, the id needs to be in quotes
      also,
      general rules for module definition
      {} and [] must be matched
      the word to the left of : does not need quotes
      the thing to the right of : if a number or, true/false does NOT need quotes
      otherwise it needs quotes, single or double doesn’t matter as long as start and end quote are the same
      if the thing on the next line starts with a word , then THIS line needs a trailing comma
      if the thing on the next line starts with {, then THIS line needs a trailing comma
        stalker401 @sdetweil
        @sdetweil I really appreciate your help, and i’m sorry i can’t seem to figure this out on my own at all. So here’s what I tried:
        i used this code:
        		  module: "MMM-awesome-alexa",
        		  position: "bottom_bar",
        		    wakeWord: "Alexa",
        		    clientId: "null",
        		    clientSecret: "null",
        		    deviceId: "null",
        and got this error:
        /home/pi/.pm2/pm2.log last 15 lines:
        PM2        | 2020-12-20T15:53:14: PM2 log: pid=27048 msg=process killed
        PM2        | 2020-12-20T16:28:35: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-12-20T16:28:35: PM2 log: App [mm:0] online
        PM2        | 2020-12-20T16:29:25: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-12-20T16:29:25: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-12-20T16:29:25: PM2 log: App [mm:0] online
        PM2        | 2020-12-20T16:29:34: PM2 log: Stopping app:mm id:0
        PM2        | 2020-12-20T16:29:35: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-12-20T16:29:35: PM2 log: pid=27383 msg=process killed
        PM2        | 2020-12-20T16:31:10: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-12-20T16:31:10: PM2 log: App [mm:0] online
        PM2        | 2020-12-20T16:32:41: PM2 log: Stopping app:mm id:0
        PM2        | 2020-12-20T16:32:42: PM2 log: pid=27457 msg=failed to kill - retrying in 100ms
        PM2        | 2020-12-20T16:32:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-12-20T16:32:42: PM2 log: pid=27457 msg=process killed
        0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
        0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
        0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
        0|mm       |   code: 'MODULE_NOT_FOUND',
        0|mm       |   requireStack: [
        0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js',
        0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js',
        0|mm       |     '/home/pi/MagicMirror/js/app.js',
        0|mm       |     '/home/pi/MagicMirror/js/electron.js',
        0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
        0|mm       |     undefined
        0|mm       |   ]
        0|mm       | }
        0|mm       | [2020-12-20 16:31:29.816] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm       | [2020-12-20 16:31:29.816] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|mm       | [2020-12-20 16:31:29.774] [LOG]    No helper found for module: alert.
        0|mm       | [2020-12-20 16:31:29.775] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:31:29.776] [LOG]    Module helper loaded: updatenotification
        0|mm       | [2020-12-20 16:31:29.777] [LOG]    No helper found for module: clock.
        0|mm       | [2020-12-20 16:31:29.779] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:31:29.779] [LOG]    Module helper loaded: MMM-Remote-Control
        0|mm       | [2020-12-20 16:31:29.781] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:31:29.781] [LOG]    Module helper loaded: calendar
        0|mm       | [2020-12-20 16:31:29.782] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:31:29.783] [LOG]    Check MagicMirror version for node helper 'MMM-Ring' - Minimum version:  2.11.0 - Current version: 2.13.0
        0|mm       | [2020-12-20 16:31:29.783] [LOG]    Version is ok!
        0|mm       | [2020-12-20 16:31:29.784] [LOG]    Module helper loaded: MMM-Ring
        0|mm       | [2020-12-20 16:31:29.785] [LOG]    No helper found for module: MMM-DailyPokemon.
        0|mm       | [2020-12-20 16:31:29.991] [LOG]    Launching application.
        0|mm       | [2020-12-20 16:32:42.341] [LOG]    Shutting down server...
        I also did this code:
        		    wakeWord: "Alexa",
        		    clientId: "amzn1.application-oa2-client.0fa20b28debc4858a0acd193871bd8e1",
        		    clientSecret: "53e57d1db3d529ac84ee1b6f9d42d5339acfba752812aa4faf6efbb848aa39b4",
        		    deviceId: "MagicMirror_2",
        and got this error:
        PM2        | 2020-12-20T16:37:11: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2020-12-20T16:37:11: PM2 log: App [mm:0] online
        PM2        | 2020-12-20T16:38:25: PM2 log: Stopping app:mm id:0
        PM2        | 2020-12-20T16:38:26: PM2 log: pid=27652 msg=failed to kill - retrying in 100ms
        PM2        | 2020-12-20T16:38:26: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2020-12-20T16:38:26: PM2 log: pid=27652 msg=process killed
        0|mm       |     undefined
        0|mm       |   ]
        0|mm       | }
        0|mm       | [2020-12-20 16:37:32.113] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm       | [2020-12-20 16:37:32.114] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|mm       | [2020-12-20 16:37:32.067] [LOG]    No helper found for module: alert.
        0|mm       | [2020-12-20 16:37:32.068] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:37:32.069] [LOG]    Module helper loaded: updatenotification
        0|mm       | [2020-12-20 16:37:32.071] [LOG]    No helper found for module: clock.
        0|mm       | [2020-12-20 16:37:32.072] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:37:32.074] [LOG]    Module helper loaded: MMM-Remote-Control
        0|mm       | [2020-12-20 16:37:32.075] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:37:32.076] [LOG]    Module helper loaded: calendar
        0|mm       | [2020-12-20 16:37:32.077] [LOG]    Initializing new module helper ...
        0|mm       | [2020-12-20 16:37:32.078] [LOG]    Check MagicMirror version for node helper 'MMM-Ring' - Minimum version:  2.11.0 - Current version: 2.13.0
        0|mm       | [2020-12-20 16:37:32.079] [LOG]    Version is ok!
        0|mm       | [2020-12-20 16:37:32.080] [LOG]    Module helper loaded: MMM-Ring
        0|mm       | [2020-12-20 16:37:32.082] [LOG]    No helper found for module: MMM-DailyPokemon.
        0|mm       | [2020-12-20 16:37:32.962] [LOG]    Launching application.
        0|mm       | [2020-12-20 16:38:26.368] [LOG]    Shutting down server...
        I’ll also say when I try to get to the dev console i get this error that stats couldn’t not connect…
          @stalker401 u didn’t finish the install. all 14 steps.
            @sdetweil lol i was racking my brain what i was doing wrong. I’ll go back and see what I missed thanks!
              @stalker401 i made a script out of the steps
              https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
              download, make it executable ( chmod +x do-install.sh)
              and then execute it… (./do-install.sh)
              the steps include the whole thing, git clone, and onward
              D 1 Reply Last reply Reply Quote 2
                stalker401
                Thanks so much for your help. I got it up and working, and i see where I missed some early steps actually.
                  stalker401
                  So i’m having another issue, but it’s not the installation. When I try to add an item to my calendar or remove one, alexa responds to me with a confirmation question. But does not listen for my response. Anyone else seen this issue, or has anyone dealt with this? I tried looking through the GitHub issues and searching online, but I couldn’t find anything.
                    @stalker401 no idea if the developer handled that case. i don’t see it in the state model
                      @sdetweil Thanks again, I appreciate your patience working with me.
                        @stalker401 no problem, I built an alexa integration for a different platform,
                        so I understand about handling the dialog.
                          Didikojak @sdetweil
                          @sdetweil : after tried your script for installation of awesome-alexa, but got a lot of error messages at the end:
                          Please find following cut-out:
                          ⠧ Building module: snowboy, Completed: 0  SOLINK_MODULE(target) Release/obj.target/snowboy.node
                          ⠏ Building module: snowboy, Completed: 0/usr/bin/ld: cannot find -lcblas
                          collect2: error: ld returned 1 exit status
                          make: *** [snowboy.target.mk:151: Release/obj.target/snowboy.node] Error 1
                          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
                          ✖ Rebuild Failed
                          An unhandled error occurred inside electron-rebuild
                          node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                          Error: `make` failed with exit code: 2
                          Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                              at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:193:19)
                              at processTicksAndRejections (internal/process/task_queues.js:93:5)
                              at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:190:9)
                              at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:152:17)
                              at async /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/cli.js:146:9
                          any help would be appriciated!
                          kind regards, Dieter
                            sdetweil @Didikojak
                            @didikojak only the results of the last command matters
                            there WILL be errors reported before that… I didn’t design the steps, I just hate typing someone elses stuff,
                            so I copy/pasted the steps to a file and made it runnable
                            and it worked…
                            so, now I thought others might like it too… I don’t add any technical value…
                            just ease of use
                              Didikojak @sdetweil
                              I see, thanks for the clarification!
