    MMM-Awesome-Alexa (again =p)
    17 Posts 3 Posters 7.1k Views 3 Watching
      stalker401 @sdetweil
      @sdetweil I really appreciate your help, and i’m sorry i can’t seem to figure this out on my own at all. So here’s what I tried:
      i used this code:
      		  module: "MMM-awesome-alexa",
      		  position: "bottom_bar",
      		    wakeWord: "Alexa",
      		    clientId: "null",
      		    clientSecret: "null",
      		    deviceId: "null",
      and got this error:
      /home/pi/.pm2/pm2.log last 15 lines:
      PM2        | 2020-12-20T15:53:14: PM2 log: pid=27048 msg=process killed
      PM2        | 2020-12-20T16:28:35: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-12-20T16:28:35: PM2 log: App [mm:0] online
      PM2        | 2020-12-20T16:29:25: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2020-12-20T16:29:25: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-12-20T16:29:25: PM2 log: App [mm:0] online
      PM2        | 2020-12-20T16:29:34: PM2 log: Stopping app:mm id:0
      PM2        | 2020-12-20T16:29:35: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2020-12-20T16:29:35: PM2 log: pid=27383 msg=process killed
      PM2        | 2020-12-20T16:31:10: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-12-20T16:31:10: PM2 log: App [mm:0] online
      PM2        | 2020-12-20T16:32:41: PM2 log: Stopping app:mm id:0
      PM2        | 2020-12-20T16:32:42: PM2 log: pid=27457 msg=failed to kill - retrying in 100ms
      PM2        | 2020-12-20T16:32:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2020-12-20T16:32:42: PM2 log: pid=27457 msg=process killed
      0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
      0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
      0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
      0|mm       |   code: 'MODULE_NOT_FOUND',
      0|mm       |   requireStack: [
      0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js',
      0|mm       |     '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js',
      0|mm       |     '/home/pi/MagicMirror/js/app.js',
      0|mm       |     '/home/pi/MagicMirror/js/electron.js',
      0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|mm       |     undefined
      0|mm       |   ]
      0|mm       | }
      0|mm       | [2020-12-20 16:31:29.816] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | [2020-12-20 16:31:29.816] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm       | [2020-12-20 16:31:29.774] [LOG]    No helper found for module: alert.
      0|mm       | [2020-12-20 16:31:29.775] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:31:29.776] [LOG]    Module helper loaded: updatenotification
      0|mm       | [2020-12-20 16:31:29.777] [LOG]    No helper found for module: clock.
      0|mm       | [2020-12-20 16:31:29.779] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:31:29.779] [LOG]    Module helper loaded: MMM-Remote-Control
      0|mm       | [2020-12-20 16:31:29.781] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:31:29.781] [LOG]    Module helper loaded: calendar
      0|mm       | [2020-12-20 16:31:29.782] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:31:29.783] [LOG]    Check MagicMirror version for node helper 'MMM-Ring' - Minimum version:  2.11.0 - Current version: 2.13.0
      0|mm       | [2020-12-20 16:31:29.783] [LOG]    Version is ok!
      0|mm       | [2020-12-20 16:31:29.784] [LOG]    Module helper loaded: MMM-Ring
      0|mm       | [2020-12-20 16:31:29.785] [LOG]    No helper found for module: MMM-DailyPokemon.
      0|mm       | [2020-12-20 16:31:29.991] [LOG]    Launching application.
      0|mm       | [2020-12-20 16:32:42.341] [LOG]    Shutting down server...
      I also did this code:
      		    wakeWord: "Alexa",
      		    clientId: "amzn1.application-oa2-client.0fa20b28debc4858a0acd193871bd8e1",
      		    clientSecret: "53e57d1db3d529ac84ee1b6f9d42d5339acfba752812aa4faf6efbb848aa39b4",
      		    deviceId: "MagicMirror_2",
      and got this error:
      PM2        | 2020-12-20T16:37:11: PM2 log: App [mm:0] starting in -fork mode-
      PM2        | 2020-12-20T16:37:11: PM2 log: App [mm:0] online
      PM2        | 2020-12-20T16:38:25: PM2 log: Stopping app:mm id:0
      PM2        | 2020-12-20T16:38:26: PM2 log: pid=27652 msg=failed to kill - retrying in 100ms
      PM2        | 2020-12-20T16:38:26: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
      PM2        | 2020-12-20T16:38:26: PM2 log: pid=27652 msg=process killed
      0|mm       |     undefined
      0|mm       |   ]
      0|mm       | }
      0|mm       | [2020-12-20 16:37:32.113] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | [2020-12-20 16:37:32.114] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm       | [2020-12-20 16:37:32.067] [LOG]    No helper found for module: alert.
      0|mm       | [2020-12-20 16:37:32.068] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:37:32.069] [LOG]    Module helper loaded: updatenotification
      0|mm       | [2020-12-20 16:37:32.071] [LOG]    No helper found for module: clock.
      0|mm       | [2020-12-20 16:37:32.072] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:37:32.074] [LOG]    Module helper loaded: MMM-Remote-Control
      0|mm       | [2020-12-20 16:37:32.075] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:37:32.076] [LOG]    Module helper loaded: calendar
      0|mm       | [2020-12-20 16:37:32.077] [LOG]    Initializing new module helper ...
      0|mm       | [2020-12-20 16:37:32.078] [LOG]    Check MagicMirror version for node helper 'MMM-Ring' - Minimum version:  2.11.0 - Current version: 2.13.0
      0|mm       | [2020-12-20 16:37:32.079] [LOG]    Version is ok!
      0|mm       | [2020-12-20 16:37:32.080] [LOG]    Module helper loaded: MMM-Ring
      0|mm       | [2020-12-20 16:37:32.082] [LOG]    No helper found for module: MMM-DailyPokemon.
      0|mm       | [2020-12-20 16:37:32.962] [LOG]    Launching application.
      0|mm       | [2020-12-20 16:38:26.368] [LOG]    Shutting down server...
      I’ll also say when I try to get to the dev console i get this error that stats couldn’t not connect…
        sdetweil @stalker401
        @stalker401 u didn’t finish the install. all 14 steps.
          @sdetweil lol i was racking my brain what i was doing wrong. I’ll go back and see what I missed thanks!
            @stalker401 i made a script out of the steps
            https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
            download, make it executable ( chmod +x do-install.sh)
            and then execute it… (./do-install.sh)
            the steps include the whole thing, git clone, and onward
            D 1 Reply Last reply Reply Quote 2
              stalker401
              Thanks so much for your help. I got it up and working, and i see where I missed some early steps actually.
                stalker401
                So i’m having another issue, but it’s not the installation. When I try to add an item to my calendar or remove one, alexa responds to me with a confirmation question. But does not listen for my response. Anyone else seen this issue, or has anyone dealt with this? I tried looking through the GitHub issues and searching online, but I couldn’t find anything.
                  @stalker401 no idea if the developer handled that case. i don’t see it in the state model
                    @sdetweil Thanks again, I appreciate your patience working with me.
                      @stalker401 no problem, I built an alexa integration for a different platform,
                      so I understand about handling the dialog.
                        Didikojak @sdetweil
                        @sdetweil : after tried your script for installation of awesome-alexa, but got a lot of error messages at the end:
                        Please find following cut-out:
                        ⠧ Building module: snowboy, Completed: 0  SOLINK_MODULE(target) Release/obj.target/snowboy.node
                        ⠏ Building module: snowboy, Completed: 0/usr/bin/ld: cannot find -lcblas
                        collect2: error: ld returned 1 exit status
                        make: *** [snowboy.target.mk:151: Release/obj.target/snowboy.node] Error 1
                        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
                        ✖ Rebuild Failed
                        An unhandled error occurred inside electron-rebuild
                        node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                        Error: `make` failed with exit code: 2
                        Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                            at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:193:19)
                            at processTicksAndRejections (internal/process/task_queues.js:93:5)
                            at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:190:9)
                            at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:152:17)
                            at async /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/cli.js:146:9
                        any help would be appriciated!
                        kind regards, Dieter
                          sdetweil @Didikojak
                          @didikojak only the results of the last command matters
                          there WILL be errors reported before that… I didn’t design the steps, I just hate typing someone elses stuff,
                          so I copy/pasted the steps to a file and made it runnable
                          and it worked…
                          so, now I thought others might like it too… I don’t add any technical value…
                          just ease of use
                            Didikojak @sdetweil
                            I see, thanks for the clarification!
