    MMM-Awesome-Alexa (again =p)
    17 Posts 3 Posters 6.8k Views 3 Watching
      sdetweil @stalker401
      @stalker401 u didn’t finish the install. all 14 steps.
        stalker401 @sdetweil
        @sdetweil lol i was racking my brain what i was doing wrong. I’ll go back and see what I missed thanks!
          @stalker401 i made a script out of the steps
          https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
          download, make it executable ( chmod +x do-install.sh)
          and then execute it… (./do-install.sh)
          the steps include the whole thing, git clone, and onward
          D 1 Reply Last reply Reply Quote 2
            stalker401
            Thanks so much for your help. I got it up and working, and i see where I missed some early steps actually.
              stalker401
              So i’m having another issue, but it’s not the installation. When I try to add an item to my calendar or remove one, alexa responds to me with a confirmation question. But does not listen for my response. Anyone else seen this issue, or has anyone dealt with this? I tried looking through the GitHub issues and searching online, but I couldn’t find anything.
                @stalker401 no idea if the developer handled that case. i don’t see it in the state model
                  @sdetweil Thanks again, I appreciate your patience working with me.
                    @stalker401 no problem, I built an alexa integration for a different platform,
                    so I understand about handling the dialog.
                      Didikojak @sdetweil
                      @sdetweil : after tried your script for installation of awesome-alexa, but got a lot of error messages at the end:
                      Please find following cut-out:
                      ⠧ Building module: snowboy, Completed: 0  SOLINK_MODULE(target) Release/obj.target/snowboy.node
                      ⠏ Building module: snowboy, Completed: 0/usr/bin/ld: cannot find -lcblas
                      collect2: error: ld returned 1 exit status
                      make: *** [snowboy.target.mk:151: Release/obj.target/snowboy.node] Error 1
                      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
                      ✖ Rebuild Failed
                      An unhandled error occurred inside electron-rebuild
                      node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                      Error: `make` failed with exit code: 2
                      Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                          at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:193:19)
                          at processTicksAndRejections (internal/process/task_queues.js:93:5)
                          at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:190:9)
                          at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:152:17)
                          at async /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/cli.js:146:9
                      any help would be appriciated!
                      kind regards, Dieter
                        sdetweil @Didikojak
                        @didikojak only the results of the last command matters
                        there WILL be errors reported before that… I didn’t design the steps, I just hate typing someone elses stuff,
                        so I copy/pasted the steps to a file and made it runnable
                        and it worked…
                        so, now I thought others might like it too… I don’t add any technical value…
                        just ease of use
                          Didikojak @sdetweil
                          I see, thanks for the clarification!
