    MMM-Awesome-Alexa (again =p)
    17 Posts 3 Posters 7.1k Views 3 Watching
      stalker401 @sdetweil
      @sdetweil lol i was racking my brain what i was doing wrong. I’ll go back and see what I missed thanks!
        sdetweil @stalker401
        @stalker401 i made a script out of the steps
        https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
        download, make it executable ( chmod +x do-install.sh)
        and then execute it… (./do-install.sh)
        the steps include the whole thing, git clone, and onward
        D 1 Reply Last reply Reply Quote 2
          stalker401
          Thanks so much for your help. I got it up and working, and i see where I missed some early steps actually.
            stalker401
            So i’m having another issue, but it’s not the installation. When I try to add an item to my calendar or remove one, alexa responds to me with a confirmation question. But does not listen for my response. Anyone else seen this issue, or has anyone dealt with this? I tried looking through the GitHub issues and searching online, but I couldn’t find anything.
              @stalker401 no idea if the developer handled that case. i don’t see it in the state model
                @sdetweil Thanks again, I appreciate your patience working with me.
                  @stalker401 no problem, I built an alexa integration for a different platform,
                  so I understand about handling the dialog.
                    Didikojak @sdetweil
                    @sdetweil : after tried your script for installation of awesome-alexa, but got a lot of error messages at the end:
                    Please find following cut-out:
                    ⠧ Building module: snowboy, Completed: 0  SOLINK_MODULE(target) Release/obj.target/snowboy.node
                    ⠏ Building module: snowboy, Completed: 0/usr/bin/ld: cannot find -lcblas
                    collect2: error: ld returned 1 exit status
                    make: *** [snowboy.target.mk:151: Release/obj.target/snowboy.node] Error 1
                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
                    ✖ Rebuild Failed
                    An unhandled error occurred inside electron-rebuild
                    node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                    Error: `make` failed with exit code: 2
                    Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy'.
                        at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/module-rebuilder.js:193:19)
                        at processTicksAndRejections (internal/process/task_queues.js:93:5)
                        at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:190:9)
                        at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/rebuild.js:152:17)
                        at async /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/electron-rebuild/lib/src/cli.js:146:9
                    any help would be appriciated!
                    kind regards, Dieter
                      sdetweil @Didikojak
                      @didikojak only the results of the last command matters
                      there WILL be errors reported before that… I didn’t design the steps, I just hate typing someone elses stuff,
                      so I copy/pasted the steps to a file and made it runnable
                      and it worked…
                      so, now I thought others might like it too… I don’t add any technical value…
                      just ease of use
                        Didikojak @sdetweil
                        I see, thanks for the clarification!
