    Clone the SD card?
    Scheduled Pinned Locked Moved Unsolved Hardware
    10 Posts 6 Posters 2.8k Views 6 Watching
    • C-sonC
      C-son Module Developer
      Hi all!
      I just bought a new SD card, a 32GB instead of the current 16GB, thinking that I could clone the current content to the new one. Can I do that, and if so, how? What tools do I need?
      I’m working on a Windows machine usually, if that helps.
      MMM-MagicMover :: MMM-MagicSuperHero :: MMM-MagicHexClock
      • P
        pakal41
        hi
        yes you can with usb image
        link in french
        https://www.clubic.com/telecharger-fiche366602-imageusb.html
          A Former User
          hi, or use SD copy program in your rpi desktop
          • D
            drewski3420
            If you can get on a linux machine, this is quick and easy with dd.
            First, plug in your current sdcard and find the path using
            sudo fdisk -l
            It’ll be a path starting with /dev/, usually /dev/sdX or /dev/mmcblk#. Get the whole drive, not the partition (for a device at /dev/sda, the partitions will be /dev/sda1, sda2, etc).
            Next, copy the current image to a file, using the path you just found:
            sudo dd=$YOUR_NEW_PATH of=$FileName.img bs=1M
            Once it’s finished (it’ll take a while), remove your card and insert the new one, and reverse the process. Find the path to the new card (it may have changed from the original) and use the image file you just created as the input:
            sudo dd if=$FileName.img of=$YOUR_PATH bs=1M
            And you’re done.
              sdetweil @C-son
              @C-son see https://raspberrypi.stackexchange.com/questions/4203/copy-current-sd-image-to-larger-sd-card
                sdetweil @drewski3420
                @drewski3420 but that leaves the new space unused
                B 1 Reply Last reply
                • B
                  blaukon @sdetweil
                  • sudo raspi-config
                  • Advanced Options
                  • Expand Filesystem
                  • reboot
                    that might help :-)
                  Reply Quote -1
                    sdetweil @blaukon
                    @blaukon there is a command to do it too… sinced he is right there doing dd
                    D 1 Reply Last reply
                    • D
                      drewski3420 @sdetweil
                      @sdetweil Can you share the command?
                        @drewski3420 read the content on the link above
