    Pre-built frame
    15 Posts 6 Posters 5.8k Views 6 Watching
    • M
      mrangryoven
      Hi all, Im looking at making a MagicMirror, however I have literally zero skills and no tools required to create a frame or wooden box that I can use.
      Does anyone have any ideas of how I could get say a premade frame? I have heard some people talk about a ikea mirror can work or a art & craft wall mounted display case?
      Thank you in advance.
      hummeruliH S 2 Replies Last reply Reply Quote 0
      • hummeruliH
        hummeruli @mrangryoven
        @mrangryoven Go to IKEA-Verse
        • M
          mrangryoven @hummeruli
          @hummeruli Hi, Not sure what you mean. I searched that and nothing came up. Do you have a link?
          Thanks.
          hummeruliH 1 Reply Last reply Reply Quote 0
            sdetweil @mrangryoven
            @mrangryoven maybe u can find someone locally that can build the frame for you
            • thgmirrorT
              thgmirror
              @mrangryoven , do you have a kitchen-shop around? Some cabinets-doors have a window which will fit to your needs. An old one they may have took in payment, an additional frame behind it (can look bad:-) ) and a tin of colour is all to built a nice mirror.
              • B
                bhepler Module Developer
                Another possibility is going to a framing store - one that will professionally frame portraits, photos, etc. Take your mirror glass with you and explain that you want a shadow box with the interior dimensions the same as the dimensions of the glass and a frame to match. The depth of the shadow box will be the depth of your monitor, plus 10mm or so for airflow.
                They’ll do the custom work for you.
                • hummeruliH
                  @mrangryoven About what kind of size we are talking? On Ikea you get one with 50x70cm for 20€ here in Germany.
                    sdetweil @hummeruli
                    @hummeruli note that u have to have the pi and monitor behind the glass, so behind the glass needs2-3 inches maybe more
                    • hummeruliH
                      hummeruli @sdetweil
                      @sdetweil If you remove the case from the monitor, so you have only the panel. The best is one with external power-supply. And I read about the Pi Zero W so you don’t have any problem. But the other option is to use the Ikea frame and go to the next toolshop for a wood profil and glue. Normaly they also cut it in the size you need.
                        sdetweil @hummeruli
                        @hummeruli yes, just think about it before u order the frame… measure the stuff u have to hide back there!..
                        • hummeruliH
                          hummeruli @sdetweil
                          @sdetweil Sure. In every DIY case you must think before you try to build. It’s not like you go in a shop and buy a DIY kit with a 100% fitting manual. And also all tools are in the set.
                            sdetweil @hummeruli
                            @hummeruli we have lots of users that bought first and the parts don’t fit together…
                            • hummeruliH
                              hummeruli @sdetweil
                              @sdetweil Yeah, but the guy do the right, he ask and now… :person_shrugging_light_skin_tone:
                                sdetweil @hummeruli
                                @hummeruli i was just making sure…
                                • D
                                  dkhorse74
                                  This is an option although expensive:
                                  https://www.twowaymirrors.com/smart-mirror-frame/
