    MMM-BoschSmartHome
    29 Posts 7 Posters 13.6k Views 7 Watching
    • JalibuJ
      Jalibu Module Developer @MajorC
      @majorc nope, not yet. But feel free to create a Feature Request on GitHub for that.
      • B
        Baschti
        I installed the module today, but i get this error:
        [12.02.2023 16:06.09.906] [LOG] Starting MagicMirror: v2.22.0
        [12.02.2023 16:06.09.918] [LOG] Loading config …
        [12.02.2023 16:06.09.928] [LOG] Loading module helpers …
        [12.02.2023 16:06.09.931] [LOG] No helper found for module: alert.
        [12.02.2023 16:06.09.944] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘bosch-smart- home-bridge’
        Require stack:
        • /home/pi/MagicMirror/modules/MMM-BoschSmartHome/node_helper.js
        • /home/pi/MagicMirror/js/app.js
        • /home/pi/MagicMirror/js/electron.js
        • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai n.js
        [12.02.2023 16:06.09.946] [LOG] Loading module helpers …
        [12.02.2023 16:06.09.948] [LOG] No helper found for module: alert.
        [12.02.2023 16:06.09.953] [ERROR] App threw an error during load
        [12.02.2023 16:06.09.956] [ERROR] Error: Cannot find module ‘bosch-smart-home-br idge’
        Require stack:
        at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
        at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/i        ndex.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:811:27)
        at f._load (node:electron/js2c/asar_bundle:2:13328)
        at Module.require (node:internal/modules/cjs/loader:1035:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BoschSmartHome/node_        helper.js:14:65)
        at Module._compile (node:internal/modules/cjs/loader:1141:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
        [12.02.2023 16:06.09.959] [ERROR] Whoops! There was an uncaught exception…
        [12.02.2023 16:06.09.971] [ERROR] Error: Cannot find module ‘bosch-smart-home-br idge’
        Require stack:
        at Module._extensions..js (node:internal/modules/cjs/loader:1196:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        '/home/pi/MagicMirror/modules/MMM-BoschSmartHome/node_helper.js',
        '/home/pi/MagicMirror/js/app.js',
        '/home/pi/MagicMirror/js/electron.js',
        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/        main.js',
        undefined
        [12.02.2023 16:06.09.973] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [12.02.2023 16:06.09.974] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [12.02.2023 16:06.10.508] [LOG] Launching application.
        [1549:0212/160611.418965:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
        [1576:0212/160611.630258:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extens ion not supported.
        magicmirror@2.22.0 start
        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
        Require stack:
        Require stack:
        Require stack:
        i have absolutely no clue :-(
          sdetweil @Baschti
          @Baschti
          looks like you didn’t do the npm install in the module folder
          • B
            Baschti @sdetweil
            @sdetweil The Module is located in MagicMirror/modules/MMM-BoschSmartHome/
              sdetweil @Baschti
              @Baschti yes? and
              the author missed
              a step in his instructions
              between step 1 and 2 do
              cd MMM-BoschSmartHome
              • B
                Baschti @sdetweil
                @sdetweil Awesome! Youre right! Can you give me a tip on how to integrate the window sensors
                  sdetweil @Baschti
                  @Baschti no. sorry, no idea on the actual details of implementation
                  • M
                    mcilliw
                    Hey, I was wondering if it is possible to orientate the tiles of the rooms horizontally? Has anyone got an idea? :D
                    • X
                      Xennon
                      just wanted to leave you my css, which costs me a bit of time. I wanted to have a clean overview, just see the temperatures in my house. Because I have 9 thermostats, a list with all the colors was just to much for me.
                      This css gave me a 3 column design, just with the room name and the current temperature:
                       * MMM-BoschSmartHome
                      .MMM-BoschSmartHome .bsh-wrapper {
                        background-color: rgba(0,0,0,0.00);
                        color: #fff;
                        font-size: 10px;
                          display: grid;
                          grid-template-columns: repeat(3, 1fr);
                          grid-gap: 10px;
                        line-height: normal;
                      .MMM-BoschSmartHome .bsh-wrapper br {
                          display: none;
                      .MMM-BoschSmartHome .bsh-wrapper,
                      .MMM-BoschSmartHome .bsh-tile {
                          margin: 0;
                          padding: 0;
                      .MMM-BoschSmartHome .bsh-room-icon {
                        margin-right: 8px;
                      .MMM-BoschSmartHome .bsh-tiles {
                        font-size: 10px;
                      .MMM-BoschSmartHome .bsh-badge.climate-control {
                        visibility: hidden;
                          min-width: 0; /* Prevent tiles from expanding beyond their column */
                          width: 100%;
                        color: white;
                      .MMM-BoschSmartHome .bsh-room-title {
                        font-size: 10px;
                      .MMM-BoschSmartHome .bsh-tile.tile-row {
                        visibility: hidden;
                      .MMM-BoschSmartHome .bsh-tile i {
                        visibility: hidden;
                      .MMM-BoschSmartHome .bsh-tile.temperature-level span.setpoint-temperature {
                        font-size: 10px;
                      .MMM-BoschSmartHome .bsh-tile.temperature-level div:first-child {
                          visibility: hidden;
                          position: relative;
                      .MMM-BoschSmartHome .bsh-tile.temperature-level span.room-temperature {
                          visibility: visible;
                          position: absolute;
                          left: 0; /* Adjust this to position the temperature correctly */
                          width: 100%;
                        font-size: 1.8em;
                        font-weight: bold;
                        display: inline-block;
                      I’m using this config:
                      		  module: "MMM-BoschSmartHome",
                      		    host: "", // Bosch Smart Home Bridge's local IP Address
                       		    name: "MMM-BoschSmartHome", // Display name for App
                       		    identifier: "MMM-BoschSmartHome", // Unique Identifier for app
                      		    password: "", // Password for Bosch Smart Home Bridge
                      		    refreshIntervalInSeconds: 60, // Default: 60
                      		    width: "200px",
                      		    displayRoomIcons: true, // Default: false
                       		    hideComponents: {
                          			 "Küche": ["dishwasher"]
                      			}, // See example below. Default: {}
                       		    hideEmptyRooms: false, // Hide rooms, if they have no information to display. Default: false
                       		    colorizeRoomWithAirQuality: true, // Colorizes room tiles in red/orange/green depending on combined air quality. Only works with Twinguard
                      		    roomOrder: ["Wohnzimmer", "Küche", "Bad EG", "Flur EG", "Schlafzimmer","Kinderzimmer", "Bad OG", "Flur OG / Büro", "HWR"], // Manually set the room order by a list of room names, e.g. ["Livingroom", "Bedroom", "Kitchen"]
                       		    airquality: {
                       		      purity: "none", // one of [tile, bar, donut, none]
                      		      humidity: "none", // one of [tile, bar, donut, none]
                      		      temperature: "none", // one of [tile, bar, donut, none]
                      		      preferredTemperatureProvider: "Twinguard", // Twinguard or ClimateControl
                      		      preferredHumidityProvider: "Twinguard" // Twinguard or ClimateControl
                      		    temperatureLevel: {
                      		      displayCurrentTemperature: true, // Default: true
                      		      displayTargetTemperature: false, // Default: true
                      		      forceRowTile: false // Show tile as row, even if there is no target temperature. Default: true
                      		    thermostats: {
                      		      display: false, // Default: true
                      		      displayName: false // Default: false
                      		    dishwasher: {
                      Thanks @ the author of this module.
                      Before I forget something … If you have BSHC-2 and not BSHC you just have to press the button for pairing at the BSHC.2, not hold the button, like in BSHC. This simple info costs me a week.
