    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    after MM-Update to 2.14.0 the MMM-PIR-Sensor module not working...
    Troubleshooting
    • G
      gallert last edited by
      here is the log…
      [06.01.2021 13:13.22.135] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘onoff’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/js/electron.js
      • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      can somebody help?
      • M
        MadScientist last edited by
        @gallert said in after MM-Update to 2.14.0 the MMM-PIR-Sensor module not working...:
        MMM-PIR-Sensor
        Did you enter the directory of that module and run the command npm install?
        • G
          That is the solution. how embarrassing… Sorry!!!
          • M
            Don’t be embarrassed. Someone else will have the same issue and will now find the solution here .
            JerryP 1 Reply Last reply Reply Quote 0
            • JerryP
              JerryP @MadScientist last edited by
              @MadScientist that’s the spirit
                sdetweil @MadScientist last edited by sdetweil
                @MadScientist and if you had run the upgrade script, it would have done the npm install in the appropriate module folders
                see
                G M 2 Replies Last reply Reply Quote 1
                • G
                  gallert @sdetweil last edited by
                  @sdetweil said in after MM-Update to 2.14.0 the MMM-PIR-Sensor module not working...:
                  see
                  Thanks… for the next update
                  • M
                    MadScientist @sdetweil last edited by
                    @sdetweil Hehe, I only remembered to mention the script after I already replied.
                    Let me take this opportunity to thank you for what you do or this community!
