    [module.show] Not animated instantly shown
    10 Posts 4 Posters 6.2k Views 4 Watching
    • tosti007T Offline
      tosti007 Module Developer
      When calling the show function from a module it doesn’t use it’s animation, no matter the animation time. I am using windows and just did a clean pull to make sure it wasn’t the fault of a module I was making.
      To test this I made a very simple module, code:
      Module.register("TestHideShow", {
          notificationReceived: function (notification, payload, sender) {
              if (notification === "TEST_HIDE") {
                  MM.getModules().enumerate(function (module) {
                      module.hide(10000);
              if (notification === "TEST_SHOW") {
                      module.show(10000);
      All it does is hide all modules when a notification is recieved.
      Then I copied the sample config, removed both weather modules and added:
          module: "MMM-ModuleScheduler",
              notification_schedule: [
                  {notification: "TEST_HIDE", schedule: "3 * * * *", payload: "a"},
                  {notification: "TEST_SHOW", schedule: "4 * * * *", payload: "b"}
          module: "TestHideShow"
      I used the ModuleScheduler to send 2 notifications, with one minute in between.
      For the hide animation everything works as expected, a very slow fade out (10sec). Then after one minute you would expect a very slow fade in (also 10sec), but it just pops onto the screen as if the duration was 0. I also checked the log and it didn’t do anything unusual.
      Is anyone able to recreate this/does anyone encountered the same issue?
      Note: I came across this while making a different module, so it’s not because of this testing module only.
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • tosti007T Offline
        I tested this with the remote controll module aswell and experienced the same result.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @tosti007
          @tosti007 the core adds this style property to the wrapper moduleWrapper.style.transition = "opacity " + speed / 1000 + "s"; when the hide function is called, inspect the elements in your browser and see if this shows your 10 seconds
          tosti007T 1 Reply Last reply Reply Quote 0
          • tosti007T Offline
            tosti007 Module Developer @strawberry 3.141
            @strawberry-3.141 Checked it, what happened was that this transition style was added as expected. However what I did notice was that the container within a region also changed it’s display value. When hiding it was set to display: none; after the animation. When showing a module it was set to display: block; and right when that happens the module is visible without animation (eventhough the module’s container did change transition value)
            • tosti007T Offline
              Note: I tested it with electron and firefox
              • T Offline
                TheBogueRat
                I’ve been fighting with this as well. @tosti007 I noticed the same thing in the inspector. Still looking for a solution but digging into the guts of this thing is time consuming… I appreciate the test results, that saved me some time chasing ghosts.
                // Show the desire modules
                var showModules = MM.getModules().withClass(page);
                for (i = 0; i < showModules.length; i += 1) {
                    showModules[i].show(this.config.fadeTime);
                If I figure it out I’ll post an update. I just wanted to let someone know that I’m experiencing the same issue.
                • tosti007T Offline
                  tosti007 Module Developer @TheBogueRat
                  @TheBogueRat yea indeed it takes quite a while, let me know if you find anything! I hope you do
                  • T Offline
                    TheBogueRat
                    I’ve found that if I have multiple iFrames in one position, i.e. ‘top_left’ and fade one out completely then start the fade in on the next one, I get the fade in/out to work properly which is my desired outcome.
                    If I have single iFrames in the left and center and try to fade one out and the other in, it always pops in. That needs to be fixed but I couldn’t identify a cause.
                    • CatoC Offline
                      Cato Module Developer
                      I noticed that animations works if you have at least one other visible module inside the region.
                      I think the problem is in the function updateWrapperState (main.js) that will change the region wrapper’s style to “none” if no module inside the same region has a style.position of “fixed”.
                      I’ve just added a PR that hopefully fixes this issue: https://github.com/MichMich/MagicMirror/pull/744
                      • CatoC Offline
                        Just want to notify you that this issue has been solved in the latest commit in the develop-branch.
                        1 Reply Last reply Reply Quote 4
