    Trouble getting it to start
    23 Posts 5 Posters 17.5k Views 4 Watching
    • P Offline
      PhilsterM9 @in_a_days
      @in_a_days I’m not sure how to test it as I said before that I am fairly new to this.
      in_a_daysI 1 Reply Last reply Reply Quote 0
      • in_a_daysI Offline
        in_a_days @PhilsterM9
        @PhilsterM9
        No worries, I did the same thing on my first install!
        If you made it this far you should be able to put a fresh copy of Raspbian on your SD Card. Once done, go to the terminal and:
        curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
        for a clean install of MM.
        Before it’s going to run, you need to rename/copy the config.js file. Hit the terminal and
        cd MagicMirror/config
        cp config.js.sample config.js
        That config.js file is going to be very important in customizing your mirror. Next:
        cd ..
        DISPLAY=:0 nohup npm start
        If your mirror software pops up without issue you’re in the clear and can proceed with the Configuration and Auto-Start stuff. But if you’ve got any issues at this point, it ought to be troubleshot before continuing with system changes.
        What ship would bear me ever back across so wide a Sea?
        P 3 Replies Last reply Reply Quote 0
        • P Offline
          @in_a_days I’ll clear my sd card and restart the process using your instructions here. I will let you know what happens, thanks!
          • P Offline
            This post is deleted!
            • P Offline
              @in_a_days Could you explain how to do the
              “cd MagicMirror/config
              cp config.js.sample config.js”
              I can’t get it to work because I don’t know how to do it
                @PhilsterM9
                You need to launch the Terminal to get to the command prompt. Same place from which you launched the MM installer. If you type:
                you should see that you’ve changed directories. Then type:
                That’s it. MM should be ready to launch.
                • P Offline
                  @in_a_days As I did as you said, this is what happened which I am not sure if it is supposed to happen0_1484639345331_Photo 17-1-17, 5 30 29 pm.jpg
                  in_a_daysI yawnsY 2 Replies Last reply Reply Quote 0
                    @PhilsterM9
                    Yes! From that screen type:
                    cd ..
                    So you see
                    pi@raspberrypi: /MagicMirror $
                    then type
                    DISPLAY=:0 npm start
                    • yawnsY Offline
                      yawns Moderator @PhilsterM9
                      @PhilsterM9 said in Trouble getting it to start:
                      I am not sure if it is supposed to happen!
                      Just as a side note: This is linux. No news is good news. By default there is no feedback like “1 file copied”.
                      If you don’t feel comfortable with the shell you can work on your raspberry directly using the file explorer
                      • P Offline
                        @in_a_days I tried it and it turned on. But when I reboot it, it doesn’t open the magic mirror like it should, even though I did all the pm2 steps. Also how do I change some of the settings of the magic mirror? (eg. timezone etc.)
                        • 3 / 3
