    Basic configuration issues with compliments & calendar modules
    4 Posts 2 Posters 2.9k Views 2 Watching
    • M
      mh77
      Hi all,
      Some very simple things don’t work, I’m guessing it’s me so thanks for your patience :) I’ve successfully installed MagicMirror and have been able to configure it to show my Google Calendar, as well as weather for my region. So far, so good.
      However, I could only get the compliments module to disappear by removing it from the config.js file. Adding disabled: true in the following manner (like it says here) does not seem to have any effect:
                              module: 'compliments',
                              position: 'lower_third',
                              disabled: 'true',
      Then, when I configure the calendar, the maximumEntries seems to be respected but preventing fading or hiding the symbol before each entry does not work with this configuration:
                              module: 'calendar',
                              position: 'top_left',
                              header: 'Agenda',
                                      maximumEntries: '5',
                                      displaySymbol: 'false',
                                      fade: 'false',
                                                      url: 'https://URL.ics'
      I hope anyone knows if I’m doing something wrong, and what?
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @mh77
        @mh77 you have to type booleans without quotes
        disabled: true , fade: false and displaySymbol: false
        • M
          mh77
          Ah of course, that’s it. Thanks so much!
          I hadn’t thought of it, because when I used ‘onlyTemp’ in my currentweather module config, it worked when I entered ‘true’. But it also only shows the temperature when I enter ‘false’ there, so it somehow defaults to true if you enter it with any value between single quotes.
          Anyhow, thanks again!
          • strawberry 3.141S
            @mh77 a string in javascript is handled as true, so 'false' => true
