    module that displays a certain text from a website, the text on the website is updated daily
    36 Posts 6 Posters 15.4k Views 7 Watching
    • A
      Amoniak
      I need a module that displays a certain text from a website, the text on the website is updated daily.
      I was looking for such a module but unfortunately couldn’t find anything.
      There are modules such as iFrame, but I want the text to be displayed on my mirror and not an image.
      does anyone know such a module?
        sdetweil @Amoniak
        @Amoniak what is the text? csn you use compliments w the remoteComplimentsFile?
        • A
          Amoniak
          I’m embarrassed because I’m really at the beginning, but I’ll just show you the link: “https://wol.jw.org/hr/wol/h/r19/lp-c”
          the text on the right should be displayed and automatically updated.
            sdetweil @Amoniak
            @Amoniak nah, compliments cant do that
            • A
              Amoniak
              Yes that is what I thought. is there another module?
              and thank you for your help
                sdetweil @Amoniak
                @Amoniak look thru the 3rd party.list. not up to date by a mile, but maybe
                https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                • A
                  Amoniak
                  I think I’ve found a similar module (MMM-PoemOfTheDay), but I don’t know how to adapt it to my needs, can someone help me?
                  • A
                    ashishtank Module Developer @Amoniak
                    @Amoniak MMM-PoemOfTheDay is perfect to adapt for your need. Instead of poem site you need to get data from WatchTower site and parse the html response to extract the text.
                    • A
                      Amoniak @ashishtank
                      @ashishtank said in module that displays a certain text from a website, the text on the website is updated daily:
                      wow, thank you very much for your feedback, I’ll try to see if I can do it.
                      • A
                        Amoniak
                        @ashishtank ok, I have installed the module, but it only shows me a black screen
                        • A
                          @Amoniak any error in dev console or PM2/terminal ?
                          • A
                            Amoniak @ashishtank
                            @ashishtank i got it now, i will now try to parse the html response to extract the text, any good tips?
                            A E 2 Replies Last reply Reply Quote 0
                            • A
                              @Amoniak yes, I checked the response from watch tower in postman and they give data of last 2-3 days or may be from Sunday to this day, so you will need to select the right node. You can use class tabContent as identifier and today’s date for selection of the node. Also check which html parse is good enough, as HTML is very complex to parse you may want to choose right parser which gives speed and is lightweight. i.e. node-html-parser
                              2021-01-20-18-33-58-Clipboard
                              Other thing you can do is once you have parsed text data from watch tower, you can assign it to poem’s format (title, content and name) and it will just work. later on you can change the UI and text property names if you want.
                                sdetweil @ashishtank
                                @ashishtank cheerio lib will parse html to json
                                • A
                                  Amoniak
                                  well, I’ll get started then. Keep your fingers crossed.
                                  • A
                                    Amoniak
                                    i installed cheerio, but i don’t know how to use it.
                                    do I have to put this now in my “MMM-PoemOfTheDay.js” ?
                                      sdetweil @Amoniak
                                      @Amoniak gotta go read the library usage
                                      • L
                                        lolo
                                        It gonna be harder than u think as your text is changing daily. Just follow the the pattern.
                                        Every day this is changed( https://wol.jw.org/hr/wol/h/r19/lp-c).
                                        new day new text.
                                        Text is in :
                                        div id=“dailyText”
                                        but if you ignore reference in text as (Mat. 16:24, 25; Ivan 15:20) located in a class it’s gonna be more easier.
                                        And with cheerio u can complete this.
                                        • A
                                          Amoniak
                                          so, this is what my NodeHelper.js looks like. like i thought, the screen is black.
                                          const axios = require("axios");
                                          const DetectLanguage = require("detectlanguage");
                                                  socketNotificationReceived: async function(noti, payload) {
                                                          if (noti === "START") {
        if (payload.updateInterval < 120000) {
        payload.updateInterval = 120000;
        const self = this;
        (async function displayWatchtower () {
        const poem = await getWatchtower(payload);
        self.sendSocketNotification("UPDATE", poem);
        setTimeout(displayPoem, payload.updateInterval);
                                          const cheerio = require("cheerio");
                                          const axios = require("axios").default;
                                          const fethHtml = async url => {
                                            try {
                                              const { data } = await axios.get(url);
                                              return data;
                                            } catch {
                                              console.error(`ERROR: An error occurred while trying to fetch the URL: ${url}`);
                                          const extracWatchtower = selector => {
                                            const theme = selector
                                              .find(".tabContent active")
                                              .find("[class='themeScrp'] > [class='b'])
                                              .text()
                                              .trim();
                                           const text = selector
                                              .find(".bodyTxt")
                                              .find("[class='section']")
                                              .text()
                                              .trim();
                                           return { theme,
                                                    text
                                          const scrapWatchtower = async () => {
                                            const watchtowerUrl =
                                              "https://wol.jw.org/hr/wol/h/r19/lp-c";
                                            const html = await fethHtml(watchtowerUrl);
                                            const selector = cheerio.load(html);
                                            const searchResults = selector("body")
                                                .find("#dailyText"
                                            const deals = searchResults.map((idx, el) => {
                                                const elementSelector = selector(el);
                                                return extractDeal(elementSelector)
                                              .get();
                                            return Watchtower;
                                          • A
                                            @Amoniak there are lots of missing pieces… add console.log with some message in each function and see how the flow works.
