    module that displays a certain text from a website, the text on the website is updated daily
    36 Posts 6 Posters 14.8k Views 7 Watching
    • L Offline
      lolo
      Try to do something with this code. It will retrieve data from current day. Modifying that node_helper is not great idea.
          const url=  'https://wol.jw.org/hr/wol/h/r19/lp-c';
          request({
              url: url,
              method: 'GET'
              }, (error, response, body) => {
                  if (error) {
                      return console.error(error)
                  var $ = cheerio.load(body);
                  //console.log($.html());
                  const data =  $('div[class="tabContent"]').first();
                  let header = $(data).find('h2').text();
                  let title = $(data).find('p').first().text();
                  let text = $(data).find('div.pGroup>p').text();
                  //console.log(header,title,text);
                  var recivedData={
                      header,
                      title,
                      text
                  //console.log(recivedData);
      • F Offline
        fordi
        I bet you could use the same technique to see if any playstation 5 are in stock on websites?
          Amoniak @lolo
          @lolo thank you for the code.
          I used the “MagicMirror-Module-Template” to create a new file and the associated folder.
          this is my js:
          Module.register(“dnevni_citat”, {
          defaults: {
          updateInterval: 60000,
          retryDelay: 5000
              requiresVersion: "2.1.0", // Required version of MagicMirror
              start: function() {
                      var self = this;
                      var dataRequest = null;
                      var dataNotification = null;
                      //Flag for check if module is loaded
                      this.loaded = false;
                      // Schedule update timer.
                      this.getData();
                      setInterval(function() {
                              self.updateDom();
                      }, this.config.updateInterval);
          request({
              url: url,
              method: 'GET'
                  if (error) {
                  var recivedData={
                      header,
                      title,
                      text
          what am I doing wrong?
          • L Offline
            lolo
            This should be your node_helper.
            const NodeHelper = require("node_helper");
            const cheerio = require("cheerio");
            const request = require('request');
                start: function () {
                    self = this;
                    console.log("Starting node_helper for: " + this.name);
                getData: function () {
                    const url = 'https://wol.jw.org/hr/wol/h/r19/lp-c';
                    request({
                        url: url,
                        method: 'GET'
                        if (error) {
                        var recivedData = {
                            header,
                            title,
                            text
            			self.sendSocketNotification('TEXT_RESULT', recivedData);
                socketNotificationReceived: function (notification, payload) {
                    if (notification === 'GET_TEXT_DATA') {
                        self.getData();
            • L Offline
              lolo
              Now create MMM-Dnevni_citat.js
              Inside you need first to registar module
              Module.register("MMM-Dnevni_citat", {
              	defaults: {
              		updateInterval:  10 x  60 x 1000,       //  minute ,seconds ,milliseconds
              		//retryDelay: 5000          // not needed for now
              Then first function will be start function
                      Log.info("Starting module: " + this.name);
                      requiresVersion: "2.1.0";
                      this.scheduleUpdate();
              with first function we are calling second ( scheduleUpdate) , how often will fetch data.
                 scheduleUpdate: function () {
                      setInterval(() => {
                          this.getData();
                      this.getData();
              Then we are calling getData function. Sending socketNotification to node_helper.
                      this.sendSocketNotification(''GET_TEXT_DATA'', this.config);
              Whe node_helper send back, next function will check if data is received and update DOM
                     if (notification === "TEXT_RESULT") {
                         this.textDataRecived = payload;
                         this.loaded = true;
                    },this.updateDom();
              Now only is left to create DOM
                  getDom: function () {
                      if (!this.loaded) {
                          wrapper.innerHTML = "LOADING";
                          return wrapper;
                      if (this.loaded) {
                     // here to add elements and styling
                         return wrapper;
                Amoniak @lolo
                @lolo
                i did that. it is still not displayed
                i added this configuration in the config.js file:
                module: “MMM-Dnevni_citat”,
                position: “middle_center”
                • L Offline
                  lolo
                  It’s not displayed as DOM elements are not created.
                  But there is another problem with cheerio, is not loading any data for Saturday and Sunday. This is because of website. Need to find another approach.
                  • L Offline
                    lolo
                    node_helper. But need to find different approach.
                    var self;
                            self = this;
                            request({
                                url: url,
                                method: 'GET'
                                if (error) {
                                    return console.error("ERROR: ",error)
                                if (!error && response.statusCode == 200) {
                                const data = $('div[class="tabContent"]').first();//
                                let textData = $(data).find('div.pGroup>p').text();
                                var recivedData = {
                                    header,
                                    title,
                                    textData
                    			//console.log('recivedData: ',recivedData);
                         var self = this;
                                //console.log(notification,payload);
                    			self.getData();
                    MMM-Dnevni_citat.js. getDom need some styling.
                        defaults: {
                            updateInterval: 10 * 60 * 1000, //  minute ,seconds ,milliseconds
                            setInterval(() => {
                                this.getData();
                            this.getData();
                            console.log(' GET_TEXT_DATA ', this.config)
                            this.sendSocketNotification('GET_TEXT_DATA', this.config);
                                console.log(this.textDataRecived);
                                this.loaded = true;
                            this.updateDom();
                            if (!this.loaded) {
                                return wrapper;
                            if (this.loaded) {
                                var header = document.createElement("header");
                                header.innerHTML = this.textDataRecived.header;
                                wrapper.appendChild(header);
                                var table = document.createElement('tr');
                                table.classList.add("xsmall", "normal");
                                var title = document.createElement('tr');
                                title.innerHTML = this.textDataRecived.title;
                                table.appendChild(title);
                                var textData = document.createElement('tr');
                                textData.innerHTML = this.textDataRecived.textData;
                                table.appendChild(textData);
                                wrapper.appendChild(table);
                            return wrapper;
                    config.js
                    		{    module: "MMM-Dnevni_citat",
                                 position: "middle_center"
                    • L Offline
                      lolo @Amoniak
                      @Amoniak
                      This should fix the problem with loading text for current Date.
                      node_helper:
                      var self;
                      const ur = 'https://wol.jw.org/wol/dt/r19/lp-c';
                              self = this;
                              self.browser
                              var self = this;
                              var url = self.setURL();
                              request({
                                  url: url,
                                  method: 'GET'
                                  if (!error) {
                                      var result = JSON.parse(body);
                                      var contentData = result.items[0].content;
                                      var $ = cheerio.load(contentData);
                                      //console.log("cheerio:  ", $.html());
                                      var header = $('html>body>header>h2').text();
                                      var title = $('p').first().text();
                                      var textData = $('p').first().next().text().replace(/(\r\n|\n|\r)/gm, "");
                                      var recivedData = {
                                          header,
                                          title,
                                          textData
                                  if (error) {
                                      console.log(error);
                          setURL: function () {
                              console.log("ur old: ", ur);
                              var utc = new Date().toJSON().slice(0, 10).replace(/-/g, '/');
                              var newURL = ur.concat("/").concat(utc);
                              return newURL
                              var self = this;
                                  self.getData();
                        Amoniak @lolo
                        @lolo
                        thank you, I’ll try right now
                          Amoniak
                          @lolo there it is.
                          many, many, many thanks. and thanks for adding explanations
                          • L Offline
                            lolo @Amoniak
                            @Amoniak you’re welcome.
                            Just delete the second appendChild in MMM-Dnevni_citat.js
                                        table.appendChild(title);        // delete this one
                            I added twice,my mistake.
                            • E Offline
                              e199504 @Amoniak
                              @amoniak how did you fix the black screen? I am getting the same error
                                sdetweil @e199504
                                @e199504 is this after install?
                                did u do the npm install in the module folder?
                                • E Offline
                                  e199504 @sdetweil
                                  @sdetweil in the reeadme file it did not say to go inside the module and use npm install but once I did it started working.
                                  thank you
                                    sdetweil @e199504
                                    @e199504 yes. it seems many authors forget to write that step.
                                    general rule. look for a package.json file.
                                    if present, run the npm install
